Like New Nautilus Exercise Bike has Dead Panel
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #81
    Re: Like New Nautilus Exercise Bike has Dead Panel
    This is what i use for testing
    https://www.ebay.co.uk/itm/DC-6-40V-...72.m2749.l2649
    • vestaviascott
      • Aug 2018
      • 100
      The input has to be a DC source?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #83
        yes i use a old laptop charger for output voltages under 19v i have a old 30vdc printer psu for voltages over 19v
          For now you can try using two NEW AA batteries connected in series to give around 3V to see if you will get any action on main board.
          • R_J
            • Jun 2012
            • 9535
            You could also try two 1.5 volt AA or AAA batteries in series, most people have them around. or maybe even a CR2025 3 volt cell might have enough current to check the circuit
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8112
              Originally posted by R_J
              AZ1117CH-3.3TRG1 Marking GH16D this should be a 3.3 volt regulator
              Pin one should be connected to ground which would be that checker board pattered trace
              You could remove the regulator and supply 3 volts to the output trace from a power supply or 3v battery and see if it powers up, likely if you have 7 volts there now, other parts down the line could be damaged.
              AZ1117CH-3.3TRG1 = GH16D
              The H in xxx7CH means H package. Sez so in the datasheet.
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                #87
                Originally posted by vestaviascott
                0.7v on pin 1
                7.2v (middle pin - Vout) * I measured this several times b/c I was expecting 5v (turns out it should actually be 3.3v)
                8.7v (right pin - Vin)
                Trace (visually) where the output goes. If it supplies power to any "chips", chances are, they are also toast as you've supplied 7.2V to their power pins (usually not able to withstand more than 10% over). If in doubt, you can look up the datasheets on those components (ax voltage on power pin), as well.
                I.e., don't waste your time fixing the regulator if that's just going to tell you that everything downstream is toast.
                You can also try removing the regulator and probing the signal on the PCB in its absence. I.e., has something else imposed 7.2V on its output or was it the sole source? (replacing the regulator in the case of some other superimposed signal will just toast the new regulator in an ohnosecond).
                • vestaviascott
                  • Aug 2018
                  • 100
                  Here is the closeup shot of the chip and its surrounding trace pattern:
                  The output pin (middle) does not appear to be connected to anything from this view. Do I have to remove the board and turn it over to see where this center pin leads?
                  And here is the full hi resolution shot:
                    BTW:
                    1) I see another 5-PIN regulator IC RGP1 close to UP1, UP2 IC's.
                    2) Can I also see the pictures of the whole back side of the board.
                    3) Check the resistance between the big solder pad of RG1 and the positive (marked with bar) pin of cap C20.
                    • vestaviascott
                      • Aug 2018
                      • 100
                      Originally posted by budm
                      BTW:
                      Ah, I see that now. Thanks. I'll run voltage tests on that one in the am.
                      Will do.
                      OK, will do.
                        See if you can get spec sheet of that regulator.
                        BTW, Did you remove RG1 from the board already? If you did, check the resistance both way between input pin and the output pin to see what you have on that RG1.
                        • vestaviascott
                          • Aug 2018
                          • 100
                          Will do. P/N is IR50
                          • vestaviascott
                            • Aug 2018
                            • 100
                            Have not. Have to get a soldering iron or bring it to a buddy who has one (and knows how to use it, lol)
                              That is all it has printed on the top, IR50?
                                You can go ahead and check the resistance with it in place for now, I ma just curious as to what it will show resistance wise.
                                It will be a lot easier to remove the IC if you cut the two small legs first, the to remove the big tab you will add flux and more solder to it. You will need 45W iron with wide tip because that cooper plane will suck the heat from your solder tip if you use low Wattage iron.
                                • vestaviascott
                                  • Aug 2018
                                  • 100
                                  Closeup shot is below. There is what appears to be a vertical bar or line, followed by "R50" so "|R50"
                                  • vestaviascott
                                    • Aug 2018
                                    • 100
                                    That pin on C20 is almost too tiny to hit, but when I can, I'm getting 0.6 to 0.7 ohms resistance.
                                    • vestaviascott
                                      • Aug 2018
                                      • 100
                                      BTW:
                                      Left and right pins measure 8.8v, middle pin measures 0.7v
                                      Question:
                                      These pins are SUPER small and VERY close to one another, if I happen to accidentally bridge two pins with my test lead while measuring voltage, does that likely fry/short the component?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #99
                                        Question:
                                        do the top two pins read any voltage? and yes shorting pins can cause damage so just be careful if you can see where the trace from the pin goes too you can measure on the end of say a resistor or capacitor the side closest to the pin you want too measure saves shorting too the next pin by accident
                                        • vestaviascott
                                          • Aug 2018
                                          • 100
                                          Yes, one pin measures 1.2v, the other 4.99v
                                          • KYBOSH
                                            Samsung UN50TU8000 - Dead Panel Forensic Questions
                                            by KYBOSH
                                            I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                            When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                            When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                            Later I checked for shorts on the panel PCB boards but could not find anything.
                                            When I took a look with the FLIR i noticed the 2 resistors...
                                            08-10-2024, 08:39 AM
                                          • NSkyLab
                                            Vizio D43f-J04 is panel dead?
                                            by NSkyLab
                                            TV Model: Vizio D43f-J04
                                            Main Board: TPD.MT5583.PB751 (60103-00876)
                                            T-Con: BOE_CC430LV2D_43001 V1.0
                                            Panel: BOEI430WU1
                                            The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
                                            This is a dumpster find, don't know if it was hit, there are no visible cracks...
                                            I though there may be something wrong with the panel voltages.
                                            Those I managed to find on the T-Con board. Does it seem normal?
                                            12V: 12.27v
                                            VCC33: 3.28v
                                            1.2V: 1.25v
                                            VGL: -5.87v
                                            AVDD: 16v
                                            HAVDD: 7.47v
                                            VCOM: 7.0v...
                                            01-29-2023, 08:18 PM
                                          • howardc64
                                            LG 49UJ6500 LCD panel lighter band that goes away
                                            by howardc64
                                            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                            02-19-2023, 12:13 AM
                                          • triplefour
                                            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                            by triplefour
                                            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                            tcon is built into mainboard.
                                            Only one cable goes to panel boards.
                                            there is a cable from one panel board to the other that links them.
                                            cost cutting measure that results in us having harder time to diagnose.
                                            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                            07-28-2022, 07:59 PM
                                          • Storyteller12
                                            QN55Q60R Service Menu Panel Help
                                            by Storyteller12
                                            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                            01-13-2024, 01:57 PM
