hawaiian breeze fan
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: hawaiian breeze fan
    If it's anything like this electronic air cleaner I fixed-
    Five leads from the motor, one for each speed plus common to neutral.
    Those are triacs on that board, one for each speed.
    This appears to be doing the same as that EAC, right down to the confused micro.
    In my case, the resonator checked out, the caps in the 'power supply' were replaced, even another 5V supply was substituted. Never got anything other than a fan twitch. The lights would pulse brightly during the twitch, then stay dim for 20 seconds. There was an LCD that never displayed anything. It had its own chip and got data from the micro.
    I ripped all that junk out and put in a rotary switch for the fan, and two toggle switches- one for main power and the other for the ionizer. I think someone 'charged up' after removing/replacing the collection cell and 'discharged' into the circuit board when using the control panel.
    Ah, yes. One of those cheap capacitive voltage divider supplies. See my diagram.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • Agent24
      I see dead caps
      • Oct 2007
      • 5016
      • New Zealand
      #42
      I bet they didn't even need to use a microcontroller, probably the only reason they do is so they can write code which randomly erases itself, forcing you to buy another one.
      -David VanHorn
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        #43
        I put the new resonator in, it still doing the same thing.
        Oh well I tried.
        Question:... Can LED in series cause this kind of problem?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5016
          • New Zealand
          #44
          Could use it for parts... those micro button switches are useful, here Jaycar charges $2.50 each..
          -David VanHorn
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Get rid of the controller and mod it for switches.
            Mann-Made Global Warming.
            - Dr Seuss
            • b700029
              Banned
              • Sep 2010
              • 640
              #46
              Or if you're feeling adventurous, program a PIC or AVR to replace the existing micro, and then you can get the fan to do things it originally didn't --- all those LEDs could make for a nice lightshow
              • Agent24
                I see dead caps
                • Oct 2007
                • 5016
                • New Zealand
                #47
                Hey that's a good idea.. yeah you should do that! Shouldn't be too hard...
                -David VanHorn
                • xyzzy
                  • Jul 2011
                  #48
                  Maybe too late to help this case, but I recently fixed a similar problem on a Honeywell HFY-045-THA Tower fan. The 5v rail is derived the same way through a 1.0μF X2 uTx brand direct from the hot lead through a dropper to a 5.1v zener. Selecting 'ON' would briefly blip the fan, then nothing.
                  Turned out the derived supply was not "stiff" - the load of driving a couple of triacs and led indicator collapsed the supply and caused the MPU to reset. This happened fast enough, the LCD display remained blank.
                  The culprit was the X2 cap - no external signs of stress, but the nominal value had dropped to ~0.17μF. Enough for a sniff of 5v, but not under load.
                  I'm curious about the failure mode - no leakage under test, no external signs. Maybe the endplate bonding failed partially to the layers? Its potted, so further examination difficult. The circuit drags current thru as short pulses on the crest of negative going cycles, maybe not what an X2 expects...
                  Cheers
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #49
                    Nah, the answer is that they simply cheaped out on the cap and it didn't have a high enough current rating. I've even seen those caps cracked in half in those cheap flashlights that recharge from the mains using a similar scheme.
                    A working TV? How boring!
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      #50
                      does your 5v stay steady?
                      would not be the first time i have seen that cap die in a setup like that.
                      as for the flashlight a neighbor has one from the 50's made like that.a cap,string of diodes for the drop,and a sealed lead acid cell.crude but effective.adding 1 diode gave just enough to charge 2 aa nimh.no cheap zeners back then i guess.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #51
                        program it to tap out "i am a pile of shit" in morse when it is running?
                        • Toasty
                          • Jul 2007
                          • 4171
                          #52
                          veritas odium parit
                          • juergenb
                            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                            by juergenb
                            i am asking for some Help.
                            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                            The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                            So i got a few of these from Banggood.
                            I swapped the motor and now i have a new fault condition.
                            In a working Frother you would press the start button, it will light red and work for a few minutes.
                            If you press longer it will light blue and just mixup the milk.
                            With the new Motor it just starts...
                            03-23-2021, 11:24 AM
                          • sbt123
                            charnwood w821 mini wood lathe motor problem
                            by sbt123
                            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                            10-27-2024, 03:43 AM
                          • mikey5791
                            Help identify this motor
                            by mikey5791
                            Hi all forum members,
                            Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                            Correct me if i am wrong on the initial test.
                            Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                            11-24-2023, 07:54 PM
                          • Per Hansson
                            Motor run capacitor physical size vs voltage rating & measurements?
                            by Per Hansson
                            (TL;DR skip the first paragraph)
                            I encountered my first dead motor run capacitor at a customer this week.
                            For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                            (Unless a servo motor makes more sense that is).
                            But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                            The pump would run but sometimes trip the 10A breaker.
                            I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                            Then it could...
                            09-20-2020, 06:32 AM
                          • peter99
                            HP 245 laptop not charging when turned on
                            by peter99
                            helo everry body!!!
                            My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
                            - If not power on, battery charge ok.
                            - if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
                            The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
                            I replaced the BQ 25A charging IC but the device only charges when not turned on.
                            everyone please help me with solution, what should i do ?
                            thanks a lot !!!!!...
                            04-04-2025, 07:35 AM
