Help with freemotion incline trainer with controller comm error
  • ronnygracias
    • Sep 2022
    • 8
    The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power it on. It returned the same error. I tried replicating what I did, but it still shows the same error.
    The treadmill is a freemotion FMTK750090. The motor controller is a cc2050 by Delta and the power supply board is a PBCL_UNI_50W by icon. Anyone knows what I could check.
    The cc2050 has 6 x 820 farad capacitors that read 730-735 farad.
    Any guidance on this would be greatly appreciated.
    • Jul 2011
    • 6070
    “has 6 x 820 farad capacitors that read 730-735 farad.”
    This is a little bit low but it depends on where it is in the circuit if this is a problem or not
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Mouse piss does quite a number on circuit boards... I would clean these boards in a ultrasonic cleaner then see what the mouse piss damaged. Its corrosive and eats everything. Been there,, done that, got the ticket and the shirt!
      • ronnygracias
        • Sep 2022
        • 8
        The 6 capacitors are on the bottom side of the motor controllers.
        • ronnygracias
          • Sep 2022
          • 8
          On it, I'll keep you'll posted and see if this fixes it.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            I had to write off a whole vhf crystallized receiver because of it. Mouse pissed exactly in the tuning holes in the case. After a while the receiver quit. Looked inside and it damaged traces, damaged through holes, ate legs etc. It is as bad as a leaking capacitor. So remember where the mouse piss was, clean it with water and dawn dish soap, flowed by a pure alcohol bath and dry it off. I like the ultrasonic, as it gets into everything.
            • wzamoyski
              Treadmill controller (zipro dream (?)) - PCB-ZYXK9- 1111-V1.2.PCB not working
              by wzamoyski
              Hello
              I received a treadmill controller (probably Zipro Dream) for repair (more like replacing parts). Board designation: PCB-ZYXK9-1111-V1.2.PCB. existing in it were:
              • mosfet Q9 (originally MDF4N60 was installed) - mounted on P10NK60ZFP;
              • resistor R64 (replaced);
              • F2 protection.
              After turning on the power of AC1 and AC2, the components burned again. The existing elements were desoldered and new ones were soldered. The controller has not been connected yet because I'm afraid they would be destroyed again.
              There are no additional restrictions that can be applied,...
              02-26-2025, 02:29 AM
            • master3112
              ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
              by master3112
              I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
              When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
              10-29-2024, 09:32 PM
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
              Tankless hot water heater controller board not powering up when power is applied
              I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
              I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
              However I would like to know if I could figure what happened to this controller board if possible
              Tomorrow I will take some better pictures of both side of both boards
              The...
              12-09-2022, 09:14 PM
              Modifing a Battery Spot Welder because of Controller Issues
              I keep having the same exact issue with these battery spot welder controller boards
              They either do one of two things
              One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
              Or
              The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
              This...
              10-12-2019, 08:51 AM
