I've got an oldish MSI MS-6368 v2.1 board that has 5 visibly bad capacitors. 3 of them are right next to the ATX power connector and 2 of them are just below the CPU socket. The board seems to have some major problems randomly locking up. I am guessing this is probably due to the board having so many bad capacitors?
All of the capacitors that have gone bad appear to be identical.
Manufacturer: Chhsi
Model?: WG (M)
Temperature Range: -40C - +105C
Voltage: 6.3v
Capacitance: 2700uF
Today, because the machine locked up again, I replaced one of the capacitors near the CPU socket with the only capacitor I had laying about:
Manufacturer: Rubycon
Model: ??? (forgot to look)
Temperature Range -??C - +105C
Voltage: 10v
Capacitance: 2200uF
I see you have a fair few threads asking if it's ok to replace with higher values, but in my case you can see that the capacitance value I have replaced with is actually slightly lower than the original. My main question is if this is ok? I'm seem to be having a hard time finding good brand name, 2700uF capacitors in the UK. I've seen a Panasonic FC series 2700uF capacitor on RS, but the specs say the diameter is 16mm! Perhaps this is a typo? I'm needing as close to 10mm diameter as possible. The replacement I did today was probably (I didn't measure) 12.5mm, and it's at a slight angle as it didn't quite fit perfectly next to the other capacitors.
Thanks in advance,
Mark
Manufacturer: Chhsi
Model?: WG (M)
Voltage: 6.3v
Capacitance: 2700uF
Voltage: 10v
Capacitance: 2200uF
Thanks in advance,
Mark
 I only need a few.
 I only need a few. Just a little worried about the diameter. I'm not sure replacing them with even 12.5mm will actually fit properly. There's hardly any space between the capacitors
 Just ordered:
 Just ordered:
