Like New Nautilus Exercise Bike has Dead Panel
  • vestaviascott
    • Aug 2018
    • 100
    Re: Like New Nautilus Exercise Bike has Dead Panel
    yes. Basically there are different voltage rails for different IC's to work. So, you got some thing like: 5V, 3.3V, 2.5V and 1.8V.
    1st pin is power input, 2nd pin is GND and the 3rd pin is power output.
    OK, I'm going to hook it back up, plug the adapter in and take the readings for each of the ICs and report back.
    BTW, do those P/Ns look right? Curious what they tell you.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      [QUOTE=vestaviascott;848289]Awesome. Here are the P/N's:
      RG1 = 3940M3 501434L
      RG2 = GH16D 4266J2
      https://cdn.badcaps-static.com/pdfs/...27ae2b3e9b.pdf
      RGA1 = 3940M3 501434L
      see RG1
      • vestaviascott
        • Aug 2018
        • 100
        For RG1, voltages are from left to right:
        .8 (left pin)
        7.2 (middle pin)
        8.72 (right pin)
        For RG2, voltages are from bottom to top:
        8.93 (bottom pin)
        .2 (middle pin)
        4.98 (top pin)
        For RGA1, voltages are from left to right:
        8.9 (left pin)
        .6 (middle pin)
        4.99 (right pin)
        • vestaviascott
          • Aug 2018
          • 100
          Interesting, as I was testing the connections at a couple random times, I heard a couple long tone beeps (just like I would expect to hear when the panel fires up). I can't be certain if they were coming from the DMM or the bike. I glanced over at the panel and saw no signs of life so its likely it was something else beeping near me. The DMM was on the DV voltage switch (not beep mode) so I don't know how it could have come from there.
          • vestaviascott
            • Aug 2018
            • 100
            1st pin is power input, 2nd pin is GND or ADJ and the 3rd pin is power output.
            So, aside from the consistant 5V reading, my voltages are way different than it appears you are expecting:
            .8 (left pin)
            7.2 (middle pin)
            8.72 (right pin)
            8.93 (bottom pin)
            .2 (middle pin)
            4.98 (top pin)
            8.9 (left pin)
            .6 (middle pin)
            4.99 (right pin)
            What does this tell you or what should it tell me? If these are acceptable voltages what's the next step to isolate the problem?
            • vestaviascott
              • Aug 2018
              • 100
              I suppose when comparing RG1 and RGA1, since they are the same P/N, I should expect similar voltage readings? That would lead me to think that RG1 may be defective. Its output voltage (assuming its the right pin) 8.72 reading is above the expected 5V output I'm seeing on the reference doc PDF.
              • vestaviascott
                • Aug 2018
                • 100
                Some additional notes on the Voltage measurements:
                Originally posted by vestaviascott
                For RG1 (3940M3), voltages are from left to right:
                .8 (left pin = Vin)
                7.2 (middle pin = GND)
                8.72 (right pin = Vout)
                For RG2 (GH16D), voltages are from bottom to top:
                8.93 (bottom pin)
                .2 (middle pin)
                4.98 (top pin)
                For RGA1 (3940M3), voltages are from left to right:
                8.9 (left pin = Vin)
                .6 (middle pin = GND)
                4.99 (right pin = Vout)
                • vestaviascott
                  • Aug 2018
                  • 100
                  Updated readings as of this morning:
                  For RG1 (GH16D), voltages are from left to right:
                  0.7 (left pin - GND)
                  7.2 (middle pin - Vout) * I measured this several times b/c I was expecting 5 V
                  8.7 (top pin - Vin)
                  For RG2 (3940M3), voltages are from bottom to top:
                  8.9 (bottom pin = Vin)
                  0.1 (middle pin = GND)
                  [/quote]
                  So, for RG1 and RGA1, the voltages appear normal and expected, correct?
                  So, from the chart, assuming this is the 5v version, I'm guessing since this bike calls for a 9 Volt power supply, the pin readings should be:
                  Pin 1 (input): No more than 16 volts (expect appx 9 volts due to 9 volt power supply adapter)
                  Pin 2 (Ground): appx 0 volts
                  Pin 3 (output): 5 volts
                  • vestaviascott
                    • Aug 2018
                    • 100
                    So, based on my readings, is it correct to conclude that the RG1 voltage regulator is leaking voltage to the board and is likely cause of the failure? Expecting 5v, Actual observed is 7.2
                    8.7 (top pin - Vin)
                    • vestaviascott
                      • Aug 2018
                      • 100
                      Originally posted by Curious.George
                      Yes, but what likely role would a switch THERE serve in such a device? (Goal is to have OP think about why "it" would care about whether the power adapter was mechanically attached -- or not!)
                      Since gray wire is coming from the speed sensor AND the power supply, perhaps the switch in this case is to automatically allow the console to "sleep" when there is no activity (measured by the speed sensor) for a period of time.
                      Then, when the user gets back on the bike and engages the pedals, triggers the speed sensor (gray wire lead) and the console switches on.
                      I'm guessing on that obviously, but that's my experience with exercise equipment is that they typically have a sleep mode for inactivity and in this case it needs some means to "wake" which the speed sensor could obviously inform.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8327
                        8.7 (top pin - Vin)
                        Well... Now I don't know what regulator is which since you switched RG1 and 2 around with the part numbers. The GH16D LDO should have 3.3V output and you have something like 0.8V the rest goes to GND. The input voltage is sagging a bit due to this. So this LDO is bad. Does this regulator get a bit warm?
                        • vestaviascott
                          • Aug 2018
                          • 100
                          Well... Now I don't know what regulator is which since you switched RG1 and 2 around with the part numbers. The GH16D LDO should have 3.3V output. So this LDO is bad. Does this regulator get a bit warm?
                          Sorry about that, the post #51 IS CORRECT. in my original post I misidentified RG1 and RG2 (I'm used to linear numbering from left to right and these are out of sequence on the board which I lazily got backwards in my original post ID'ng the chips).
                          To clarify, RG1 is at the top of the board and is the lone GH16D chip. RG2 and RGA1 are both 3940M3 chips.
                          I'll check RG2 to see if it gets hot. Based on the observed voltages, is it possible that this could be the sole cause of the dead panel?
                          Can RG2 be replaced on the board?
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8327
                            Depending on your soldering skills, yes RG2 can be replaced. As for me, I'd have no problem changing that (I do have a hot air rework station). It could be the cause for the dead panel, yes. Could be also that there is more broken. However, fix that what you know is broken first. In this case a new GH16D LDO.
                            Here: https://www.digikey.ca/products/en?keywords=AZ1117C
                            they have over 20.000 in stock. You need the 3.3V one.
                            • vestaviascott
                              • Aug 2018
                              • 100
                              ...The GH16D LDO should have 3.3V output and you have something like 0.8V the rest goes to GND.
                              The readings in Post #51 are accurate. Please disregard all prior readings:
                              8.7 (right pin - Vin)
                              Yes, after about a minute of the device being plugged in, this regulator is extremely hot compared to the others.
                              • vestaviascott
                                • Aug 2018
                                • 100
                                Thanks! So, this one, correct?
                                https://www.digikey.ca/product-detai...ICT-ND/4505206
                                • vestaviascott
                                  • Aug 2018
                                  • 100
                                  OK, can you let me know how I should know whether its 3.3v or not? I was thinking 5volt.
                                  I'm going to go ahead and order backups for the two 3940M3 chips while I'm at it - I'm already paying $4 bucks for shipping. What voltage are those?
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8327
                                    Yes, this is correct you need the 3.3V one, GH16D tells you that. I figured that this regulator should get a bit warm... lol. Replace it! Again the 0.7V on that regulator is the output voltage, not GND! Middle pin is GND! It is just that the regulator is bad and dumps the input voltage to GND.
                                    You need a lot of heat (a good soldering iron or hot air) flux and solder to get this regulator of the PCB.
                                    The other 2 regulators are 5V
                                    • vestaviascott
                                      • Aug 2018
                                      • 100
                                      Thanks. I'll be having these soldered on by a friend who can do it. I'll practice on lesser projects.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8327
                                        Let us know the outcome!
                                        • vestaviascott
                                          • Aug 2018
                                          • 100
                                          I was just going by this chart in the PDF that was referenced. In these shots, ground is pin 1 left, am I mis-reading? Just trying to learn as I go:
                                          • KYBOSH
                                            Samsung UN50TU8000 - Dead Panel Forensic Questions
                                            by KYBOSH
                                            I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                            When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                            When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                            Later I checked for shorts on the panel PCB boards but could not find anything.
                                            When I took a look with the FLIR i noticed the 2 resistors...
                                            08-10-2024, 08:39 AM
                                          • NSkyLab
                                            Vizio D43f-J04 is panel dead?
                                            by NSkyLab
                                            TV Model: Vizio D43f-J04
                                            Main Board: TPD.MT5583.PB751 (60103-00876)
                                            T-Con: BOE_CC430LV2D_43001 V1.0
                                            Panel: BOEI430WU1
                                            The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
                                            This is a dumpster find, don't know if it was hit, there are no visible cracks...
                                            I though there may be something wrong with the panel voltages.
                                            Those I managed to find on the T-Con board. Does it seem normal?
                                            12V: 12.27v
                                            VCC33: 3.28v
                                            1.2V: 1.25v
                                            VGL: -5.87v
                                            AVDD: 16v
                                            HAVDD: 7.47v
                                            VCOM: 7.0v...
                                            01-29-2023, 08:18 PM
                                          • howardc64
                                            LG 49UJ6500 LCD panel lighter band that goes away
                                            by howardc64
                                            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                            02-19-2023, 12:13 AM
                                          • triplefour
                                            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                            by triplefour
                                            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                            tcon is built into mainboard.
                                            Only one cable goes to panel boards.
                                            there is a cable from one panel board to the other that links them.
                                            cost cutting measure that results in us having harder time to diagnose.
                                            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                            07-28-2022, 07:59 PM
                                          • Storyteller12
                                            QN55Q60R Service Menu Panel Help
                                            by Storyteller12
                                            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                            01-13-2024, 01:57 PM
