820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
  • xdever
    • Oct 2019
    • Svájc
    I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0 is 2.5V. The TPS62180 looks perfect, the SSDs have no visible sign of damage, I checked with thermal camera and nothing gets hot. PP2V5_NAND_SSD0 measures 0.387V in diode mode (for the good side it's 0.421V, but the good side only have 1 SSD chips, and the bad have 4 of them, so I guess it's kind of right).
    I can put the MAC in DFU mode with macvdmtool, but when I start restoring the system, it just disappears from USB and turns off.
    Additionally, when the machine tries to start, it power cycles every 20 seconds (all the SSD voltages go away for a moment and then come back).
    I know about the special power requirements of these boards. I have the battery connected and I plug in the original 96W adapter.
    Does anybody have any idea what could have happened here?
    Thank you,
    Robert
  • mon2
    • 14727
    @ 4V, the PP2V5_NAND_SSD0 is dead. With dead nand, the DFU cannot complete. Crapware design.
      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • Aeisens
      Samsung UE50RU7170 not booting /no picture
      by Aeisens
      Dear all,
      My issue is the following:
      Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
      I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
      Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
      Question 1: Where should I start to...
      06-24-2025, 03:07 PM
    • Daniel Kubica
      Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
      by Daniel Kubica
      I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
      I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
      06-14-2025, 09:24 AM
