PS4 SMD HDMI Resistor and Diode (Where can I buy)
  • Bafury
    • Jul 2012
    • 55
    I'm trying to find out where i can purchase the two components highlighted in yellow. Or at least the value. thank you in advanced
  • ngth82
    • Jul 2015
    • 541
    Re: PS4 SMD HDMI Resistor and Diode (Where can I buy)
    What model # PS4 is this picture from? I have several of the parts in inventory.
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
      • 31247
      can you upload any pictures please - they dont show on secure browsers if you link them.
      • Snapman
        • Sep 2018
        • 9
        Best bet would be ebay. Something like this.
        https://www.ebay.com/itm/HDMI-Port-S...item2f1db3598d
        • petehall347
          • Jan 2015
          • 4440
          . is the diode a tvs diode ? dont see a resistor marking
          • budwich
            ESD Diode on HDMI output of Yamaha a1050 RCVR
            by budwich
            I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
            I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
            09-11-2023, 12:21 PM
          • SuperAman
            PS5 HDMI port diode reading?
            by SuperAman
            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
            02-03-2024, 10:16 PM
          • XxMicroSoldering
            Lost Diode/Resistor RP802 MacBook Pro 2020 A2338 HELP
            by XxMicroSoldering
            Hello Guys. Yesterday I was repairing a MacBook with no backlight. I noticed the resistor/diode RP802 is bad so I took it off. I also had a faulty motherboard that can't be repaired that had that resistor/diode on it (RP802). So it took the good RP802 off the faulty board. And when I had it on my tweezers it accidentally flew away. And now I don't know what to do. I 100% can't find it because of how small it is. Do you guys know any other diode/resistor that can work as the RP802
            I'm a newbie to microsoldering and I'm still learning. All help is really appreciated
            10-06-2022, 12:41 AM
          • spleenharvester
            Ugreen HDMI splitter missing a pulldown resistor
            by spleenharvester
            Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
            I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
            (Not that this is worth the hassle for an...
            09-15-2025, 11:23 AM
          • irepair559
            Ps4 1215a hdmi diode readings good everything good but no pic??
            by irepair559
            PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
            01-05-2023, 12:32 AM
