LA-L246P & kbc MEC1515-NM
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    It'll definitely work if sio is from same donor motherboard..Tested on LA-L243P
    • Varon23
      • May 2018
      • 19
      • Poland
      Available from Della and authorized sellers. You have to ask if it is clean or D0
      • pahahi
        • Aug 2017
        • 5
        • germany
        Hello, what is the procedure for uploading the service tag?
        • Varon23
          • May 2018
          • 19
          • Poland
          We introduce hand after starting the laptop
          • pahahi
            • Aug 2017
            • 5
            • germany
            Thanks Varon23,
            After replacing the MEC1515, the laptop will go into "Manufacturing mode Active"
            Problem is: Laptop does not save the Service Tag. After saving and restarting laptop the service tag remains empty, moreover the cooling fan is spinning at full capacity (bios problem?)
            Bios attached,
            TAG service:6QTYKG3
            model: Dell 7506 2 IN 1
              • 21145
              Originally posted by pahahi
              Thanks Varon23,
              Bios attached,
              TAG service:6QTYKG3
              Please post your bios request in the bios requests sub forum
              Laptop bios requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
              • DanielDacko
                • Mar 2015
                • 325
                • Macedonia
                #27
                Does anyone have info how to obtain the firmware for MEC1515-NB (Let's suppose programming is possible) and which size is it?
                I don't provide help for people using CH341A and a clip.
                  • 21145
                  Here`s some info from the MEC140x datasheet about a crisis recovery .
                    • 21145
                    MEC1515 KSO9 on PVT. What will happen if KSO9 is shorted to gnd at boot i don`t know.
                    • DanielDacko
                      • Mar 2015
                      • 325
                      • Macedonia
                      #30
                      So if I understand correctly, if the chip goes into crisis recovery, it should pull the firmware from the main bios? Although I'm not sure if 14XX have the same principle as 15XX, the datasheet for 1515 seems impossible to find.
                        • 21145
                        Forget what i posted .A blank chip wouldn`t boot without the boot ROM
                        • ferah831208
                          • Aug 2019
                          • 62
                          • Cuba
                          #32
                          And when u buy this chips in AliExpress they are always blank I think 😐😐, laptops with this chip are a big headache 😔
                          • Varon23
                            • May 2018
                            • 19
                            • Poland
                            #33
                            You also need to pay attention to the CPU.
                            I fixed one Dell. But at the second with the same defect, it turned out that after replacing MEC is still dead. CPU-Bridge was also damaged.​
                            • huzo
                              • Sep 2014
                              • 178
                              • CROATIA
                              #34
                              I had a board with burnt 1.8V power chip, i replaced it with SY8388RHC(Kdxxx marking ), and now i have the voltage all across the board , but MCE1515 is getting hot ,laptop dead, soemtimes orange light for charging goes on , so there is no repair? 20V probably went directly to him?
                              • ferah831208
                                • Aug 2019
                                • 62
                                • Cuba
                                #35
                                U need mec1515 from same donor board I never found the way to purchase the chip original from Dell 😔
                                • huzo
                                  • Sep 2014
                                  • 178
                                  • CROATIA
                                  #36
                                  Man they made it complicated....I see that the MEC1515 is also hard to replace...
                                  • f-bone
                                    • May 2013
                                    • 96
                                    • Greece
                                    #37
                                    hi guys any update on this IO regarding programming it? or a method/link to order from Dell?
                                    • cubytus
                                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                      by cubytus
                                      Hi to all,
                                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                      01-10-2024, 01:26 AM
                                    • otaku_nut
                                      Vizio E701i-A3 fixed but now has red vertical line
                                      by otaku_nut
                                      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                      08-19-2025, 06:11 PM
                                    • TrueSword88
                                      Kogan - KALED65XU9220STB - Blue Vertical Line
                                      by TrueSword88
                                      Hi all.
                                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                      Hoping to fix...
                                      05-05-2023, 04:28 PM
                                    • FALKLAN
                                      Running Line Voltage and Integrating LED Pods - Automotive
                                      by FALKLAN
                                      Howdy everyone! I hope all is well where ever you are!
                                      I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                      I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                      02-05-2025, 12:30 AM
                                    • mindoverflow
                                      ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                                      by mindoverflow
                                      hello,
                                      there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                                      I changed pads and thermal paste.
                                      I run mats test but it is reporting 0 errors.
                                      I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                                      After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                                      02-09-2022, 03:22 PM
