Epox 8RDA Recaps
  • ferynov
    • Dec 2006
    • 18
    Epox 8RDA Recaps
    I have epox 8RDA ... many badcaps ...major caps is GSC. few Teapo and Sulycon??.. i want try to recaps... coz my system restart frequently..
    anyone have sugestion for my recaps project..?
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: Epox 8RDA Recaps
    I know 8RDA/8RDA+ PCB Ver1.x have using the following caps, because i have recapped so many 8RDA series.
    6 x 3300uF 6.3v D10mm
    4 x 2200uF 10v D10mm
    5 x 1500uF 6.3v D10mm
    9 x 1000uF 6.3v D8mm
    7 x 470uF 16v D8mm
    If you are outside US/Canada, shoot me a PM. Otherwise, you can contact badcaps.net/Top Cat for getting a solution.
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
    • ferynov
      • Dec 2006
      • 18
      the pictures is :... i need advise... what best caps replacement that i use for epox..? ..are TEAPO is good? on my board teapo not bugging... GSC is weak..thanks for advise.
      • gonzo0815
        • Feb 2006
        • 1600
        Well, read the FAQ and you will probably find out, that we usually suggest one o fthe folowing brands and series:
        Panasonic FC, FM, FK, FJ
        Rubycon ZL, ZLG, MBZ, MZC
        Sanyo WG
        Nichicon (don`t know their series) but not the HM(N) series.
        Some members here have great succes with Samxon too, but as Samxon are not that wiedely known for a long time, there is no longtime experience with them.
        Dependent on the avaliability i would suggest some Panasonic FMs or FC`s for all caps. If you want to improove the board far beyond the specs as it was new (e.g. to archive an higher OC), use Panasonic FM for all inputcaps ( those 4 big GSC ones ) and Rubycon MCZ or Samxon GA for the outputcaps ( the Teapos near the coils).
        All the other caps you can use Panasonic FM.
        I would replace all caps, especially those TEAPOS too. They are crappy too, and can fail without any sign. So if you want to do a lasting rpair replace any bad caps =>470uF.
        If you want to make it perfect, replace any cap.
        • PeteS in CA
          • Aug 2005
          • 3582
          • USA, Unsure of Planet
          Adding to what gonzo posted, Nichicon HD, HE, HZ series usually OK; avoid HM and HN series, as they had a defective batch a couple of years ago, and those parts are likely still in distribution or brokers. Also UCC/NCC KY, KZE, KZH series are good. With Rubycon, YXH and ZLH series are also good; per Rubycon's 2007 paper catalog (got one yesterday), they will stop taking orders for ZA and MBZ series in 9/08.
          PeteS in CA
          • Oklahoma Wolf
            • Dec 2005
            • 353
            I used Panasonic FC, FM, and Chemicon KY to do my 8RDA. Ran out of caps so I left the Sanyo ones by the CPU socket alone (you have something else there I'd replace though).
            • ferynov
              • Dec 2006
              • 18
              thanks for advise i will try to find the caps...hard to find in my county (yogya indonesia) ...
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                caps are available in indonesia. pm yanz he will tell you where to buy them.
                • Brian C
                  • Dec 2006
                  • 156
                  Recap is definitely a good idea. For longer run in future, u might need a good power supply.
                  • ferynov
                    • Dec 2006
                    • 18
                    hard to find and no comments from yans...i think he's not active read my help message... i use the used caps from other mobos ..i choose Sanyo WG in 5 x 1500uF 6.3v D10mm & 6 x 3300uF 6.3v D10mm and Panasonic FJZ [cmiiw] in 9 x 1000uF 6.3v D8mm... and the last thing i can't found is 4 x 2200uF 10v D10mm .... but I have KZG 2200uF 6.3v D10mm with different volt n high.... what happen if i use 6.3v in mobos? thanks for respons....
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      You can use those 6.3v caps without any problem. There is simply no voltage between 12v nd 5v in a usuall PC system. There are other reasons, why the vendor initially used 10v caps.
                      • ferynov
                        • Dec 2006
                        • 18
                        Thanks gonzo....i have been tried with no problem... my project successfull ! thanks ...
                        • Anna
                          • May 2006
                          • 5
                          ferynov, Yanz said he appologize for not replying your pm. He has a list of shops that provide good caps in bandung, indonesia:
                          http://forum.oprekpc.com/viewtopic.php?t=6232
                          He would also like to ask you to add a list of shop in yogya that provide good caps, as there are still many user in indonesia that need those list..
                          Originally posted by yanz
                          hi, fery.. salam kenal. maaf banget pm-nya ga sempat kebales karena ada kejadian yg ga diharepin yg bikin saya ga sempat nyentuh internet berminggu2. salah seorang keluarga saya termasuk dalam korban kecelakan hilangnya pesawat adam air dan banyak hal yg terjadi yg membuat saya tidak bisa membagi perhatian secukupnya untuk forum badcaps ini.
                          untuk diskusi lebih lanjut, kalau anda mau, silakan bergabung dengan forum oprekpc krn banyak rekan2 lain yg juga berada dalam masalah yg sama spt ini, dan beberapa dr mereka bisa membantu. dan saya akan sangat berterima kasih kalau anda mau menambahkan juga daftar toko yg menyediakan caps di yogya.
                          salam,
                          yanz
                          • ferynov
                            • Dec 2006
                            • 18
                            thanks Anna, i don't know that Yanz message me before.
                            • Alladinsane
                              • Feb 2007
                              • 8
                              I also have 9 caps to replace on this mobo- 4 2200uF 10v and 5 500uF 6.3v. How do I contact Topcat for solutions? I am in the States btw.
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                Request repair service from Topcat
                                Request capacitor kit from Topcat
                                • Alladinsane
                                  • Feb 2007
                                  • 8
                                  aha. thank you
                                  • Alladinsane
                                    • Feb 2007
                                    • 8
                                    I found some of the caps I need, but, as I am a cap noob, I am unsure if these will work. In the FAQ section, they mentioned United chemcom as being acceptable, but they did not mention this series as being acceptable. They are
                                    KMG series
                                    Are these ok? It is hard to find a place to buy in small amounts, but this place (that was in the faq seems to allow small purchases, which is nice
                                    edit: the way the faq reads makes me think that the named models under ucc are the bad ones.. is this correct?
                                    edit: which of these would be best for 2200 10v?
                                    • willawake
                                      Super Modulator
                                      • Nov 2003
                                      • 8457
                                      • Greece
                                      i dont see anything good there
                                      best to get from digikey (catalogue page 1266 Panasonic FM)
                                      • Alladinsane
                                        • Feb 2007
                                        • 8
                                        ok, thanks.
                                        • iMic
                                          IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                          by iMic
                                          Hi folks,
                                          I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                          The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                          11-29-2023, 06:44 AM
                                        • kotel studios
                                          Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                          by kotel studios
                                          Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                          Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                          So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                          What I've tried so far:
                                          replace the original N-MOSFETs with beefier 60V ones for testing
                                          Resolder the resistors near the Vcore Jumper block
                                          Short Vcore...
                                          05-25-2025, 01:46 AM
                                        • kotel studios
                                          Epox EP 8K3A+/8K3A - need specs of 2 caps in DDR1 VRM arena
                                          by kotel studios
                                          Is there anybody here who could tell me what are the two caps marked bellow? Or atleast send me a picture of those two caps from their board. Size wise I think those will be 2200uF10v, the same as in the CPU VRM, but not sure....
                                          01-18-2025, 08:54 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
