Hello, please share the dump on EDM-030 CFI-1208B 61G
playstation 5 digital firmware dump
please if anyone ever found the solution to SU-101217-2 error code, should please share.
note
-wifi mac address not showing
-wont connect or detect any network
-system software wont update.
i guess im going to try to reflow the wifi chip. i bought this console with a 3 beeps of death, i dont know if the wifi issues was there before or if was caused by nor chip getting corrupted. Its just weird that the same bin file that was corrupted and was causing 3bod its now working.
Anyway if anyone needs a bin file for a CFI-2016 B01Y (EDM-041) (it may have wifi issues)
Hello everyone, I'm looking for a dump for ps5 slim disc CFI-2016 EDM041. Because I tried with the dump recovered here, it starts very well but when I want to install the software from the safe mode option 7 and 8 it tells me an error because it can't make the cd player work even though it was installed but the original dump was already corrupted during the installation of the cd block. Do you have a solutionComment
Que tal? Por favor si alguien tiene el archivo bin de una ps5 edm033 cfi 1200A con disco en buen estado y me lo podría pasar, es para soluciona los 3 bip de la mia, muchas graciasComment
Hello Everyone,
I'm stuck with a CFI-2016A which has a license problem and doesn't register its disc drive (but it works 100% on another console).
PSN logs in 100%, I can download content but as soon as I try to run/play I get "Can't use this content" / "Can't connect to the server to verify your license. Wait a while, and then try again."
Of course, trying to restore license from the PS5 menu fails with error [CE] - [105628] - [2].
Trying to reinstall system from SAFE MODE (forced) with option "Reset PS5 (Reinstall System Software) ends up at 29% systematically with error [CE] - [120239] - [7]
I found a way to get it reinstalled with >>> SAFE MODE (forced) >>> [3.Repair Console Storage] or [4.Update System Software] >>> Reboot >>> asks for USB stick with necessary file >>> all goes well until arriving in PS5 menu where the console acts stable and well.
Only game that starts is Astro's Playground but ends up crashing every single time at the same location in game with error [CE] - [108255] [1].
I suspect NOR to be in cause as I don't know this console's past.
My suspicions might be correct as after dumping the NOR, here are some observations :- Latest version installed : 25.05-11.60.00.05
- PKG reported in NOR : PKG-3486
- MAC addresses fields are full of [FF]
- Model not present at 0x001C7230 (16 Bytes) : only a bunch of [FF]
- Plastic case S/N not present at 0x001C7210 (17 Bytes) : only a bunch of [FF]
- Strange string present at 0x001C7330 over 16 bytes : PS5GNPXXXXXXXXXX (where XXXXXXXXXX are numbers beginning with 3 zeroes // example : 0001234567)
Does somebody has a CFI-2016(A) NOR dump with southbridge CXD90069GG, WiFi module J20H104 and same version (25.05-11.60.00.05) and PKG-3486 ?
Thanks !
Exactly, I enter the console information in the new dump but I think I'm not putting it in the right place so it crashes like it's impossible to reset to zero or re-install the PS5 software it crashes at 29%Comment
by AhariHi all,
I...-
by Tamo NekoHello everyone,
I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
What Happened:
I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.- I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
- My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
- A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
1 Photo-
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by gun4asHello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
08-25-2025, 04:28 AM -
Hi, i have canon mf264 printer which is stuck in download firmware mode and I'm after a firmware memory dump for this model, so I can try to rewrite. Thanks for your kind help!07-22-2025, 04:48 AM
- Loading...
