asus p5kpl am/ps freeze on post screen
  • srt1
    • Aug 2013
    • 177
    • india
    my p5kpl freeze on boot screen it showing initilizing usb controllers done and detecting memory. further no movement. i waitd almost 30 minuts stil no sucess . i already cleard cmos and removed all hdd and othr usb devises stil same problm ..is it bios corrupted/?
  • srt1
    • Aug 2013
    • 177
    • india
    Re: asus p5kpl am/ps freeze on post screen
    no body here to help me?
    • c_hegge
      • Sep 2009
      • 5219
      Have you tried it with another CPU and RAM?
      If that doesn't fix it, then it's probably time for a new motherboard. I've used a few ASUS P5KPL boards in new PCs I built for others a few years ago. A lot of them did have funny issues like this. It's just a badly designed motherboard IMO (like most ASUS boards).
      • srt1
        • Aug 2013
        • 177
        • india
        yea i tried changing cpu and ram but its not fix the problem. right i found another thing . i have a jetway g31 motherbard that also same problem freeze on bios post screen. actualy both motherboard not hanging bcz wen i hit ctl alt del it restarting.so i swaped bios of two motherboard each other.the asus motherboard post completely and detected hdd . now its working. but jetway maotherboard stil freeze on same location. so i descided to put another bios chip of asrock g31 motherboard.i wonderd the jetway mb also completed posting. so i think its bios problm. wher can i flash asus bios?
        • Philly Cheese Steak
          • Mar 2011
          • 114
          Depending on the board, the newer boards you can flash with nothing in them(intel I think). Use a bootable USB jump drive, swap the PSU out?
          X99 5930K
          X99-gaming 9
          EVGA 1080 Vanilla
          Gskill 16GBRip JAWS@2400
          SSD'S
          Corsair AX1200
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Reseat the RAM and if using all the RAM slots, take out 2 of the RAM sticks and raise the VDIMM to 1.90 V then put the other 2 RAM sticks back in. That cured the BIOS freeze on my P5QL Pro with 4 sticks.
            Even though that may have just been poor contact of the RAM sticks.....
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • holmes222
              • Aug 2009
              • 61
              • INA
              hello ..
              i have similiar problem with biostar g31 ..it just stuck at post screen (same as your description)
              my solution is remove onboard audio chip (realtek chip), after remove ..the mobo boot normaly without stuck at post screen
              try it ..and post here the result
                • 31247
                @srt1 - have you tried with a different PSU?
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • FallenOne008
                  Asus G712L No Screen Backlight
                  by FallenOne008
                  Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                  The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                  03-31-2025, 08:27 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • krige
                  asus g750js ms1130c (203) turns on nothing on the screen
                  by krige
                  hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
                  03-22-2024, 04:59 AM
                • Technodoc
                  ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                  by Technodoc
                  Asus laptop G614JZ-N3012W Rog Strix with i7
                  Mainboard G634J-PMV-VGT
                  6050A3441302-MB-A01
                  2023-02-10
                  Power button works okay....power light goes on
                  Red "bottom" leds go on
                  Charging led works
                  Fans do not spin, capslock key does nothing, screen stays black
                  I would like to program the bios again, to rule out a corrupted bios.
                  However I run into a size error
                  The bios chip is a Winbond 25R256JVEN
                  Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                  02-24-2025, 04:46 AM
