Mac EFI Toolkit
  • MuertoGB
    • Sep 2021
    • 94
    Mac EFI Toolkit
    Hi all. I'm Muerto, the creator of SMCTool/SMCFT. I thought this would be a good home for discussion regarding an open source pet project I've been working on that aims in easing Mac BIOS/UEFI analysis and editing. It is currently developed for Windows, however is Wine compatible based on my own testing, and feedback from others. Project available on Github, there is also a manual with basic usage instructions.
    In terms of editing, it can export and replace the Fsys Store, edit the serial number + hwc, clean NVRAM stores, export and replace the ME Region in a limited manner, invalidate EFI lock by modifying the Message Authentication Code, etc. The Fsys CRC is also automatically masked when necessary.
    It provides information gathering capabilities, including reading the AppleRomSectionInformation, serial (ssn), hardware config (hwc), system order number (son), EFI version, board-id, detects the APFS driver (looks inside LZMA DXE volumes also), ME version.
    Updates are planned. There are currently some DPI scaling issues at 100% size, however these have been fixed for the coming update. I'm also learning a lot as I go on; however much testing is done. Here to answer any questions and support requests when I'm available.
    Thanks for reading, Muerto.
  • spidertnt
    • Jul 2016
    • 34
    Re: Mac EFI Toolkit
    Awesome... I'll give it a try
    Thank you !
    • reformatt
      • Feb 2020
      • 1549
      Re: Mac EFI Toolkit
      Brilliant. Will try it this week as I get lots of old/bad boards that I fix and refurb.
      One of the biggest threats for me now with the pre T1/T2 system refurbishment is that newer NVMe drives (with adaptor) are no longer recognised. Crucial P2 drives worked fine but are now obsolete. P3/P3 Plus are not recognised, nor are Kingston NV2 drives. The latter were working then a later batch I ordered were no longer recognised. Is this something you could look at perhaps? The only ones that I can currently get that work are WD Blue SN570 drives.
      • Sergioz
        • Apr 2016
        • 12
        • New Zealand
        Re: Mac EFI Toolkit
        It says Assets/met.pfx is password protected on compilation attempt. It requests password to import a certificate with sn.exe
        Any solution to this? Cheers
        • MuertoGB
          • Sep 2021
          • 94
          Re: Mac EFI Toolkit
          No worries, let me know how you get on. I'm always open to improvements, and looking out for bugs.
          This would be part of compatibility in the NVMe DXE driver, and the lack of updates. It's out of my scope right now, but I've put it on the research list.
          • MuertoGB
            • Sep 2021
            • 94
            Re: Mac EFI Toolkit
            If you're building from source, you will need to either disable signing, or resign the executable with your own PFX cert.
            In Visual Studio menu go to "Project > mefit Properties", then on the left hand navigation menu select "Signing" and uncheck "Sign the assembly".
            • MuertoGB
              • Sep 2021
              • 94
              Re: Mac EFI Toolkit
              Version 1.1.2 released. Fixes scaling issues based on feedback, adds some navigational improvements to dialogs.
              https://github.com/MuertoGB/MacEfiTo...leases/tag/112
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                Re: Mac EFI Toolkit
                tnx ill try this for sure and tnx for the great work
                • MuertoGB
                  • Sep 2021
                  • 94
                  Re: Mac EFI Toolkit
                  No worries, and thank you. Here to answer any questions.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: Mac EFI Toolkit
                    Good Job@MuertoGB. Thanks for sharing. We need more people like you in this forum.
                    • reformatt
                      • Feb 2020
                      • 1549
                      Re: Mac EFI Toolkit
                      Great tool, saves me a few steps. Only thing I suppose so far is a 'save as' for the output image file. It's currently outimage_OrigFilename_number.bin
                      I usually use the format to describe what it is to refer back to when needed. But I guess this tool makes it superfluous really as it's pretty quick to do.
                      Boardnumber_SerialNumber_BiosVersion_CleanME.bin
                      • MuertoGB
                        • Sep 2021
                        • 94
                        Re: Mac EFI Toolkit
                        @mcplslg123: Thank you for the kind words. I appreciate them.
                        @reformatt: I've added this to the list of changes coming in 1.1.3. In the beginning I was trying to make it 'simple', however trickling feedback is making it better; this is why I listen. In the next release you'll be able to provide your own path (it will still default to the 'builds' directory), and your own filename.
                        • MuertoGB
                          • Sep 2021
                          • 94
                          Re: Mac EFI Toolkit
                          Okay, changes to allow a custom build path commited to the dev branch for the coming release. Clicking 'Build' in the patcher will now prompt a 'Save As' dialog, by default the path will show as, e.g: 'outimage_C02QC080FVH3_428.40.10.0.0.bin'; this way you can change appropriately.
                          https://github.com/MuertoGB/MacEfiTo...cbb91f4120a18d
                          Thanks for your feedback.
                          • MuertoGB
                            • Sep 2021
                            • 94
                            Re: Mac EFI Toolkit
                            Version 1.1.3 released. changes are based on user feedback, fixes some issues found during bug tracking.
                            https://github.com/MuertoGB/MacEfiTo...leases/tag/113
                            • reformatt
                              • Feb 2020
                              • 1549
                              Re: Mac EFI Toolkit
                              Great tool Muerto! Have been using to refurbish a few boards and a couple of things on the wish list.
                              When setting custom initial folder path to somewhere else, the patcher ignores that and just defaults to the parent directory the executable is in.
                              I went to copy the S/N to import to another BIOS, and clicked on it. Then realised you could do that via the COPY menu. Is that a big thing to just be able to click on the S/N for example to copy to clipboard?
                              Saves me a heap of time then doing this all manually with HXD and UEFI tool. Brilliant work!
                              • MuertoGB
                                • Sep 2021
                                • 94
                                Re: Mac EFI Toolkit
                                @reformatt
                                Thanks for the feedback, I appreciate it.
                                As for 'click to copy' you can double click any label to put the text into the clipboard, it's just not very 'apparent'; I'll look into creating some visual feedback for this in an update.
                                For the patcher path, could you explain a little more about which path you speak of? For Fsys Stores and ME Regions, they will always default to their respected paths in the working directory ('/me_regions', '/fsys_stores'), unless I'm missing something. If you mean the patcher outputs to /builds folder, this was updated in version 1.1.3 and you can now select your own output path.
                                If you ever have any more feedback regarding navigational improvements, etc, I'm all ears.
                                Thanks, Muerto.
                                • reformatt
                                  • Feb 2020
                                  • 1549
                                  Re: Mac EFI Toolkit
                                  Didn't realise that, sorry, should have RTFM. But I've seen other programs highlight the field like a hyperlink, and it blinks when you click on it (or you get a small bubble saying copied to clipboard).
                                  So WRT to the path I mentioned. I have the exe under D:\Bios Tools, but my custom path is D:\Bios Dumps. When I use the patcher side of and press Build, it defaults to D:\Bios Tools\build, rather than D:\Bios Dumps\build.
                                  As far as naming goes, there is nothing to distinguish that the file is a Clean ME. Current naming arrangement is outimage_SerialNumber_BiosVersion.bin. If I replace the ME, then I rename it to BoardNumber_SerialNumber_BiosVersion_CleanME.bin.
                                  • MuertoGB
                                    • Sep 2021
                                    • 94
                                    Re: Mac EFI Toolkit
                                    See it's not in the manual either, so it's no wonder you didn't know. I'm working on click-to-copy for the coming update (shouldn't be much longer).
                                    I understand what you're speaking of now regarding the path, I'll eventually get to adding another path for the patchers initial directory into the settings, however, I have to do some work on the settings system first. I'll keep you posted here.
                                    As for 'CleanME' being appended to the file path automatically, this is not possible with the way mefit is built. ME Region editing is very basic on purpose, and leaves it to the user to ensure the Management Engine firmware is properly configured. It cannot detect if a firmware is initialized or configured, therefore you'll have to append the file name text yourself.
                                    Thanks again for investing your time into giving me feedback. It really helps.
                                    • reformatt
                                      • Feb 2020
                                      • 1549
                                      Re: Mac EFI Toolkit
                                      Ok, get that. Wasn't asking for the program to detect it per se, rather just append it IF I select the Replace ME region option in the patcher. But I will just add it when I rename the outimage part to the board number.
                                      • MuertoGB
                                        • Sep 2021
                                        • 94
                                        Re: Mac EFI Toolkit
                                        Version 1.1.4 released. This release was focused on user feedback, improving the AppleEFI firmware parser, and refactoring of the codebase.
                                        https://github.com/MuertoGB/MacEfiTo...leases/tag/114
                                        @reformatt I've implemented single click copy to most main window labels for you, enjoy. I'll add the ability for a custom initial path in the patcher for the next release.
                                        • TuanTongbadcaps
                                          Change CPU multiplier through BIOS editing
                                          by TuanTongbadcaps
                                          Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                          07-22-2024, 07:57 PM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
                                        • sezsizada
                                          hp 15-fb0000nx bios editing request
                                          by sezsizada
                                          Hello
                                          I need your advice and help on a topic.
                                          Since we did not have the existing chip on the HP motherboard with a faulty VGA chip, we installed a different chip. How can we enable this on the device?
                                          old vga chip GN20-P1-A1
                                          new vga chip GN20-P0-A1
                                          I add original bios water
                                          thank you in advance...
                                          07-21-2025, 10:24 AM
                                          Copy DMI info easily with Hex editing software and Macro script
                                          by SMDFlea
                                          Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                          Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                          02-28-2023, 02:14 PM
                                        • Aditya11ttt
                                          On Board Ram Disable via Bios Editing
                                          by Aditya11ttt
                                          Post Hp | Dell | Asus | Lenovo
                                          on board Ram Bios we try to disable via bios edit.
                                          07-31-2022, 08:03 AM
