ESD Diode on HDMI output of Yamaha a1050 RCVR
  • budwich
    • Jul 2015
    • 3097
    I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
    I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the link indicates "audio only". This would seem to indicate that perhaps the main hdmi transmitter chip is functioning "OK". I am thinking that perhaps the ESD diode pack on the data pair is "leaking" to ground causing a load on the pair. The ESD diode package is ESD7004mutag. I was wondering IF I remove the package (ie. de-solder... might still be tough to get that thing off without damage somewhere), is it safe to operate the unit temporarily for test purposes to see if it is indeed the issue. I haven't been successful in testing it in circuit as the component pads are very small and getting good probe contacts is difficult. Having said that, I am not sure that I see much / any difference between the pair in question and others (packages or the adjacent pair in the package)... but I am not sure that I am testing it correctly as it appears that it might be some form of zener maybe if I understand the spec.
    Any guidance on this? Thanks
    I guess the other question is checking to see if there is something happening on the pair. I have a little single channel hand held scope. Looking at the each individual pin of the pair to ground just shows the dc value. How is this tested to at least just see some "data waggle" to if anything is actually happening? My scope might not have enough bandwidth at 100mhz.... :-(
    Again thanks for any hints.
  • budwich
    • Jul 2015
    • 3097
    Re: ESD Diode on HDMI output of Yamaha a1050 RCVR
    Well, I lifted the esd diode pack for the data0 and data1 pairs (in the same pack). No joy as the impedance to ground is still low (~6K) for either of the bad lines versus high mohm for the good lines. The only thing between the hdmi pins and the transmitter chip (256 pin) is some smd inductor pairs. I lifted the one involved. No change. It appears that the drivers involved in the data1 pair have an issue at the chip. I am not risking replacing the chip as one output is better than none... :-)
    • SuperAman
      PS5 HDMI port diode reading?
      by SuperAman
      I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
      02-03-2024, 10:16 PM
    • debidoobs
      Yamaha delay D1500, zener diode broken with no marking
      by debidoobs
      im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
      Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
      04-24-2024, 09:01 AM
    • irepair559
      Ps4 1215a hdmi diode readings good everything good but no pic??
      by irepair559
      PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
      01-05-2023, 12:32 AM
    • minniedt
      Yamaha cx-a3040 no hdmi signal
      by minniedt
      Hi all badcaps member,
      I have a Yamaha cx-a3040 which does not detect hdmi input as well as outputting video to the tv, other functions seem to work fine, it can play music if inputting using rca or optical. I'm suspecting the issue is on the digital pcb.
      Self diagnostic info display the below
      C1-1
      All:—
      C1-2
      BUS_FROM:—
      C1-3
      BUS_FPGA:—
      C1-4
      I2C:—- - -
      C1-5
      FPGA_RAM:—
      S4-12
      FPGA-G-V.—-
      S4-13
      FPGA-S-V.—-
      S4-14...
      12-06-2023, 07:21 AM
    • aliougm
      Marantz SR4003 AVR HDMI board issue, seeking for help
      by aliougm
      I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
      Connection as below:
      Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
      If I bypassed AVR then HDTV screen color be good.
      I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
      3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
      I replaced all...
      04-30-2022, 12:21 PM
