Speed controller for golf trolley
  • redriddick
    • 93
    • Ireland
    #41
    Re: Speed controller for golf trolley
    Where to start?
      https://www.badcaps.net/forum/attach...6&d=1548445387
      What are the P/N as printed on top of those two IC's?
      • R_J
        • 9557
        It looks like the one ic is a LM78L05 regulator and the other one could be a microchip 12C5xx pic ic
        • redriddick
          • 93
          • Ireland
          #44
          Will check them in a min
          • redriddick
            • 93
            • Ireland
            #45
            12c671 and 78L05A i think
            • R_J
              • 9557
              Have you checked to see if you have 5 volts coming out of the regulator ic?
              Where does the speed pot connect and where does the on/off switch connect?
              • redriddick
                • 93
                • Ireland
                #47
                The blue and red wire are where the pot and on off switch are connected.
                I will have 're solder the mosfets and relay before I can test for 5v
                • R_J
                  • 9557
                  The way it likely works is 12 volts is applied to the board from the battery, U3 supplies 5 volts to the pic processor. when the switch/pot is activated the pic outputs a pwm signal to Q4 & Q5 then to the output transistors (this is the variable speed signal) then the pic also turns on the relay connecting the transistor output to the motor, driving the motor at whetever the speed pot is set to. The relay is likely also used to provide dynamic braking for the motor
                  Q7 looks like the relay drive transistor, D3 is protection across the relay coil.
                  I believe that diode D1? (to220 dual diode?) is likely connected across the motor to protect the output transistors.
                    Post #17 also suggested to test the Voltages, but no data from OP.
                    • redriddick
                      • 93
                      • Ireland
                      #50
                      There is 5v to the pic
                      • tomark
                        Golf trolley charger Model G60 A2A power supply schematic
                        by tomark
                        Hi everyone
                        I am just beginning, has anyone got Model G60 A2A power supply schematic.
                        It's for charging golf trolley, input 100-240V50/60 Hz 1.0A output 13.8 v 3.3A.
                        Please. If possible.
                        10-29-2023, 06:58 AM
                      • master3112
                        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                        by master3112
                        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                        10-29-2024, 09:32 PM
                      • ronnygracias
                        Help with freemotion incline trainer with controller comm error
                        by ronnygracias
                        The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                        11-04-2024, 01:32 PM
                        Tankless hot water heater controller board not powering up when power is applied
                        by sam_sam_sam
                        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                        However I would like to know if I could figure what happened to this controller board if possible
                        Tomorrow I will take some better pictures of both side of both boards
                        The...
                        12-09-2022, 09:14 PM
                        Modifing a Battery Spot Welder because of Controller Issues
                        by sam_sam_sam
                        I keep having the same exact issue with these battery spot welder controller boards
                        They either do one of two things
                        One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                        Or
                        The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                        This...
                        10-12-2019, 08:51 AM
