9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
  • Geeker007
    • Jan 2025
    • 20
    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
    I am new to electronics repair, so my queries could be naive but I am ready to learn.
    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is to inject low voltage and check with component is getting hot. But I want to understand basics as well.
    1. How to find power rail on mobo.
    2. What else I can check with just multimeter? Like to check if inductors are grounded, if yes then there is short. Check if any capacitor is shorted? What else?
    3. So if my multimeter is in continuity check mode, and I connect prongs to terminals of a capacitor it should not beep, right? If it is beeping there is a short?
    I am attaching an image of mother board, this what I have checked as of now.
    I put multimeter into 2000 resistance mode. Here are the values.
    Blue Ones - 424 for two then 371 for others
    White - 446
    Green - 033
    Yellow - 442
    Orange - 451
    Red - 432
    Click image for larger version  Name:	board.webp Views:	2 Size:	153.6 KB ID:	3559049
    Other things/measurements:
    I took the voltage measurement on inductors immediately after connecting power, nothing came up, means power didn't reach till there? I checked the same thing on DC jack and it came 1.96V for while and immediately went back to .16V.
    I checked short on DC jack, but ground and main is not shorted on it. I checked outer terminal with inner 3 terminals. So just to confirm, outer is ground and inner 3 are mains?
    Click image for larger version  Name:	jack.webp Views:	1 Size:	12.3 KB ID:	3559050
    I got a hold of another laptop charger which is 19V but with different DC jack. So I would need to use DC jack of possibly culprit PSU. When I cut open the wire, it has three wires, black, white and blue. So that is live, neutral and blue is signal for which PSU is connected?
    Can I simply connect black and white cables to laptop charger DC jack and keep blue wire open? Will that work?
    Updated - So I went ahead and connected black and white wire. Inserted the jack and again my laptop charger also turned off immediately. So original PSU seems to be fine. I again checked short on input DC jack but no it's not shorted. There is a resistance coming when checking between outer ground and pin which between center pin and outer ground pin.
    So I am again stuck. What else I can do? Could that DC jack from original power supply be bad?
    Thanks, Sam
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    check resistance on that marked resistor to gnd. all coils are ok according to your reading.
    • Geeker007
      • Jan 2025
      • 20
      So in continuity check mode, it is beeping. So this resistor is grounded. 00.4 value coming when checking resistance mode set at 200.
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        do you have lab psu ? you could inject 1 volt 3 amp and see what get hot spilling maybe some ipa or better with thermal camera.
        • Geeker007
          • Jan 2025
          • 20
          Unfortunately I don't have thermal camera, but I can get a lab PSU and use 91% IPA, will that work?
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            yes it will work most of the time..... just spill some ipa close that dc connector where mosfet or caps are . if we had a boardview we could see that line where could possible go.
              • 21899
              Schematic & boardview https://www.badcaps.net/forum/troubl...oard-schematic
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                tnx very much for the brd. what app can i use to open it ? openbv i use for mac doesnt work
                  • 21899
                  Allegro Free Physical Viewer, but there`s a problem, the file has a password , i tried it https://www.badcaps.net/forum/troubl...38#post1819438
                    • 21899
                    Found a CAD boardview ,it opens ok with openboardview https://www.badcaps.net/forum/troubl...95#post3559795
                    • dellxps15
                      • Feb 2014
                      • 1598
                      • italy
                      it's hard to use it..... still some point give me nc or the bus stop somewhere.
                      ok give it a look.
                      +adp_19v
                      edit2: ok loks like it goes in every mosfet like other laptop. some go also to cpu mosfet so be carefull (i see u removed the cpu good job) so make good progress when injecting power.check if anything get hot.
                      • Geeker007
                        • Jan 2025
                        • 20
                        Sorry for the delay in checking, was out of town. So I injected power but I don't see anything getting hot. Any other way of finding the short?
                        • Geeker007
                          • Jan 2025
                          • 20
                          SMDFlea and dellxps15 So I was able to find the short. Thank you so much for your help. So it was a capacitor. I removed it and now short is gone. But I don’t have replacement capacitor.
                          Can I use the PC without that capacitor or I need to replace it. Can you please let me know its value if it is needed and I will try to find it on some donor board.
                          Attaching the picture of faulty capacitor highlighted in green circle.
                          • Geeker007
                            • Jan 2025
                            • 20
                            I removed this one on the board. C178. I think it is 100uF/16V. So I don't have SMD capacitor. Will a normal Electrolytic Capacitor work here if I am able to find a one? I think this is in fan circuit. Please confirm.
                            • aaronkatrini
                              Help me find the short circuit on this WORKING Nvidia GTX1650
                              by aaronkatrini
                              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                              04-18-2024, 03:15 PM
                            • Tarot Superstars
                              Short Circuit tester
                              by Tarot Superstars
                              Hello.
                              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                              Link
                              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                              https://www.youtube.com/watch?v=0eixDdCpiO4
                              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                              09-25-2023, 09:11 AM
                            • fab13
                              Nintendo Switch lite charging chip heats up and does not short circuit
                              by fab13
                              Hello everyone
                              Small technical problem on a Nintendo Switch lite
                              Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
                              After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
                              When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
                              Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
                              09-16-2023, 04:59 AM
                            • M1NEBLANK SHOW
                              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                              by M1NEBLANK SHOW
                              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                              Schematic and Boardview here
                              04-04-2025, 03:57 PM
                            • rumpumpel1
                              Fault source of a short circuit
                              by rumpumpel1
                              I have a mainboard with a short circuit (approx. 0 Ohm) on the 3.3V rail. As usual, I injected current and observed the mainboard with the thermal camera. Instead of individual components becoming warm, I observed that an area of several square centimeters became evenly warm from approx. 2A.
                              Has anyone ever seen anything like this? Is it possible that there is a short circuit between two layers of the mainboard? The visual inspection of the mainboard did not reveal any abnormalities....
                              10-21-2025, 01:38 AM
