Mac EFI Toolkit
  • mtherana
    • 122
    • South Africa
    Re: Mac EFI Toolkit
    Thank you Sir Does it Support A1398
    • MuertoGB
      • Sep 2021
      • 94
      Re: Mac EFI Toolkit
      Yes, it supports anything with an accessible EFIROM. Dump the SPIROM contents, open it with the application.
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        Re: Mac EFI Toolkit
        hi, how can I remove MDM with your tool? is enough to edit serial?
        thank you.
        • MuertoGB
          • Sep 2021
          • 94
          Re: Mac EFI Toolkit
          thank you.
          Yes, enter a clean serial number in the patcher, and select the following so you don't have to perform an NVRAM reset on boot.
          Code:
          Clear VSS Store
          Clear VSS Backup Store
          • volinakis
            • Jan 2021
            • 2877
            • N/A
            Re: Mac EFI Toolkit
            Code:
            Clear VSS Store
            ok, thank you. What means "clean serial number"? I modified 3 characters randomly, cleared VSS store and replaced ME and now is not asking for MDM enrollment at setup.
            • MuertoGB
              • Sep 2021
              • 94
              #26
              Re: Mac EFI Toolkit
              This is essentially what I mean, use a serial number that isn't bound to MDM. Glad to hear it worked for you.
              • reformatt
                • Feb 2020
                • 1550
                Re: Mac EFI Toolkit
                I usually use one off from the many base covers I have lying around. The danger of using a random one is that it is potentially bound to another MAC elsewhere. Not so much an issue with the older Mac's these days I guess but the possibility is there.
                This is why Apple stopped the iCloud lookup service years back, as China was using it to find valid (unlocked) serial numbers by changing the last 3 digits. They were then having conflicts with iCloud on legitimate devices as a result and having to replace them for the real customers. Was great being able to buy stuff and being able to check on it in advance....not any more.
                • MuertoGB
                  • Sep 2021
                  • 94
                  #28
                  Re: Mac EFI Toolkit
                  This is why I prefer a clean donor serial from a dead board. Someone could end up MDM locking another persons SSN.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1375
                    • France
                    #29
                    Re: Mac EFI Toolkit
                    thank you.
                    you can use BBS to change serial until 2017 without removing eeprom
                    https://www.badcaps.net/forum/showpo...10&postcount=1
                    or
                    https://www.badcaps.net/forum/showpo...59&postcount=2
                    • volinakis
                      • Jan 2021
                      • 2877
                      • N/A
                      #30
                      Re: Mac EFI Toolkit
                      or
                      right, thank you, I discovered your tool after I modified bios. I did try it on A1466 2017 and works well.
                      @Maxpower3
                      @MuertoGB
                      Thanks again for sharing your work, is very useful!
                      • classicandy
                        • Apr 2018
                        • 309
                        • Nigeria
                        #31
                        Re: Mac EFI Toolkit
                        Code:
                        Clear VSS Store
                        Hi, can I also use this tool to remove MDM on an Air M1 ?
                        • oxonater
                          • Oct 2012
                          • 77
                          • uk
                          #32
                          Hey peops
                          As above I don't think this method works with M1 as there is no serial saved in the ROM chip itself
                          Great tool though
                          OXY 😉
                          • macospk
                            • Feb 2021
                            • pakistan
                            #33
                            This can support a2141 with bridge os 8.3?
                            • oxonater
                              • Oct 2012
                              • 77
                              • uk
                              #34
                              Hi all
                              Just a quicky any reason i'm getting invalid image on T2 dumps ?
                              Thank OXY
                              • reformatt
                                • Feb 2020
                                • 1550
                                This tool is for EFI dumps for pre-T2 machines. T2 SPI ROM dumps aren't EFI , however I think Muerto said he may consider supporting them down the track though.
                                • oxonater
                                  • Oct 2012
                                  • 77
                                  • uk
                                  #36
                                  Ah ok makes sense
                                  Thanks OXY 😀
                                  • reformatt
                                    • Feb 2020
                                    • 1550
                                    Just noted the other day when I was upgrading a 2017 iMac (has USB C ports on the rear in addition to the USB A ports) that it appears to have an updated NVMe driver in the BIOS. I say this because I tried one of my Crucial P3 SSD's (and adaptor) and was detected fine. 2015 A1466/A1502 etc currently do not detect these newer drives. Double checked this again with BIOS 489.0.0.0 in the 2015 MBA and still doesn't work.
                                    • MuertoGB
                                      • Sep 2021
                                      • 94
                                      #38
                                      Correct, the toolkit does not support T1, or T2, currently. Possibly in the future.
                                      Sorry for the lack of updates, I've been extremely busy lately. Version 1.2.0 will come later this year, a time frame is not set.
                                      NOTE: I've identified an issue when clearing the NVRAM stores, there is more to clearing the store header than I though, therefore sometimes when a user clears the NVRAM store the device may fail to boot. A patch will be applied for the next update.
                                      • TeslaK
                                        • May 2024
                                        • Turkey
                                        #39
                                        i have a question. i changed my macbook pro serial number but mdm popup still came time to time. is there a way to stop it?
                                        Thanks.
                                        • MuertoGB
                                          • Sep 2021
                                          • 94
                                          #40
                                          Thanks.
                                          Some things to check:
                                          1. Is the replacement SN MDM attached? Is it known clean from MDM?
                                          2. Did you clear the NVRAM on boot after replacement? (Do not use MacEfiToolkit to clear the NVRAM at the moment, use key commands).
                                          3. Did you re-install MacOS after the SN change? If not, the flag might be written to the OS and you'll need to format and re-install again.
                                          In the future, if you're just changing the SN, it's best to use BBS as it saves you from dumping the firmware.
                                          https://www.badcaps.net/forum/troubl...01#post1864401
                                          • TuanTongbadcaps
                                            Change CPU multiplier through BIOS editing
                                            by TuanTongbadcaps
                                            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                            07-22-2024, 07:57 PM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
                                          • sezsizada
                                            hp 15-fb0000nx bios editing request
                                            by sezsizada
                                            Hello
                                            I need your advice and help on a topic.
                                            Since we did not have the existing chip on the HP motherboard with a faulty VGA chip, we installed a different chip. How can we enable this on the device?
                                            old vga chip GN20-P1-A1
                                            new vga chip GN20-P0-A1
                                            I add original bios water
                                            thank you in advance...
                                            07-21-2025, 10:24 AM
                                            Copy DMI info easily with Hex editing software and Macro script
                                            by SMDFlea
                                            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                            02-28-2023, 02:14 PM
                                          • Aditya11ttt
                                            On Board Ram Disable via Bios Editing
                                            by Aditya11ttt
                                            Post Hp | Dell | Asus | Lenovo
                                            on board Ram Bios we try to disable via bios edit.
                                            07-31-2022, 08:03 AM
