HikVision DS-7104HQHI-K1 MB: DS-80303_P REV 2.0 Firmware dump or unlock required
  • jovani1989
    • Sep 2022
    • 22
    HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!
  • Mephysis
    DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
    by Mephysis
    Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
    I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
    03-27-2025, 02:34 AM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Andreas_de
    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
    by Andreas_de
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    04-12-2025, 10:38 AM
  • Tamo Neko
    Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
    by Tamo Neko
    I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
    What Happened:
    I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
    • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
    • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
    What I Need:
    • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
    02-12-2025, 11:29 PM
  • jorpec
    Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
    by jorpec
    Hi, all
    I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
    10-17-2025, 03:51 AM
