Speed controller for golf trolley
  • redriddick
    • 93
    • Ireland
    #41
    Re: Speed controller for golf trolley
    Where to start?
      https://www.badcaps.net/forum/attach...6&d=1548445387
      What are the P/N as printed on top of those two IC's?
      • R_J
        • 9633
        It looks like the one ic is a LM78L05 regulator and the other one could be a microchip 12C5xx pic ic
        • redriddick
          • 93
          • Ireland
          #44
          Will check them in a min
          • redriddick
            • 93
            • Ireland
            #45
            12c671 and 78L05A i think
            • R_J
              • 9633
              Have you checked to see if you have 5 volts coming out of the regulator ic?
              Where does the speed pot connect and where does the on/off switch connect?
              • redriddick
                • 93
                • Ireland
                #47
                The blue and red wire are where the pot and on off switch are connected.
                I will have 're solder the mosfets and relay before I can test for 5v
                • R_J
                  • 9633
                  The way it likely works is 12 volts is applied to the board from the battery, U3 supplies 5 volts to the pic processor. when the switch/pot is activated the pic outputs a pwm signal to Q4 & Q5 then to the output transistors (this is the variable speed signal) then the pic also turns on the relay connecting the transistor output to the motor, driving the motor at whetever the speed pot is set to. The relay is likely also used to provide dynamic braking for the motor
                  Q7 looks like the relay drive transistor, D3 is protection across the relay coil.
                  I believe that diode D1? (to220 dual diode?) is likely connected across the motor to protect the output transistors.
                    Post #17 also suggested to test the Voltages, but no data from OP.
                    • redriddick
                      • 93
                      • Ireland
                      #50
                      There is 5v to the pic
                      • master3112
                        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                        by master3112
                        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                        10-29-2024, 09:32 PM
                      • tomark
                        Golf trolley charger Model G60 A2A power supply schematic
                        by tomark
                        Hi everyone
                        I am just beginning, has anyone got Model G60 A2A power supply schematic.
                        It's for charging golf trolley, input 100-240V50/60 Hz 1.0A output 13.8 v 3.3A.
                        Please. If possible.
                        10-29-2023, 06:58 AM
                      • GardevoirForEver
                        Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                        by GardevoirForEver
                        I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                        Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                        The motherboard of my ASUS...
                        11-15-2025, 04:30 PM
                      • ronnygracias
                        Help with freemotion incline trainer with controller comm error
                        by ronnygracias
                        The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                        11-04-2024, 01:32 PM
                      • Wutru
                        HP Elitebook 820 G4 BIOS repair assistance required
                        by Wutru
                        Hi guys,
                        If someone would be able to provide some expertise, I'd be very grateful.
                        BIOS Corruption - Cause
                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                        09-06-2025, 10:32 AM
