ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
  • Technodoc
    • Aug 2007
    • 10
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere here on the forum)
    Here is however my problem : the bios file that is saved, is 32.768 kB
    The bios file I downloaded from the Asus website (version 331) is after extracting 38.016 kB in size
    I have to extract the bios from this updatefile but am not sure how to proceed...
    Is there someone who can shine some light on this ?? have attached both bios files
    Thanks in advance,
    Frans
    • 22109
    Read https://www.badcaps.net/forum/troubl...before-posting ,and type the laptop serial number please.
    • Technodoc
      • Aug 2007
      • 10
      Sorry....s/nr R5NRKD037485206
      CN : RWNJ
      MFD : 2023-05
      • ruslan657
        • Mar 2016
        • 75
        • Azerbaijan
        hey friends, hope all u fine
        need help bios
        G634J-PMV-VGT
        6050A3441302-MB-A01
        ASUS G634JY-NM035
        S/N R5NRKD00594622B
        • hoaca388
          Badcaps
          • Jan 2022
          • 12419
          need help bios
          G634J-PMV-VGT
          6050A3441302-MB-A01
          ASUS G634JY-NM035
          S/N R5NRKD00594622B
          G634JY
          • RCCBUBC
            • Sep 2025
            • 9
            • CANADA
            Need help with the bios file.
            Power on and keyboard lights up but won't post or shows black screen.
            G634J G634JZR14900-0EAAXHBBX30
            Serial: RBNRKD016219463
            • ruslan657
              • Mar 2016
              • 75
              • Azerbaijan
              Originally posted by hoaca388
              G634JY
              thank u bro but not worked found another forum thanks all
              • RCCBUBC
                • Sep 2025
                • 9
                • CANADA
                Could anyone help me with this bios please?
                Thank you in advance!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12419
                  G634JZR
                  • RCCBUBC
                    • Sep 2025
                    • 9
                    • CANADA
                    G634JZR
                    Thanks but it's stuck on Asus Logo and goes black screen after 2 minutes.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12419
                      Keep looking for hardware problems.
                      • RCCBUBC
                        • Sep 2025
                        • 9
                        • CANADA
                        Sounds good. I will keep you posted if I was able to fix it and test the bios after. Thanks for all the help!
                        • ALANWAKE32
                          • Aug 2018
                          • MEXICO
                          PLEASE REPAIR
                          SERIAL R8NRKD01947234B
                          G614JV-N3254W
                            • 22109
                            Originally posted by ALANWAKE32
                            PLEASE REPAIR
                            G614JV-N3254W
                            post the motherboard model number
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • grimacelord
                              by grimacelord
                              07-10-2025, 02:52 PM
                            • LtCdrData
                              ASUS Rog Strix 6050A3441302-MB-A01 BIOS
                              by LtCdrData
                              I'm trying to flash the bios chip but all the files on the asus website end in a 3 digit bios number. I'm not sure how to convert/trim/extract from these files to a file I can load with AsProgrammer to write to the chip.
                              ASUS Rog Strix Scar G18 G834JY-XS97
                              latest version 331 or oldest 317 would be great. thanks!
                              https://rog.asus.com/us/laptops/rog-...helpdesk_bios/
                              09-16-2025, 06:13 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
