Asrock K7S8X R3.0
  • 0laf
    • Oct 2007
    • 11
    Asrock K7S8X R3.0
    Hi all
    my first post here
    found this in my brothers computer,
    the mainboard is still working fine in spite of the 5 open caps.
    all big brown KZG 3300uF caps still seem to be fine.
    well the smaller taicon 1000uF caps are
    I guess taicon is a rather bad company?
    I will try to replace them, would Yageo caps be o.k. for that? (looks like its rather difficult to get something different in europe)
    Btw: would be a temperature controlled (150-450°C) soldering iron enough for that or do i need more equipment?
    Thanks for helping me & sry for my bad english
    olaf
  • kikkoman
    • Jul 2007
    • 691
    Re: Asrock K7S8X R3.0
    Depends on the specs of those Yageos. Do you have any other info on those?
    Re the soldering iron: if it has at least 30W, it's fine. Make sure you have enough solder, it's much easier if you use LOTS of it.
    btw, it's not impossible to get decent parts in Europe...where exactly do you live?
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • 0laf
      • Oct 2007
      • 11
      1000uF 6.3V, 10 mm x 12 mm, max. temperature: 150°C, durability: 2000-5000h, esr: 0.08
      i m living in austria
      Thanks in advance
      • kikkoman
        • Jul 2007
        • 691
        Just checked on Yageo and found out that they own Teapo.
        ewwwwww...... wouldn't trust these in a mainboard, probably they are identical to the Teapos, as they use the same series numbers.
        I sent you a PM about availability in Austria.
        • gonzo0815
          • Feb 2006
          • 1600
          those Yeago / Teapo would probably work, but not much longer then those Taicon.
          So if kikkoman can`t suit your needs, there is www.rs-components.at, which probably can (ok, 20€ min order ...).
          I would suggest some decent Panasonic FM`s or Samxon.
          • linuxguru
            • Apr 2005
            • 1564
            Check out your PSU. The odds are pretty good that the 3.3v rail (and maybe other rails too) has failed caps on it, which in turn contributed to the failure of the Taicons (which are known bad caps) on the mobo.
            • gonzo0815
              • Feb 2006
              • 1600
              Failure of Taicons on this particular board (or better the series of K7S8 boards) is inevitable.
              Sure checking the PSu never hurts with this current sucking board (only 5v powered), but even the best would not influence the well being of this shit caps in this particular bad design (hot temperature due to linear voltage regulator).
              • 0laf
                • Oct 2007
                • 11
                thx for the replies,
                i ll gonna check the caps on the psu aswell
                • 0laf
                  • Oct 2007
                  • 11
                  another question: there are some more TAICON caps on the ASrock board that still look ok.
                  should i replace them aswell?
                  thanks for your help
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    I would fix it once, thus replace all of Taicon caps.
                    • Super Nade
                      • Jun 2006
                      • 294
                      That board is a joke. 2 Phase VRM? I would replace ALL the Taicons. Sure, replacing the dead ones alone will get the baord up and running, but eventually you will have to replace the other Taicons as well..
                      Q6700 @ 3.6 GHz
                      Zippy GSM-6600P
                      Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                      Abit IP35Pro
                      ATi HD4870
                      • tvtech
                        • Oct 2006
                        • 48
                        Originally posted by kikkoman
                        Just checked on Yageo and found out that th ey own Teapo.
                        I wouldn't trust yageos on anything,I remember finding 5 of them bulging on an older amd board from around mid 2000.Other than that I havent seen them on any newer boards
                        • pippolippi
                          • Sep 2006
                          • 15
                          Hello, I posted here a while ago (time flies) due to a single capacitor failing on the same board.
                          It has been working since then, it still works but all the taicon are swollen and it needs a reset to completely boot (but then it works fine).
                          I need to replace 12 capacitors, I found these on ebay but they smell as fakes, however the seller has 100% positive reviews.
                          What do you think, fakes or not?
                          • docbrown
                            • Dec 2006
                            • 8
                            Hello pippolippi
                            I bought those caps (and some 3300uF panasonic FJ) to recap an epox 8rda+ mainboard. They dont look like fakes to me.
                            The board is working fine without problems now.
                            • pippolippi
                              • Sep 2006
                              • 15
                              Thank you, anyway that's the point: the fakes usually don't look like fakes, and in HK are specialized in faking anything.
                              Sometimes I don't mind (e.g. if I'm buying a memory stick for the psp I'm not expecting to receive a genuine one, especially if the fake works as well as the original for a third of the price) but in this case I wouldn't want to have to recap again in a few months.
                              • Wizard
                                • Mar 2008
                                • 2296
                                Bzzt.
                                You are funding the shady people who leads to mafias/crimal organizations with these fakes. Best thing is vote with your pocket and buy geniune and third-party quality parts stuff, not the fakes.
                                This is the major reasons major brands crack down on fakes while honest third party did their proper design and had to pay licensing fee to the makers to use in their stuff.
                                Fakers do not pay the license and doesn't test completely with expensive tools to conform to standards and quality, reliability. And many of the fakes were programmed to show larger capacity than actual size.
                                Cheers, Wizard
                                • ironbot
                                  • Dec 2008
                                  • 8
                                  i have a Asrock K7S8XE+/A/ASR. a had recent crashes BOD, i replaced the caps on it about a year ago after the same problems and things where ok. until now. the only caps i could get hold of are .. jamicon 16v 1000uf, the first time i replaced them with the direct same ( 6.3v 1000uf ). could any-one advise me if the jamicons will be ok? with the extra voltage, thank you
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    not sure on the brand, but the voltage only means the max. voltage the cap can take. using higher volt caps should be ok- its the value (uf) that you dont want change
                                    if its all you can get, go for it, but id try to get ones of a better brand ("jamicon" sounds kinda fishy brand-wise)
                                    good luck
                                    Larry the teenage computer surgeon
                                    sigpic
                                    (Insert witty quote here)
                                    • Scenic
                                      o.O
                                      • Sep 2007
                                      • 2642
                                      jamicon is crap IMHO..
                                      seen lots of them in really cheap DVD players...
                                      bulging or open of course..
                                      edit: i don't even know if they produce low-esr caps...!?
                                      most i've seen were GP caps..
                                      • ironbot
                                        • Dec 2008
                                        • 8
                                        thank you Scenic and ratdude747, i will try and source better ones. as long as the uf is ok. i was realy worried about the voltage. again thank you both.
                                        • Exim
                                          ASRock N100M, no picture no boot, but semi-alive
                                          by Exim
                                          Hi guys,
                                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                          ASRock N100M special features:
                                          - CPU soldered to board, small Intel 12th gen
                                          - iGPU
                                          - four POST LEDs
                                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                          Symptoms:
                                          - no picture/signal on any of the display connectors,...
                                          04-01-2025, 02:36 PM
                                        • MasterCap
                                          What IC does AsRock usually use to make the PWM signals for GPU fans ?
                                          by MasterCap
                                          I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
                                          Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
                                          But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
                                          12-28-2024, 08:42 AM
                                        • nolaryie
                                          BIOS .bin file for ASRock B450M Steel Legend
                                          by nolaryie
                                          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                                          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                                          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                                          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                                          Thank you!
                                          08-06-2025, 12:01 PM
                                        • khanhtq0
                                          Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
                                          by khanhtq0
                                          I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
                                          I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
                                          I suspect the original Intel ME and descriptor...
                                          08-06-2025, 02:14 AM
                                        • zklgfs
                                          AsRock B560 Pro4 Possible Short on +1.8VSB
                                          by zklgfs
                                          I have an AsRock B560 Pro4 (boardview: https://www.badcaps.net/forum/troubl...pro4-schematic) that's completely dead (it doesn't even turn on the power supply when the power button is pressed or the power button pins are shorted). I do get about 3.4V on the power button pin, but 1.8VSB isn't there. The resistance to ground on the inductor PL53 is only about 0.1-0.4 Ohms. Am I correct in assuming that there must be a short...
                                          06-07-2025, 02:22 AM
