Troubleshooting Uni-T EEPROM ErrE
+ More Options
Posts
  • DanFen
    • Apr 2017
    • 201
    • Malta
    I've got a UT139C that powers on for a second with an ErrE, before switching itself back off.
    I haven't found much information about this, other then the error being caused by the EEPROM (both on the internet and from fellow members here). While I'm using a cheaper multimeter temporarily, I'm trying to troubleshoot this... hoping it won't go to trash
    I've opened it up and did a visual inspection. Unfortunately I couldn't see anything obvious, everything looks clean and as new. No signs of damaged components.
    I'm attaching two photos: one of the eeprom area, and the other I think are the rails on the back that end up to the eeprom (?). Also attaching datasheets.
    And because I'm doing this to learn, and I'm still new to this, I have a couple questions.
    1. What are the components starting with L? I know C are usually caps, while R are resistors, F fuses and so on.
    2. Laugh at me, but, where do you find ground on these 2 layer boards? On laptops it's easy cause these are usually screw holes/ports etc.... What am I missing?
    Thanks a lot
  • lotas
    • Jan 2016
    • 4549
    • Russia
    Re: Troubleshooting Uni-T EEPROM ErrE
    Look here
    https://www.eevblog.com/forum/testge...matics-avail)/
      • 30978
      L are inductors.
      do you have an eeprom programmer?
      • DanFen
        • Apr 2017
        • 201
        • Malta
        Thanks, will go through it.
        Originally posted by lotas
        Hello again! Not yet, but on delivery. Went for the RT809F.
        Originally posted by stj
        L are inductors.
        • lotas
          • Jan 2016
          • 4549
          • Russia
          Here are two original and modified firmwares for UT139C.
            • 30978
            backup the original first, it has calibration data in it
            • DanFen
              • Apr 2017
              • 201
              • Malta
              I know it's been a while, but I just got to do this now. Wrote the shared bin to the IC, re-soldered it back, and still getting the same error :/
              I also de-soldered the IC and read it again just to make sure that it got programmed correctly. Then compared it to the shared hex and they are the same... which concludes that the programming was fine.
              • redwire
                • 3906
                Post the EEPROM file you have, to see if it can be fixed.
                • DanFen
                  • Apr 2017
                  • 201
                  • Malta
                  This is the backup (the one I had before I wrote the shared one).
                    • 30978
                    check the tracks between the eeprom and the main chip.
                    here is a schematic of another meter with the same chipset,
                    and a datasheet with example schem on page 17
                    • DanFen
                      • Apr 2017
                      • 201
                      • Malta
                      Will try Is that done with the EEPROM back in circuit?
                      • redwire
                        • 3906
                        I looked at your EEPROM dump with a hex editor and did not see any errors. I can't know what every byte should be, but I did not see anything corrupt.
                        Check the EEPROM pullup resistors on SDA and SCL are OK, is R29 soldered on both sides? The main IC DTM0660 looks like solder balls are behind/under the pins?
                        • DanFen
                          • Apr 2017
                          • 201
                          • Malta
                          Thanks for checking!
                          All resistors seem to be soldered fine, but I'll re-flow them just in case. I also measured them and the readings are good.
                          About the solder balls, do you mean in between pins? If so, it doesn't seem like it under the microscope, and I didn't reflow it or touch it in any way.
                          I also tested in continuity between the DTM0660 and the EEPROM IC, in case there's a broken trace, but all seems fine.
                          • redwire
                            • 3906
                            No, the solder bridges I see are UNDER the pins.
                            You can poke a wire or paper clip (gently) through and see if you hit them. Usually they are solder balls from extra paste and can poke out.
                            • DanFen
                              • Apr 2017
                              • 201
                              • Malta
                              Doesn't seem to be the case, must be the quality of the previous photo
                              I'm still to re-flow the resistors around the EEPROM area.
                              • DanFen
                                • Apr 2017
                                • 201
                                • Malta
                                Reflowed the resistors, still the same. While it seems to be interesting, I don't think it's worth working on it anymore. The only thing I miss about this is that it has auto range, and the other ones I have do not.
                                  • 30978
                                  did you check the eeprom is getting power?
                                  • redwire
                                    • 3906
                                    For some reason EEPROM power has a R40 100Ω resistor to +V, and it's supposed to have a bypass cap 0.1uF across power and gnd but I don't see it.
                                    • CapLeaker
                                      Leaking Member
                                      • 8102
                                      Check with an oscilloscope the data line, clock and the main oscillator for activity.
                                      • junphil
                                        • Sep 2023
                                        • Philippines
                                        Please help....
                                        Does anyone here have the working and original firmware of ut139???
                                        • SidneyCanadas
                                          93C46 and 93C56 EEPROM
                                          by SidneyCanadas
                                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                          06-14-2023, 01:16 PM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • blues_spirit
                                          practical courses for troubleshooting pc motherboards
                                          by blues_spirit
                                          Hello from France,
                                          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                          Do you think this is feasible for me? I...
                                          12-18-2022, 12:56 PM
                                        • edgarmg15
                                          Damaged EEPROM on TV Vizio E320-A0
                                          by edgarmg15
                                          Hi everyone
                                          I´m trying to repair a TV Vizio E320-A0 that I found in the street
                                          The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                                          The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                                          So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                                          11-19-2022, 03:46 PM
