Fic P4pb-400
  • jarobi
    • Dec 2005
    • 34
    Fic P4pb-400
    This puppy had two strikes against it from the get-go IMO (see: First International Computer) and the kicker was the GSC caps. Symptoms were extremely slow boot & the occasional freeze. Manufacture date was April 2002. FIC didn't get the memo, and continues to be a bottom feeder as far as I'm concerned. Every capacitor on the board was a GSC. These caps were fed by a seven-dollar PowMax "400" watt PSU. I will offer the board to anyone who wants it for the price of shipping.
    Regards,
    Jim
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Fic P4pb-400
    why not recap it Jim? if it still posts then there is a good chance the recap will be successful.
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Re: Fic P4pb-400
      I'll Take anything! How much to ship?
      • jarobi
        • Dec 2005
        • 34
        Re: Fic P4pb-400
        I really have a bad taste in my mouth as regards anything FIC. If it was an ABit or Epox I wouldn't think twice. Spaced, if you're serious PM me, we'll hash it out that way. Shipping... I dunno, six or seven bucks?
        -Jim
        P.S. I'm getting the twin to this setup in the next couple of weeks. I'm going to check the caps well and replace the PowMax with a FSP 350 watt. She told me it's running fine. It will sit for weeks at a time, powered off, between uses. The pictured board was in use 6-8 hours per day.
        • Newbie2
          • Sep 2005
          • 885
          Re: Fic P4pb-400
          I recommend you recap that board ASAP. In your picture 7 bad GSC caps are visible and it only takes a few caps to bring down a board. It may work fine now but will not later.
          If you don't want the board ship it to the guys on this forum that want it.
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • jarobi
            • Dec 2005
            • 34
            Re: Fic P4pb-400
            Thanks, but that was the plan. I pulled the FIC, snapped a photo of the caps, and replaced it with a Tyan board. In a previous post I offered it to anyone who wanted to pay the shipping. Out of personal preference I refuse to spend very much time (e.g. recapping) on anything manufactured by FIC.
            Regards,
            Jim
            • Chris1992
              • Apr 2005
              • 561
              Re: Fic P4pb-400
              why? what's wrong with FIC?
              The great capacitor showdown!
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: Fic P4pb-400
                if you still have it i have a neighbor who needs a socket 478 board for her evilmachines crap box.bad caps went undetected too long and it died 2 days after recapping.
                • jarobi
                  • Dec 2005
                  • 34
                  Re: Fic P4pb-400
                  I shipped it to Spaced already. I'll probably have another one available when I get the second system. I'll PM you if I do. Chris1992, I have personal preferences for everything, especially motherboards. I've experienced high failure rates and general nonsense with FIC boards, so I don't care for them.
                  • Chris1992
                    • Apr 2005
                    • 561
                    Re: Fic P4pb-400
                    Ah, just as I have personal preference for Fortron PSUs.
                    • MrG
                      • Jan 2006
                      Re: Fic P4pb-400
                      Interesting, I have the exact same board (mine is VIA brand and VIA boards were being produced by FIC) and the exact same caps were leaking. I replaced them with KMG capacitors and it is completely stable now. I know that KMG is not recommended since they are not ESR, but I did not want to spend more than the board worth while fixing it. Apparently KMG is not ESR but still better than those junk capacitors, board is working completely stable since several months under constant load 24/7.
                      You can see the details in the following link
                      http://forums.viaarena.com/messagevi...VIEWTMP=Linear
                      By the way, this is a good chance to thank this forum and the administrator for all the information I acquired here, thank you !
                      Regards
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        Re: Fic P4pb-400
                        i missed your post, so if you pass by again we are glad you liked our info.
                        GREAT you got your board working perfectly again!
                        KMG are not so bad i guess, digikey cross references them to panasonic NHG which is an ESR cap at the lower end.
                        • clearchris
                          Soldering Gun with Solder Feeder
                          by clearchris
                          Prices on these have really come down. $40 gets you a solder gun with auto feeder. Anyone have any experience with these?
                          https://www.circuitspecialists.com/c...eid=f560f13fe0
                          03-07-2020, 10:16 AM
                        • eccerr0r
                          Sell or Shim Solar panels?
                          by eccerr0r
                          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                          So now what to do with these small panels?
                          I could sell them...
                          Or I could shim them....
                          03-29-2025, 01:07 AM
                        • stylishconsultant
                          un60j620dafxza - Samsung No Display Problem
                          by stylishconsultant
                          Hi All,
                          Need help.
                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                          09-04-2024, 03:26 AM
                        • MBaads
                          Surface Pro 6 with no USB
                          by MBaads
                          Hey friends.
                          I bought a used Microsoft Surface Pro 6 . Good condition, only downside is that the xHCI complient USB Host Controller gives code 10.
                          I have tried everything that seemed immediately obvious to solve this, like driver updates, roll back OS versions, run all MS's diagnostics tools etc.
                          The kicker: It works in UEFI just fine.
                          It works in Grub2, too.
                          I can even boot off a USB recovery drive thumbstick. However, after it has loaded the image and starts the OSs drivers, it fails.
                          (This is actually how I got Windows back on it, by putting...
                          04-23-2024, 07:41 AM
                        • langbaobao
                          DIY 3D-Printer WSON8 Pogo Pin Adapter
                          by langbaobao
                          Hi.
                          I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                          I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                          01-08-2024, 05:58 PM
