ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
  • mindoverflow
    • Feb 2022
    • algeria
    hello,
    there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
    I changed pads and thermal paste.
    I run mats test but it is reporting 0 errors.
    I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
    After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt state; int1 == 0x00800000.
    Error 000000000608 : Gpu.Initialize Interrupt request line stuck asserted"
    How can I solve this problem? do you have an idea about the origin of the first problem?
    Before the problem worsened here is how it was behaing:
    https://drive.google.com/file/d/1CoL...ew?usp=sharing
    Here is the latest mods.log file
    Code:
    MODS start: Tue Jan 25 21:33:00 2022
    Command Line : gputest.js -oqa -skip 154 -testarg 293 UseI2cReads true -testarg 171 SkipSerialNumCheck 1 -testarg 1 IgnoreRgbMcuFwCheck true -adc_cal_check_ignore
    CPU
    Foundry : GenuineIntel
    Name : Intel(R) Pentium(R) Gold G5500 CPU @ 3.80GHz
    Family : 6
    Model : 14
    Stepping : 11
    Version
    MODS : 400.271
    OperatingSystem: Linux (x86_64)
    Kernel : 4.17.4-gentoo
    KernelDriver : 3.87
    SBIOS Version : 2301
    SBIOS Date : 07/10/2020
    HostName : tinylinux
    GPU 0 [01:00.0] dev.sub 0.0
    DevInst : 0
    PCI Location : 0x00, 0x01, 0x00, 0x00
    GPU DID : 0x1f82
    PDI : 0x0cc46a5d6407a2ff
    Raw ECID : 0x015fd1c00000006dd7800991
    Raw ECID (GHS) : 0x1646dd7800800000007fe8280
    ECID : PRTU02-07_x-3_y10
    Device Id : TU117
    Revision : a1
    NV Base : 0xa3000000
    FB Base : 0x90000000
    IRQ : 11
    Error 000000000608 : Global.PrintGpuInitError Interrupt request line stuck asserted
    Error 000000000608 : Global.InitializeGpuTests Interrupt request line stuck asserted
    PexDevMgr not initialized. Bridge device shutdowns will likely do nothing.
    Error Code = 000000000608 (Interrupt request line stuck asserted)
    MODS end : Tue Jan 25 21:33:02 2022 [2.767 seconds (00:00:02.767 h:m:s)]
    Thank you.
  • BMCappelletti
    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
    by BMCappelletti
    Hi everyone.
    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
    02-18-2025, 12:22 PM
  • stormanimal83
    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
    by stormanimal83
    Hey....
    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can“t understand...
    01-18-2024, 02:15 PM
  • cubytus
    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
    by cubytus
    Hi to all,
    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
    01-10-2024, 01:26 AM
  • otaku_nut
    Vizio E701i-A3 fixed but now has red vertical line
    by otaku_nut
    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
    08-19-2025, 06:11 PM
  • TrueSword88
    Kogan - KALED65XU9220STB - Blue Vertical Line
    by TrueSword88
    Hi all.
    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
    The line just happens to coincide with the end of COF and start of the next COF (attached).
    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
    Hoping to fix...
    05-05-2023, 04:28 PM
