I cant understand this.
  • gastorgrab
    • May 2007
    • 320
    I'm sorry, but how can one machine with leaking caps work so well while another machine stops working if you breath too hard on it?
    I reassembled my fathers machine with the new Enhance power supply. It now seems incredibly stable. This is the system where the Antec SmartPower originated. After pushing the current machine into place i decided to shine a flashlight into the power supply of the EPoX 8RGA that i recently recapped. This was dads temporary replacement.
    This machine showed no behavioral abnormalities but over half of the caps on the MB were leaking.
    The first thing inside that i can identify as a capacitor through the fan grill is a blue 10mm radial.....................wearing a fur hat.
    How the hell can this thing run so stable?
  • Harvey
    • Apr 2007
    • 264
    Re: I cant understand this.
    Are you sure its not just glue on the cap?
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      can you do a favour, dont repair it just let it run and record the number of days until it fucks everything. i need this data.
      • stevo1210
        • Oct 2006
        • 4156
        I have the same idea as you. Why is it still stable with a bunch of bad caps??
        I had an IBM netvista with a bunch of failed GSC caps and it was rock stable and I didn't know it had bad caps until I opened the case up....
        So yeah, I have the same question. Why is a motherboard with a bunch of bad caps still stable??
        • Spacedye69
          • Nov 2005
          • 698
          • US
          Why do some General Motors cars still run? Sometimes its just pure blind luck.
          • linuxguru
            • Apr 2005
            • 1564
            Depends on the CPU Vcore load and various other things, like the number of MLCCs below the CPU socket, the design margin on the VRM O/P, etc.
            There are desktop P3/Celerons with a Pd of 12 - 20W or so - they'll probably run OK even if there's a single functional bypass cap on the output side of the VRM, as long as there are a number of large MLCCs below the CPU socket to take the core-clock and FSB ripple.
            OTOH, all bets are off even with a single busted Vcore cap on a P4 board with a Prescott 100W+ CPU - the design margins are far tighter.
            {\begin rant} Sometimes, it all depends on how much leeway the bean-counters have to fuck things up by omitting extra components that have been spec'ed by real engineers. That's also why bridges sometimes collapse. {\end rant}
            • Tom41
              • Oct 2005
              • 338
              • England
              I had several PCs at work that were all of the same basic design, same motherboard and components. Every PC had GSC caps, and in each case every single cap near the CPU was vented! Oddly, two of the PCs were still stable - but one of them was doing random reboots and crashes.
              Surely the vented GSCs didn't help, but a contributing factor could have been that the fan in the PSU had been dead a long time. The other vented-GSC PCs still had PSUs with working fans - perhaps this prolonged their life?
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • gastorgrab
                • May 2007
                • 320
                With my luck with new parts these days i'm almost afraid to do anything about it.
                • severach
                  • Aug 2007
                  • 1055
                  Capacitance of a blown cap typically goes down but not always. If a few 3300uf caps turn into 330uf caps you can expect trouble every time. I pulled 4 vented Rubycon 3300uf from a Dell Dimension and the capacitances measured as high as 7500uf. Other than a mucked up Windows XP install, the Dell actually ran quite well. Surely the voltage drops as the capacitance rises but many caps are double to triple the voltage they need to be.
                  A particular Dell P4 power supply model with Arcon caps has a very high failure rate. I pull and test all these caps because many fail without showing signs. Some Arcon caps from these test more than double the printed value. Those are probably not the ones making the supply fail.
                  I also had an Asrock P4S61 motherboard that would not post because of two 1000uf filter caps. Each tested about 575uf. Looks like the bean counters left that one on the edge of the abyss.
                  sig files are for morons
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    it may take awhile before the vented caps dry out enough to cause trouble.
                    • davmax
                      • Dec 2005
                      • 899
                      Severach. If capacitance does rise two things will happen. Ripple will reduce ( if ESR does not rise significantly) this may slightly raise the measured output voltage and VRM response time will increase.
                      160Gb WD SATAII Server grade
                      Nvidia 8500GT 256Mb
                      Samsung 18x DVD writer
                      33 way card reader
                      Windows XP Pro SP3
                      17" Benq FP737s LCD monitor
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        It probably wasn't stable, even when it appeared to be, bet you Prime95 would fail pronto!
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • yanz
                          • Nov 2004
                          • 910
                          why, my ep 8k3a with more than 6 bloated gsc caps was still running f@h perfectly for months, untill it doing more bluescreen in the end..
                          it's just a matter of time.
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            • USA, Unsure of Planet
                            As lg pointed out, different loads and regulator circuit contexts make for a great deal of difference. Differences in cooling contribute. Low Z caps are also highly tuned electro-chemical systems. "Minor" differences can have major performance impacts.
                            PeteS in CA
                              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 03:28 PM
                            • CG2
                              Janome DC3050 Sewing Machine Pedal Resistance
                              by CG2
                              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                              04-14-2023, 07:53 AM
                            • mkdj
                              MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                              by mkdj
                              About me, my goal and the equipment I (don't) have:
                              I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                              About my issue and my goal:
                              A friend of mine has a MacBook Air M1 A2337 that does not...
                              04-03-2025, 08:28 AM
                            • unimatrix93
                              How to stabilize AC voltage to CNC machine
                              by unimatrix93
                              Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                              I have a CNC machine wired to 3-phase 230V AC.
                              It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                              The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                              I contacted the electricity company but they refuse to help me solve this problem.
                              So I started to look around for some DIY...
                              03-17-2025, 05:52 AM
                            • xdever
                              820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
                              by xdever
                              I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
                              01-15-2025, 08:44 PM
