I am in need of a replacement crystal filter for this set, 7.8mhz not sure if these are repairable as it seems the set is passing both side bands and carrier through the filter. The problem is intermittent, I have addressed the bad soldering around the input and output pins which immediately helped with the problem (well the heating did) but after a few hours am back to the same intermittent failure.
Belcom LS120l radio (crystal filter)
Re: Belcom LS120l radio (crystal filter)
Opps I'm sorry I got this into the wrong forum, could some one please move it to
Troubleshooting Game Consoles & Other Weird Devices please, There wont be any electrolytic s in there, maybe some ceramics in there though, casing appears sealed though. Will have to scope it, annoyingly it seems to be working at the moment.Comment
Just a crystal in it... or a bunch of crystals. Yeah unfortunately you'll need to locate an identical unit or substitute, there should be no electrolytics in it.
Likely one of the wires or plating fell off a crystal, and getting it back on would be tough...Comment
From my understanding of the lattice crystal filters, they are made up from a series of crystals strung together, each one sealed along with the housing itself sealed with solder. The amount of thermal mass and heating required to disassemble the outer casing will probably cause more damage. I think I have located several candidate crystals rather than attempt to repair this one.Comment
Yeah probably difficult to open, especially if it's crimped and soldered together. I wonder how much of a loss it would be if you replaced it with an RC filter, alas the Q is going to suck.
Getting a pile of 7.8MHz crystals will be tough too, I wonder why they don't make them anymore? I feel for you, this is worse than my crystal problem for my 2m radio...
I need to really figure out SSB someday...that modulation technique doesn't quite make sense, well, specifically, to encode and decode via analog. The SSB concept easy to understand; implementation, that's a whole another ball of yarn...
I have no SSB tuners/transmitters...Comment
get yourself one . had fun with mine in the 1980.s . covered large distances at low power no problem ..was like being local . i was using directional antennas though . no way to move easily so was stuck with same contacts for months . worked best at night for long distance . local was 24hr . cant remember mhz now about 38 mostly rings a bell .Yeah probably difficult to open, especially if it's crimped and soldered together. I wonder how much of a loss it would be if you replaced it with an RC filter, alas the Q is going to suck.
Eh, nah, not going to buy one. Has to be "MAKE" or "MAKE INTO"
So theoretically I can hack one of my CB radios to the 10m band (of which I have the schematics to!), add on an SSB frontend/decoder ... hmm!
And I suppose using a CB radio is QRP as it is ...
Alas I want to figure out how to get onto 2m band without buying a radio first. I do have an old 2m radio but not the right crystals to communicate with a repeater. Task #1 is to get this to work...
Then I'll have acquired the knowledge to reliably generate/receive the 10m frequencies needed to hack the CB radio - the radio I'm thinking about hacking is also using crystals. 10m should be around 28-30MHz I'd guess as 11m is 27MHz CB.
Step by step, incremental abilities! (then again, still haven't gotten my license yet, and antennas will be a problem...)Comment
i used 3 19ft dipoles in tandem style in the attic .. parallel . like a large beam type thing .. had to make sure nothing interesting on tv as neighbours were not happy otherwise . just had to key up and watch his front window to see if he was shaking his fists .. was a cb radio with lots of channels .fm am too . thinking back there was too much going on in a small space to consider interfering with tv.s etc .Comment
Ideally it wouldn't affect others TV, shouldn't even be within frequency range of VHF/UHF TV! Alas yes, HOAs and antennas is sadness. Need to build so-called stealth antennas, I do have a fence I can play with, as long as the fence stays dry...Comment
The problem as I understood it was not related to the VHF / UHF frequencies used for broadcast television but rather one of the IF stages / frequencies used within your stock consumer television. These included IFs of 38.9 MHz vision, 33.4 MHz sound applied to Systems B, C and F. System E used 38.9 MHz vision, 27.75 MHz the latter of which being right in the middle of the CB / free radio allocations for 11 meter.Comment
filter here ..https://www.ebay.co.uk/itm/Uniden-7-...YAAOSwI-BWIQ7PComment
Thanks Pete, that was one of the candidate filters I located, the other being a US vendor who wanted 40$ just to put the thing in a jiffi bag and ship it. Well I have ordered the https://www.ebay.co.uk/itm/Uniden-7-...YAAOSwI-BWIQ7P and hoping it fits the pcb and more importantly works lol.
will keep you updatedComment
by shelby5041hi
ive got a modern digital clock radio approx 15yrs old
my question is how long can a clock radio or a simple radio last ss farcas operating hours?
since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
it uses very little power just a few watts i would imagine that may have something... -
by UserXPDear all,
I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
My question is, do you know of this brand of capacitors and how bad are...-
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....09-12-2024, 02:00 PM
by OmronHello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
- Tried to unplug radio and plug it back in into power,
- Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
- Tried to hold 3,6 while turning it back on and then pressing 1,2...-
- Loading...
