Troubleshooting Uni-T EEPROM ErrE
  • DanFen
    • Apr 2017
    • 201
    • Malta
    I've got a UT139C that powers on for a second with an ErrE, before switching itself back off.
    I haven't found much information about this, other then the error being caused by the EEPROM (both on the internet and from fellow members here). While I'm using a cheaper multimeter temporarily, I'm trying to troubleshoot this... hoping it won't go to trash
    I've opened it up and did a visual inspection. Unfortunately I couldn't see anything obvious, everything looks clean and as new. No signs of damaged components.
    I'm attaching two photos: one of the eeprom area, and the other I think are the rails on the back that end up to the eeprom (?). Also attaching datasheets.
    And because I'm doing this to learn, and I'm still new to this, I have a couple questions.
    1. What are the components starting with L? I know C are usually caps, while R are resistors, F fuses and so on.
    2. Laugh at me, but, where do you find ground on these 2 layer boards? On laptops it's easy cause these are usually screw holes/ports etc.... What am I missing?
    Thanks a lot
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: Troubleshooting Uni-T EEPROM ErrE
    Look here
    https://www.eevblog.com/forum/testge...matics-avail)/
      • 31140
      L are inductors.
      do you have an eeprom programmer?
      • DanFen
        • Apr 2017
        • 201
        • Malta
        Thanks, will go through it.
        Originally posted by lotas
        Hello again! Not yet, but on delivery. Went for the RT809F.
        Originally posted by stj
        L are inductors.
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Here are two original and modified firmwares for UT139C.
            • 31140
            backup the original first, it has calibration data in it
            • DanFen
              • Apr 2017
              • 201
              • Malta
              I know it's been a while, but I just got to do this now. Wrote the shared bin to the IC, re-soldered it back, and still getting the same error :/
              I also de-soldered the IC and read it again just to make sure that it got programmed correctly. Then compared it to the shared hex and they are the same... which concludes that the programming was fine.
              • redwire
                • 3912
                Post the EEPROM file you have, to see if it can be fixed.
                • DanFen
                  • Apr 2017
                  • 201
                  • Malta
                  This is the backup (the one I had before I wrote the shared one).
                    • 31140
                    check the tracks between the eeprom and the main chip.
                    here is a schematic of another meter with the same chipset,
                    and a datasheet with example schem on page 17
                    • DanFen
                      • Apr 2017
                      • 201
                      • Malta
                      Will try Is that done with the EEPROM back in circuit?
                      • redwire
                        • 3912
                        I looked at your EEPROM dump with a hex editor and did not see any errors. I can't know what every byte should be, but I did not see anything corrupt.
                        Check the EEPROM pullup resistors on SDA and SCL are OK, is R29 soldered on both sides? The main IC DTM0660 looks like solder balls are behind/under the pins?
                        • DanFen
                          • Apr 2017
                          • 201
                          • Malta
                          Thanks for checking!
                          All resistors seem to be soldered fine, but I'll re-flow them just in case. I also measured them and the readings are good.
                          About the solder balls, do you mean in between pins? If so, it doesn't seem like it under the microscope, and I didn't reflow it or touch it in any way.
                          I also tested in continuity between the DTM0660 and the EEPROM IC, in case there's a broken trace, but all seems fine.
                          • redwire
                            • 3912
                            No, the solder bridges I see are UNDER the pins.
                            You can poke a wire or paper clip (gently) through and see if you hit them. Usually they are solder balls from extra paste and can poke out.
                            • DanFen
                              • Apr 2017
                              • 201
                              • Malta
                              Doesn't seem to be the case, must be the quality of the previous photo
                              I'm still to re-flow the resistors around the EEPROM area.
                              • DanFen
                                • Apr 2017
                                • 201
                                • Malta
                                Reflowed the resistors, still the same. While it seems to be interesting, I don't think it's worth working on it anymore. The only thing I miss about this is that it has auto range, and the other ones I have do not.
                                  • 31140
                                  did you check the eeprom is getting power?
                                  • redwire
                                    • 3912
                                    For some reason EEPROM power has a R40 100Ω resistor to +V, and it's supposed to have a bypass cap 0.1uF across power and gnd but I don't see it.
                                    • CapLeaker
                                      Leaking Member
                                      • 8286
                                      Check with an oscilloscope the data line, clock and the main oscillator for activity.
                                      • junphil
                                        • Sep 2023
                                        • Philippines
                                        Please help....
                                        Does anyone here have the working and original firmware of ut139???
                                        • SidneyCanadas
                                          93C46 and 93C56 EEPROM
                                          by SidneyCanadas
                                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                          06-14-2023, 01:16 PM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • DrDos
                                          Unit runs but no speaker output kenwood KR-6030
                                          by DrDos
                                          I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                          09-14-2025, 09:57 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
