[HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
This is a sticky topic.
Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
x2
I don't see how "too good of caps" would cause a problem either. The PSU's wires have enough resistance so that the PSU never really "sees" the low ESR of those "too good caps" on the motherboard.Comment
This helped me fix my Asus P5E deluxe. It also had the Chassis Intruded fatal error. Took me only a few seconds to find the right transistor, thanks to the directions.
It's not perfect yet. Is it possible that my 3.3v point comes on too late? If I do a cold boot it gives me the error, but when I reset everything is fine.
Anyway, I wanted to say thanks and give people looking for a solution for their P5E deluxe some directions. So I added a picture of the fix for the P5E deluxe. The transistor is located in the bottom left corner of the motherboard. Underneath the winbond chip.Comment
I see you pulled 3.3v from a resistor. Maybe that's part of some other circuit and it takes a little while to charge. Try finding a capacitor with 3.3v on it, that should charge up quickly (as it'll be directly across a 3.3v regulator) and it should work on a cold boot as well.
The capacitors are the brown colored parts with no marking on them.
Last edited by Th3_uN1Qu3; 01-27-2014, 12:36 PM.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Thanks, I'll find another spot and post the picture. If it goes into hibernation or sleep mode now, I can't get the computer to turn back on heheh
Still, this is a lot better than Chassis Intruded: Fatal Error...
I found a new spot, but it seems that I can't get my computer to wake up anymore if it goes to sleep, and also it doesn't want to turn off anymore. Could this have something to do with it? Should I just find an alternate point again?Comment
Shouldn't happen. What happens when you try to turn the computer off? Do the fans remain spinning?
Try to clear CMOS again and also clean that area on the board well using isopropyl alcohol and a toothbrush.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Good job!
Another board saved from the landfill.
I know this is an old thread but I have a P5E3 with same problem. My chassis intrusion connector is by the front panel header and the board power LED and the super I/O controller is in the top corner like the P5KE shown but no transistors are near it. Can anyone help me identify the correct sot-23 on my board? I certainly would appreciate it. There are 4 transistors surrounding the intrusion connector but none are marked sot-23.Comment
SOT-23 is just the package specification (look up SOT-23 on Google images and you will see what I mean). The actual marking on the transistor will vary, depending on what it is.Last edited by momaka; 04-03-2014, 11:31 PM.Comment
I have seen this error on a P6T Deluxe V2 socket 1366 motherboard, is it likely the same solution ?
Also, it appears that cleaning the board well could resolve this as well, is that correct ?
As old as this thread is, its the first solution I've seen, in a LOT of looking, that seems to delineate the exact CAUSE of the fault. Very, very useful information.
Thanks very much to the OP, btw !Comment
Have an easier workaround, following are the steps :
<1> Remove the front USB and audio connectors from MB
<2> Remove the reset switch connector
<3> Reset BIOS using the Jumper / removing CMOS
<4> Reset BIOS Settings and reboot your PC and things should be Up and running.
Let me know if this works for you too.Comment
Th3_uN1Qu3
Please help me with my PK5 DELUXE mother board that surely need that "remove transitor fix" cant know for sure wich one is it and i don't wanna mess something up.
ThanksComment
Please post clear pictures of the mainboard and a close-up of the Winbond chip area.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
by playitmy system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
few years back ps2 mouse stopped working, but ps2... -
by harpOh, sadly it has no screw...
What is the proper way to open this so that not destroy rubber?
I feel if go on forward with not knowledge howto open, that it be broken rubber seal on it.... -
by OKRPKCOMPAsus board B85M-E bios is ok, motherboard is ok, everything is fine but i am facing this error at startup
Chassis intrude,pls check yours system
Fatal error, system halted
Remember, there is nothing in bios setup to disable chassis error. Anybody can help me to solve this prob
Thanks in advance...-
by vishal24I m Having Lenovo Ideacenter B320 all in one.
when i Press F1 for BIOS, Asking for password. after 3 times wrong password, give error Fatal Error System Halted.
i forgot my bios password.-
by angelosHi all,
I got in this beast of a tv of which i am needing advice on how to access the AUTO GEN function so that i can test if my main board is perhaps faulty.
There is a 4 pin plug on the plasma control board but i don't know what to do there and i cannot find any reference on the web to it.
I have added photos to jar your memories...
This is PDP42V8 chassis.
Any suggestions would be greatly appreciated.
Angelos... - Loading...
