Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
I removed this one on the board. C178. I think it is 100uF/16V. So I don't have SMD capacitor. Will a normal Electrolytic Capacitor work here if I am able to find a one? I think this is in fan circuit. Please confirm. -
SMDFlea and dellxps15 So I was able to find the short. Thank you so much for your help. So it was a capacitor. I removed it and now short is gone. But I don’t have replacement capacitor.
Can I use the PC without that capacitor or I need to replace it. Can you please let me know its value if it is needed and I will try to find it on some donor board.
Attaching the picture of faulty capacitor highlighted in green circle.Leave a comment:
Sorry for the delay in checking, was out of town. So I injected power but I don't see anything getting hot. Any other way of finding the short?Leave a comment:
it's hard to use it..... still some point give me nc or the bus stop somewhere.
ok give it a look.
+adp_19v
edit2: ok loks like it goes in every mosfet like other laptop. some go also to cpu mosfet so be carefull (i see u removed the cpu good job) so make good progress when injecting power.check if anything get hot.Last edited by dellxps15; 01-29-2025, 04:37 PM.Leave a comment:
Found a CAD boardview ,it opens ok with openboardview https://www.badcaps.net/forum/troubl...95#post3559795
Allegro Free Physical Viewer, but there`s a problem, the file has a password , i tried it https://www.badcaps.net/forum/troubl...38#post1819438Leave a comment:
tnx very much for the brd. what app can i use to open it ? openbv i use for mac doesnt work
yes it will work most of the time..... just spill some ipa close that dc connector where mosfet or caps are . if we had a boardview we could see that line where could possible go.Leave a comment:
Unfortunately I don't have thermal camera, but I can get a lab PSU and use 91% IPA, will that work?Leave a comment:
do you have lab psu ? you could inject 1 volt 3 amp and see what get hot spilling maybe some ipa or better with thermal camera.Leave a comment:
So in continuity check mode, it is beeping. So this resistor is grounded. 00.4 value coming when checking resistance mode set at 200.Leave a comment:
Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
I am new to electronics repair, so my queries could be naive but I am ready to learn.
So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is to inject low voltage and check with component is getting hot. But I want to understand basics as well.- How to find power rail on mobo.
- What else I can check with just multimeter? Like to check if inductors are grounded, if yes then there is short. Check if any capacitor is shorted? What else?
- So if my multimeter is in continuity check mode, and I connect prongs to terminals of a capacitor it should not beep, right? If it is beeping there is a short?
I am attaching an image of mother board, this what I have checked as of now.
I put multimeter into 2000 resistance mode. Here are the values.
Blue Ones - 424 for two then 371 for others
White - 446
Green - 033
Yellow - 442
Orange - 451
Red - 432
Other things/measurements:
I took the voltage measurement on inductors immediately after connecting power, nothing came up, means power didn't reach till there? I checked the same thing on DC jack and it came 1.96V for while and immediately went back to .16V.
I checked short on DC jack, but ground and main is not shorted on it. I checked outer terminal with inner 3 terminals. So just to confirm, outer is ground and inner 3 are mains?
I got a hold of another laptop charger which is 19V but with different DC jack. So I would need to use DC jack of possibly culprit PSU. When I cut open the wire, it has three wires, black, white and blue. So that is live, neutral and blue is signal for which PSU is connected?
Can I simply connect black and white cables to laptop charger DC jack and keep blue wire open? Will that work?
Updated - So I went ahead and connected black and white wire. Inserted the jack and again my laptop charger also turned off immediately. So original PSU seems to be fine. I again checked short on input DC jack but no it's not shorted. There is a resistance coming when checking between outer ground and pin which between center pin and outer ground pin.
So I am again stuck. What else I can do? Could that DC jack from original power supply be bad?
Thanks, Sam
by thinkcentreHello,
this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe... -
by aaronkatriniHi all,
Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second... -
by RofixHi everyone, I wanted to ask you for some advice
on this board: HP ProBook 640 G5
6050A3028601-MB-A01(A1)
I have a short circuit on the 19-volt line.
I initially found and replaced this faulty MOSFET, Q60C10.
Then, when I powered up the board, I had the same problem. The MOSFET failed and is giving me a short circuit.
I wanted to ask if it's possible to try to find the faulty component by injecting current, and at what point, so I can check the damaged component with a thermal imaging camera.
Thanks everyone for the advice.
by orizonHi everyone,
I need help clearing the BIOS master password on a Dell OptiPlex Micro Plus 7020.
I have already extracted the 16MB dump using a CH341A Pro programmer and a SOIC8 clip. The NVRAM area seems to be encrypted.
- Model: Dell OptiPlex Micro Plus 7020
- Chip size: 16MB (128Mb)
- BIOS Chip: Winbond 25Q128JV
I've attached my original locked dump. Could someone please patch it or clear the password for me?
Thank you so much in advance!...-
Hello.
I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
Link
The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
https://www.youtube.com/watch?v=0eixDdCpiO4
My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor... - Loading...
