hawaiian breeze fan
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: hawaiian breeze fan
    Originally posted by Toasty
    Sonix, actually. SN8P2602B
    A 95 page manual: https://cdn.badcaps-static.com/pdfs/...90923eb075.pdf
    Doubt that it's knackered, though. If it is, it's trashed as it's a factory programmed chip.
    Motor(s) or controller transistors make more sense.
    I tested each transistor and they tested ok, as in get a reading on pins 2-3 before going open. There is 4 of them, one for each mode *low, medium, high* then SW which might be on/off or oscillation mode for the unit.
    I think it's not getting a good filtered ripple from the supply voltage, but my inexperience and naivety shows.
    • Toasty
      • Jul 2007
      • 4171
      If you measure across pin 5 (-) to pin 14(+) you should see about 5v. Check that. Careful not to short to neighboring pins.
      Your picture:
      lower left pin (with white mark) is Pin1
      upper left is Pin 18
      If the 5v is missing, then it's likely the Zener (as Krankshaft implied), or one of the two diodes. Circuit draws very little current to run IC and _probably_ runs through that 2w, 20Ω resistor. Check that also for value.
      If that all checks out, then maybe the crystal died. XTAL1 - blue object right above IC
      Toast
      veritas odium parit
      • Krankshaft
        • Jan 2007
        • 2328
        Based on the video it looks like the micro is going wacky. As Toasty posted above check the supply voltage and the ceramic resonator.
        To answer your question about the cap near the motor if it has one it's a capacitor start induction motor.
        Most desk and stand fans use a poly type cap (a few uf) as a start cap.
        It creates a phase shift which allows the motor to start spinning and gives the motor more starting torque to overcome the inertia of getting the blades moving. If the cap was bad the motor would hum and you'd need to rotate the shaft to get it started.
        Some fans use a shaded pole induction motor which doesn't require a start cap but they have less starting torque.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I suggested the transistors earlier but I apparently did suggest strongly enough.
          Point to looking at the IC is to figure out it makes the transistors do.
          A or some bad transistors would look the same as a bad controller IC.
          There are only 4 transistors, just check them one by one.
          Mann-Made Global Warming.
          - Dr Seuss
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            afaik they are gone.brookstone should be next to die.
            generic cheap junk differing only in name from the walmart and flea market stuff with a 10x markup.
            as far as zener regulators they are still common in cheap junk electronics because nothing is cheaper.
            Originally posted by Krankshaft
            I thought Sharper Image went bankrupt are they still in business? Always overpriced junk in any case.
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              #26
              Your picture:
              Toast
              Set my DMM to 20VDC and used the PDF to guide me, went four legs down and placed black probe on the next leg, went one down from the right and placed probe on next leg,
              No Volts!
              Checked twice to make sure I was on the correct pins and making contact.
              Also saw 0.01 to 0.03 volts pulsing with led and motor.
              But the funny thing is I get 5 volts at the big lytic cap, just after the zener.
              • Toasty
                • Jul 2007
                • 4171
                #27
                Pins (looking at your picture)
                Code:
                18 17 16 15 14 13 12 11 10
                 1 2 3 4 5 6 7 8 9
                5 = (-)
                14 = (+)
                Your description of what you tested doesn't match for Pin 14 (+).
                The 2 pins are right across from each other.
                veritas odium parit
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  #28
                  Code:
                   1 2 3 4 5 6 7 8 9
                  5 = (-)
                  14 = (+)
                  Oops... What the... I don't know why I was thinking of pin 8, my mistake guess I wasn't fully awake.
                  I measured pin 5 and pin 14 got the 5 volts, going to check 20ohm resistor I assume it's that big grey thing, and diodes look fine on meter with diode setting.
                  EDIT: 20 ohm resistor removed from circuit, check out at 25ohms Diodes check out at .69 each, zener out of range of my meter.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    If the supply voltage is fine check the transistors for the speed settings if they check out that would only leave a faulty crystal or a bad micro.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      Since you are getting 5v across the chip, I think the power is fine.
                      So, as others have indicated the chip is scrambled or the resonator/crystal is bad.
                      FWIW: Try unplugging the unit and holding down each button one at a time and then plugging it back in. Maybe something of a reset for the chip. Try 2 buttons.
                      LOL Krank beat me to the post
                      veritas odium parit
                      • Mad_Professor
                        A Mech Warrior
                        • Feb 2011
                        • 1587
                        #31
                        To do this I assume 200ohm setting on the DMM then do
                        leg 1 to 2
                        leg 1 to 3
                        leg 2 to 3
                        Do I need to take them out of circuit?
                        I didn't think of that, So I tried it, mashed buttons and then plugged it in and hope it worked, but it didn't.
                        Well since we can't replace the micro then let's replace the resonator/crystal and hope it fixes the problem.
                        The resonator is 4.00MG
                        Looking this up on google I get ZTT or ZTA series made by ECS
                        Since ZTT is a three leaded resonator, the ZTA is what I think I want and digikey has them in stock.
                        But some experienced input is requested.
                        • bluto
                          • Oct 2007
                          • 560
                          #32
                          Try the X911-ND (4 MHz - 2 pin). I had similar issues with my range hood (https://www.badcaps.net/forum/showth...?t=8654&page=2) and a new resonator fixed it. For fifty cents, what do you have to lose? After all, isn't the mantra something like "the silicon parts rarely go bad"? Hopefully that it the case for your fan's brain as well.
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            To test the transistors use the diode check function it's much more reliable than the resistance function. Go from base to collector you should only get a reading one way a voltage drop of around 0.700 volts on the meter if you don't get a reading flip the probes.
                            If you don't get a reading the transistor is open if you get 0.00 in either probe orientation then it's shorted. Do the same from base to emitter.
                            The resonator is your last hope if the transistors are fine. Without a scope or frequency counter to verify if the clock signal is stable you'll just have to shotgun it.
                            • brethin
                              • Dec 2008
                              • 1907
                              Typical China made shit, just throw it away, I see these for sale for like $15, if time was money you have already spent more than that trying to fix it.
                              • Mad_Professor
                                A Mech Warrior
                                • Feb 2011
                                • 1587
                                #35
                                yeah but it's fifty cent part combined with 2$ for USPS that's $2.50, I would have saved myself $12.50 that's nearly my hourly wage for moving 2500 packages an hour.
                                Plus I enjoy fixing stuff, and since I am learning electronic repair on my spare time, I've learned alot just from working on this fan.
                                Anyways transistors look ok, not the .700 you suggested but since they are matching transistors with nearly identical results.
                                T1 *Grey wire === .453
                                T2 *Orange wire== .471
                                T3 *Red wire ==== .447
                                T4 *Black wire === .502
                                Time to shotgun it?
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  So your time is worth nothing? Because you clearly have spent at least 4 hours working on it and at your nearly hour wage of $12.50 that is $50.
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    Captain Ahab....
                                    "He tasks me, and I shall have him!"
                                    veritas odium parit
                                    • smason
                                      • 1652
                                      So what? This is Badcaps. We fix stuff. Stuff not normally worth fixing. It's what we do. Because we can.
                                      My time is worth lots, but if I enjoy doing it, and learn from it, I'll waste 2 hours fixing a 15" LCD monitor that I'll end up donating for free.
                                      • Mad_Professor
                                        A Mech Warrior
                                        • Feb 2011
                                        • 1587
                                        #39
                                        YES.
                                        Time is constant
                                        Currency on the other hand is a human concept.
                                        The concept of time equals money is false due to the fact that currency is not constant or consistent with time.
                                        Your notion of "time is worth nothing to me" is therefore true.
                                        If that doesn't get your goat, then you have no soul.
                                        Anyways,
                                        I could work my whole life away and contribute to rising empire that's China, buying stuff to replace stuff every year while I watch America go down the drain.
                                        Look at it this way, that's $47.50 that I could use to pay bills, buy food or gas, and save instead of buying another piece of shit fan made in china that will die in few years and end up in a landfill somewhere.
                                        The fact is I get to experience stuff that most people wouldn't even bother doing or learn how something works.
                                        I appreciate your suggestion and I will take it under advisement.
                                        If there was thumbs up or a reputation system I would dump all my points into that post.
                                        That's how I feel, I'm doing this because I enjoy it, and I want to learn something.
                                        Now to contribute to my thread:
                                        Going to buy that resonator and see if it works or not, I'm confident that resonator is the problem.
                                        If not, I got a box fan with a dead motor but it has a four speed switch, and only because I can.
                                        • kc8adu
                                          • Nov 2003
                                          • 8832
                                          • U.S.A!
                                          #40
                                          pull it and scrape the leads.i found a bunch of those cheap resonators over the years where the plating let go.like the ctc140 rectifier sip board.
                                          you could pull it out leaving the plating in the board.
                                          as for whether its worth it to fix something that was trash when shipped i look at it as free education.you may or may not apply what you learned on a paying job in the future but it was a free learning experience.and if it does not live you can toss it where it was designed to go anyway.its the only reason i even look at this stuff.i specialise in fixing irreplaceable industrial stuff.never the same job!
                                          • juergenb
                                            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                            by juergenb
                                            i am asking for some Help.
                                            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                            The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                            So i got a few of these from Banggood.
                                            I swapped the motor and now i have a new fault condition.
                                            In a working Frother you would press the start button, it will light red and work for a few minutes.
                                            If you press longer it will light blue and just mixup the milk.
                                            With the new Motor it just starts...
                                            03-23-2021, 11:24 AM
                                          • sbt123
                                            charnwood w821 mini wood lathe motor problem
                                            by sbt123
                                            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                            10-27-2024, 03:43 AM
                                          • d00m178
                                            Philips toothbrush 4100 (HX369BK) - motor getting hot
                                            by d00m178
                                            trying to fix Philips toothbrush 4100 (HX369BK)
                                            The battery started draining quickly.
                                            After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
                                            The motor is connected to contacts M1 and M2.
                                            When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
                                            But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
                                            The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
                                            (To...
                                            11-12-2025, 03:11 PM
                                          • mikey5791
                                            Help identify this motor
                                            by mikey5791
                                            Hi all forum members,
                                            Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                            Correct me if i am wrong on the initial test.
                                            Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                            11-24-2023, 07:54 PM
                                          • Per Hansson
                                            Motor run capacitor physical size vs voltage rating & measurements?
                                            by Per Hansson
                                            (TL;DR skip the first paragraph)
                                            I encountered my first dead motor run capacitor at a customer this week.
                                            For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                            (Unless a servo motor makes more sense that is).
                                            But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                            The pump would run but sometimes trip the 10A breaker.
                                            I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                            Then it could...
                                            09-20-2020, 06:32 AM
