Original Xbox Replacement Caps
    • 31298
    Re: Original Xbox Replacement Caps
    no, the total esr would be too high
    • jayjr1105
      • 281
      The ESR goes down as capacitance goes up though. So three 3300uf caps might have an ESR of .018 each and two 4700uf caps would be around .015 ESR each. Does that make sense? Am I misunderstanding ESR across multiple capacitors?
      Ryzen 3600x
      16GB Patriot 3600MHz
      MSI B450 Gaming Plus
      MSI Air Boost Vega 56
      Acer 32" 1440P Freesync
      Rosewill Capstone 750W
      Hakko FX-888D Station
      FX-8802 Iron
      MG Chem .8mm 63/37 RA 2.2%
        master hoarder
        • May 2008
        • 12175
        #143
        Originally posted by jayjr1105
        Any harm in using fewer caps around the CPU? The XBOX either has five 1500uf caps or three 3300uf caps. Could you simply populate two 4700uf caps on the left and right most sides?
        It depends.
        If the caps are in parallel, then... MAYBE
        I say "maybe" because of ESR.
        For a number of _identical_ caps in parallel, the total equivalent ESR/impedance in the circuit, Z, will be:
        Z = (ESR of 1 capacitor) / number of identical capacitors in parallel
        So with the example of the three 3300 uF caps with ESR of 0.018 and two 4700 uF caps with ESR of 0.015
        Z (of 3x3300 uF caps) = 0.018 / 3 = 0.006 mOhms
        Z (of 2x4700 uF caps) = 0.015 / 2 = 0.0075 mOhms
        So as you can see, the ESR of the two 4700 uF caps is higher than the three 3300 uF caps.
        Now, would 0.0015 mOhms of difference in ESR matter in this circuit?
        - Probably not. The two ESR values above are still within 25% of each other, so that's not too radical of a change. Most circuits can work OK with that difference, if designed properly. Usually, it takes a lot more deviation from the standard values to break the circuit function (10-fold is typical, hence why some devices can still work, even when their caps have already started failing.)
        But generally, you want to match ESR to be the same or better, and then if possible match the capacitance too. If you had to sacrifice a bit of capacitance to get the right ESR, that's OK. But of course, don't go too far away from the original capacitance too. Again, I'd say try to stay within 25% of original.
        The direct links to imgur are still there for the inline pictures.
        Ah.
        Maybe because I haven't cleaned my history/cache in a while, so they probably finally all pre-loaded.
        • jayjr1105
          • 281
          Originally posted by momaka
          It depends.
          Z (of 2x4700 uF caps) = 0.015 / 3 = 0.0075 mOhms
          Ah.
          Thanks for that explanation. I'll keep that math in mind. BTW I think you meant 0.015 / 2 = 0.0075 but your math was still correct and valid. But yes, these would be a cluster of caps in parallel.
          Ryzen 3600x
          FX-8802 Iron
            master hoarder
            • May 2008
            • 12175
            #145
            Ah... yeah.... that would be my copypasta.
            Thanks for catching that! Fixed it now.
            In that case, likely OK to use them.
            • jayjr1105
              • 281
              I assume the original Rubycon MBZ's are also good to leave alone if not bulging?
              Ryzen 3600x
              FX-8802 Iron
                • 31298
                i have seen in a lot of xboxes and never seen a rubycon MBZ in one - maybe they are replacements.
                if MBZ's fail you will usually see it - so probably o.k.
                • jayjr1105
                  • 281
                  99% sure they are original. Solder joints on the bottom are too good to be done by hand. This is a 1.6 board btw.
                  Ryzen 3600x
                  FX-8802 Iron
                    • 31298
                    could be original then - 1.6 had a number of updates relating to the caps.
                      master hoarder
                      • May 2008
                      • 12175
                      #150
                      Yeah, MBZ is pretty stable.
                      MCZ and MFZ, on the other hand, can be a bit more unstable - usually when placed in hot spots. But those two are newer series, so you won't see them on the original Xbox. The Xbox 360 used MFZ and MCZ quite often, though. I've seen a few failures (again, mostly related to being overheated), but they are very reliable otherwise.
                      • jayjr1105
                        • 281
                        Kudo's to Microsoft overall. Really the XBOX had one consistently bad capacitor in the Nichicon HM. In all the XBOX's I've refurbed, I've never seen anything else really bad other than those Nichicon's. Even the power supply's with Teapo's, Ltec, Samxon, and Taicon. I've recapped a lot of power supply's just because but none of those 2nd tier caps were ever out of spec. This all aside from the supercap obviously.
                        Ryzen 3600x
                        FX-8802 Iron
                          master hoarder
                          • May 2008
                          • 12175
                          #152
                          Nichicon had a manufacturing flaw/problem between 2001 and 2004 with the HM, HN, and HZ series. In 2005, they got most of that squared away - at least with the 16V and higher voltage -rated caps. Really 2006 (caps with date codes H06xx) and forward is when they got things under control with those series.
                          As far as the 2nd tier caps... I don't know, I still feel uneasy about leaving them in a device that I don't want to come back for repair again. Teapo and Ltec, in particular, seem to do poorly over time. I think it's the fact that the original Xbox PSU runs rather cool and doesn't stress the caps a whole lot is why we don't see those caps fail there as much. Once they get stressed a little more and/or are placed in a hotter environment, then they start to get a lot more problematic. Case in point with many of the post-2005 OEM ATX PSUs, when PC power consumption on the CPU alone jumped from a mere 30-50 Watts from the Pentium 3 / Athlon era to 60-100+ Watts in the Pentium 4 era. PSU design also matters, of course. But between two identical PSUs - one with Japanese caps and another with 2nd tier caps - the PSU with the Japanese caps would not have problems with cap failures. So it's clear that 2nd tier caps aren't quite on par with the good Japanese brands, even when datasheets suggest nearly identical specs and performance.
                          • jayjr1105
                            • 281
                            Pulled out three more Nichicon HM's on someone else's machine. All bloated and reading really high like 9700uf again (each). ESR is still 0.01 which is crazy since these were bulging.
                            I measured the voltage around the CPU in an empty capacitor spot and it's 1.7v. Why did they spec 6.3v caps when 4 or 2.5 would have sufficed?
                            Ryzen 3600x
                            FX-8802 Iron
                              • 31298
                              because 6.3v was as low as you can go on large electrolytics, only polymers and small smd fo down to 4v or 2.5v
                              and the ripple handling will drop like a stone on smd electrolytics.
                              • jayjr1105
                                • 281
                                There are 4v 2700uf polys with excellent ripple handling. Three of those and you'd be golden
                                Ryzen 3600x
                                FX-8802 Iron
                                  • 31298
                                  yes, but we arent talking about poly's now - we are talking about std caps
                                  • jayjr1105
                                    • 281
                                    2700uf 4v poly's are almost $2 a piece. Pass. I'll stick with my Rubycon ZLQ/ZLH and Nichicon UHV for the CPU replacement caps.
                                    Ryzen 3600x
                                    FX-8802 Iron
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #158
                                      Yup, that's why MS didn't fit this board with polymers. They're just more expensive - especially even more so back in the day. Not only that, but the circuit doesn't really need capacitors with that kind of spec. After all, the original Xbox is nothing more than a Pentium 3 CPU with a GeForce 3 GPU. Neither of those can be considered as "power hungry", and hence they don't really need a beefy VRM or beefy caps to filter power. So that's why on a lot of older stuff, you can get away with regular low-ESR caps.
                                        • 31298
                                        your forgetting the age of the xbox.
                                        they couldnt fit polymers even if they wanted to.
                                        • jayjr1105
                                          • 281
                                          Saved another 1.6 from pissing Nichicons
                                          Ryzen 3600x
                                          FX-8802 Iron
