Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
  • khanhtq0
    • Aug 2025
    • Việt Nam
    I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
    I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
    I suspect the original Intel ME and descriptor regions were corrupted or lost, and I’d really appreciate if someone could share a verified full dump from a working board with the same revision (Rev 1.02).
    Thank you in advance!
  • danito
    • Jun 2016
    • 1108
    try
    • khanhtq0
      • Aug 2025
      • Việt Nam
      Originally posted by danito
      try
      Thank you very much! I will try the file you sent and get back to you as soon as possible.
      • gabrieljma1
        Request: Full BIOS dump for ASRock Z790-CX (DDR5)
        by gabrieljma1
        I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
        The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
        I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
        10-08-2025, 03:32 PM
      • subzerillo
        Asrock H510M-HDV/M.2 SE bios dmi area from dump
        by subzerillo
        Hello.
        I'm wondering how can I check and extract de dmi area from a bios backup.
        I know it depends on the brand and model of the motherboard. Is there some guide that could help me understand and extract the dmi from the original bios dump to a new bios file.
        The motherboard is H510M-HDV/M.2 SE
        Attached is:
        h510m is the dump bios
        h510mhms1 is the downloaded bios from the website...
        10-09-2025, 02:23 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
