LA-L246P & kbc MEC1515-NM
  • rookieme
    • Oct 2014
    • 398
    • Greece
    Well at this board I had shorted 3V line and burned the 3V buck converter.
    I replaced the converter and the MEC1515-NB that was shorting the line.
    Now I get the 3V running but system is unable to power on.
    So this kbc need some programming? I wasn't able to find any info.
    Also it has a second internal line of pins that you can only assume that they have soldered ok.
  • TuanTongbadcaps
    • Mar 2023
    • 64
    • VietNam
    Re: LA-L246P & kbc MEC1515-NM
    MEC1515-NB does not currently have a programming solution for it, we had to skip a lot of boards with this error.
    • rookieme
      • Oct 2014
      • 398
      • Greece
      that's sad.
      Thank you for your reply.
      • RAR1991
        • Apr 2017
        • 25
        • Algérie
        Hi, did you find any solution ??? I have the same problem
        • memoslar
          • Apr 2015
          • 122
          • Greece
          Guys i replaced the MEC1515 and i have also same results. Its not powering on. Did you find any solution?
          • TuanTongbadcaps
            • Mar 2023
            • 64
            • VietNam
            Some vendors sell the chips New MEC1515-NB With the program 19829-1 19828-1 LA-L243P LA-L246P LA-L248P LA-K661P LA-L24FP LA-K512P you can find it on aliexpress
            • memoslar
              • Apr 2015
              • 122
              • Greece
              I have already bought from aliexpress with the appropriate program but still doesnt power up
              • memoslar
                • Apr 2015
                • 122
                • Greece
                The seller told me to refresh the bios chipset... is that the solution?
                • TuanTongbadcaps
                  • Mar 2023
                  • 64
                  • VietNam
                  I'm just wondering about BGA reballing, because I often make this mistake
                  • salvador17
                    • Dec 2019
                    • 5
                    • Panama
                    Hello, I have the same fault, replace MEC1515nb purchased on aliexpress, select program LA-L246P and the equipment only turns on the amber LED but does not turn on, ask if anyone knows how to program? the kbc
                    • mon2
                      • Dec 2019
                      • 14531
                      What is the full p/n of the original EC?
                      Is it MEC1515-NB or MEC1515-NM?
                      According to this YT video, no programming is required:
                      Dell LA-L241P MEC1515-NB IO controller replacement process (youtube.com)
                      Click image for larger version  Name:	comment.png Views:	0 Size:	39.9 KB ID:	3466100
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I dont believe the YT video from my own experience. This MEC1515 is programmable and as mentioned by@ tuan tong, there is no programming solution yet atleast in public domain.
                        The so called programmed chip from whatever source you buy will never work as they are all fake or not programmed with the target mb as claimed.
                        Only a MEC1515 from same/similar scrap mb works.
                        Thats what i've experienced so far. Thats why i fear repairing LA-241-43/46 etc series.
                        • mactouch
                          • Nov 2018
                          • 91
                          • abudhabi
                          Anyone have solution on this problem ? I changed MEC1515-NB but not working
                          MB : GDM50 LA-L246P
                          • Blackam8899
                            • Sep 2020
                            • 45
                            • Rosario
                            Hello, I also changed a MEC1515-NB from a Lenovo donor board to a Dell LA-L243P REV 1.0. ONLY WHEN PRESSING THE POWER BUTTON THE AMBER LIGHT COME ON AND THEN IT GOES OFF. It seems that there is no solution, simply changing it does not correct the problem. I have not yet tried changing the BIOS since this model has two
                            • Varon23
                              • May 2018
                              • 19
                              • Poland
                              Hi. I have the same problem. short circuit on 3v. damaged MEC1515-NB. Maybe buy a system with MFM ready to enter a service tag?
                              I have an SVOD4 and Vertyanov programmer.​
                              • deviljee
                                • 13
                                • phlippines
                                did you program it via svod 4?..
                                • Varon23
                                  • May 2018
                                  • 19
                                  • Poland
                                  Solution found.
                                  The MEC system must be purchased with software version D0. with the option of entering a Service Tag.
                                  Purchasing an empty system from Aliexpress will not help because the system is on an ARM core with EEPROM blocked by JTAG access. It can only be deleted.
                                  The only solution is to buy the system officially from DELL with an empty DMI. We solder and enter the service tag and the laptop works
                                  You only need to download the BIOS and read the ServiceTag because they often replace housings due to faulty hinges. If we enter the wrong Service Tag and it is not compatible with PCH, there will be a problem. Then replace the MEC with a new one or replace the bridge because it is not enough to reset the CMOS
                                  • zibik
                                    Just hobby
                                    • Sep 2023
                                    • 6
                                    • Polska
                                    Mozesz opisać skad bierzesz MEC1515?(Kocham Basię?})
                                    No i jak to dokładnie wyglada procedura po wluyowaniu kbc?
                                    English:
                                    Can you describe where you get MEC1515? (Kocham Basie?)
                                    So what exactly does the procedure look like after soldering the EC
                                    • Varon23
                                      • May 2018
                                      • 19
                                      • Poland
                                      From DELL. I love bass, as far as I know.
                                      I have one free deal. I bought two, one worked, the other didn't because the CPU was also damaged.​
                                      • ferah831208
                                        • Aug 2019
                                        • 65
                                        • Cuba
                                        Solution found.
                                        Do u have any link where u can buy this chio ready to attempt that procedure?? I have the same issues with mec 1404-nu I think 🤔 🤔, and I read a lot online and a thread from Vertyanov speaking about this specific chip, a blank chip doesn't work. But in that case supposedly if you use a chip from a donor board it will work. Now I have the same problem with a mec1515, bought a new one in AliExpress it didn't work, only amber light when I press power button, I don't believe bios solution will work because of signals measured in scope, and now I see your explanation and it's the more logical. In this case for what I understood even if I get a mec1515 from same motherboard model, I assume it will not work because of the dmi information verification?? 😔😔
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                        • otaku_nut
                                          Vizio E701i-A3 fixed but now has red vertical line
                                          by otaku_nut
                                          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                          08-19-2025, 06:11 PM
                                        • TrueSword88
                                          Kogan - KALED65XU9220STB - Blue Vertical Line
                                          by TrueSword88
                                          Hi all.
                                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                          Hoping to fix...
                                          05-05-2023, 04:28 PM
                                        • FALKLAN
                                          Running Line Voltage and Integrating LED Pods - Automotive
                                          by FALKLAN
                                          Howdy everyone! I hope all is well where ever you are!
                                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                          02-05-2025, 12:30 AM
                                        • mindoverflow
                                          ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                                          by mindoverflow
                                          hello,
                                          there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                                          I changed pads and thermal paste.
                                          I run mats test but it is reporting 0 errors.
                                          I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                                          After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                                          02-09-2022, 03:22 PM
