Hi, browsing this forum it doesn't seem that asrock is normally in the "badcaps" category, however I have one bulged capacitor (1000uF, 6.3V) close to the agp slot.
The symptoms: upon power up the bios beeps 8 times (repeatedly), the code is for "faulty or missing video memory" (there was a similar case in this forum but I cannot find it right now). Of course it's not the video memory (tried with 3 different cards).
It's not the power supply (tried with two more).
If I wait 5-10 minutes and reset the computer it will work with no problem or instability (at least it has been doing so for the last 3 weeks).
Note that I don't use the agp slot (in fact I have an old pci video card just to let it boot, but there's no monitor connected, this is a vdr machine that uses a dxr3 card as a tv output ).
Do you think that:
Do you think that:
- is this possibly an agp voltage regulator?
- if yes, the fact that I don't use the agp slot is the possible cause of the faulty capacitor or is it just a bad capacitor?
- will it be enough to replace just that capacitor (if I find a suitable low esr one)? (I can scavenge one 1000uF 16v marked as KME, maybe it's a Chemi-Con?)
