PS3 Fat RLOD reflow and now overheating message
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: PS3 Fat RLOD reflow and now overheating message
    Originally posted by Agent24
    A bit OT, but you know, I've never even thought about there being TIM between IHS and the die... is that true on all CPUs? I guess it must be... and how long before it degrades and needs replacing?
    Been getting word from the internetz that Intel was using solder for the Sandy Bridge processors and that Intel decided to go a more lax route with the Ivy Bridge processors.
    Possibly the same with Haswell.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      I've not dabbled in desktops for a good few years, but IME, most of the high-end C2D chips had the die soldered to the IHS. On the smaller, lower-performing ones however (particularly E2xxx series), there was thermal paste between IHS and die, and the IHS could be removed by using a sharp blade. I removed the IHS from an E2180 back in the day. Rumor has it it's the same with Ivy Bridge and Haswell too.
      A working TV? How boring!
      • Agent24
        I see dead caps
        • Oct 2007
        • 5095
        • New Zealand
        Looks like Phenom II CPUs are soldered as well (http://forums.guru3d.com/showthread.php?t=294013)
        That makes me happy, since that's what I run. So there should be no TIM to degrade\dry out.
        -David VanHorn
        • magneh
          • Apr 2014
          • 628
          • Portugal
          I'm back!
          Well, started to figure how to get that CPU IHS out of there without damaging anything...
          And after searching what I had at home, decided to go with ... a fishing line !
          A good quality one, and ... it worked !
          Just placed it on the corners and started working it arround like a chainsaw.
          It starts slowly cutting the edges ... and even slower on the middle ...but it's safe and some minutes will do it!
          Some pics are attached ... on the first one, we cant see it well, but its just two tools with the fishing line attached to permit to work it arround the IHS without hurting our hands
          Now some cleaning, some good paste ... and ready to test!
          I'll post back results!
          Hope these results can help anyone with this problem!
          Cheers
          • senndogg
            • Dec 2011
            • 383
            • Albania
            cool! i will adopt your method for my next ones. the chip looks really intact, with a modified blade there always were scuffs and cuts.
            • magneh
              • Apr 2014
              • 628
              • Portugal
              #26
              Well, applied new Thermal Paste, assembled it just for testing, and
              it turned without problems for about half an hour!
              Now I see the way to close this console!
              Gonna assemble it completly tomorrow and fire it up for a couple of hours and confirm that the repair is good.
              Thanks to all who gave the precious inputs!
              • Agent24
                I see dead caps
                • Oct 2007
                • 5095
                • New Zealand
                #27
                Good job, I learned some things too
                -David VanHorn
                • senndogg
                  • Dec 2011
                  • 383
                  • Albania
                  #28
                  Glad to help, dont forget to put the ac socket first before assembling.
                  • rumpumpel1
                    T490 error message 2203 Skip acknowledgement of an error message
                    by rumpumpel1
                    I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
                    This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
                    Is it possible to change the BIOS so that this message no longer has to be acknowledged?
                    MTM 20N3S19L00
                    system SN PF1X4JP8
                    board SN L1HF171000X...
                    01-19-2025, 03:32 PM
                  • Olvin1
                    Acer nitro 5 an517-52 reflow/rebal CPU
                    by Olvin1
                    I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
                    I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
                    • A detailed temperature profile for reflowing this specific CPU
                    • Step-by-step guidance for a safe and effective reflow process
                    • Tips on what to watch out for during the procedure
                    If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
                    08-01-2025, 01:59 PM
                  • tony359
                    Reflow equipment
                    by tony359
                    Hello all,
                    I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                    I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                    Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                    12-25-2021, 01:29 PM
                  • Ven
                    Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                    by Ven
                    Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                    Issue Description:
                    1. CPU Overheating to 100°C
                      • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                      • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                      • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                      • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                      • Thermal
                    02-12-2025, 03:57 PM
                  • Prabuth
                    always showing this message AC adapter = Unknown
                    by Prabuth
                    The customer gave me this for changing the old battery, and then I replaced the new battery. always showing this message. I changed many chargers and programmed the new BIOS as well. Does someone have any idea for this message?
                    08-28-2025, 01:26 AM
