Soldering Gun with Solder Feeder
  • clearchris
    • Dec 2013
    • 687
    Prices on these have really come down. $40 gets you a solder gun with auto feeder. Anyone have any experience with these?
    https://www.circuitspecialists.com/c...eid=f560f13fe0
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Soldering Gun with Solder Feeder
    Talk about lazy... or rather, great for assembly line workers...
      • 31086
      you probably need that suspended on a retracting steel cable over the work area,
      holding that up with a 500g roll of solder stuck to it will kill your wrist really fast!
      • clearchris
        • Dec 2013
        • 687
        Well, the picture shown has a very small roll. I'd imagine were someone to use this, it would be worth rolling a small spool of solder.
        Could be lazy, or could be really nice to have a free hand. I often put my hands in major contortions trying to hold a part, hold the iron and add the solder at the same time.
        Edit: It's actually surprising that I don't burn myself more often than I do.
          • 31086
          use blue tack.
          • petehall347
            • Jan 2015
            • 4427
            this was amusing to read ....https://cdn.badcaps-static.com/pdfs/...a87157115e.pdf
              • Jul 2011
              • 6044
              I bought on of these are all right but they are not temperature controlled and you have roll up the solder your self unless you want to buy the small rolls of solder from them so they will fit
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                That looks like around 100-150g solder reel, so not too bad, but still, the rest of the iron has some weight on it and can cause fatigue...
                  • Jul 2011
                  • 6044
                  This one might be better than the one I have it shows that one to be temperature controlled
                  I might buy one of them
                  • clearchris
                    • Dec 2013
                    • 687
                    STJ: Blue tack? Don't you end up burning that?
                    sam: Yeah, it appears to be temp controlled, that would certainly be a deal killer if it weren't.
                    eccerror: Doesn't look much heavier than my desoldering gun, except for the weight of solder. If it actually works well, I could see it having to be held for much shorter periods of time.
                      • 31086
                      blue-tack on the parts side does not burn - it just softens.
                      dont pull it off while it's hot or it leaves bits behind.
                      another trick i use - masking tape holds a whole line of resistors or leds down,
                      i use a lot of cheap masking tape!
                      one thing i cant stand - people who bend component legs to hold them in - those fuckers have never had to remove old parts that have had that done to them!
                      btw, if that gun has a really strong feed system then maybe you not need the reel on it - just run it down some slippery tubing (not rubber) to the reel at the other end of the power cable.
                      • clearchris
                        • Dec 2013
                        • 687
                        I'm guilty, I bend the component legs, only a little bit though, I don't fold them over like some I have seen. Just enough to cause some friction in the hole.
                        That's a good point about not needing a spool. I'd rather have a small spool though, one fewer thing to tangle. I could even print a small spool on my 3d printer if I really needed it. I doubt it would add all that much weight.
                          • 31086
                          how does the feeder work?
                          is it some sliding friction device on the trigger, or a nice motor-drive?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            my local lidl store had these in last month i didnt buy one though about £17.00
                            https://www.youtube.com/watch?v=Ppe2_-9Kan8
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Amen!
                              Kind of funny I sometimes still bend them... well, no more than two pins and no more than about 30 degrees. Then when one pin is tacked down, unbend and solder each of the remaining pins, and then try to undo the bend in the first pin... heh.
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • Geeker007
                                Friend messed up my laptop motherboard while working on my bench
                                by Geeker007
                                Hi All,
                                So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                I have not tried putting...
                                06-16-2025, 01:40 PM
                                Multifix 425-01 and 450-01 Rework Flux Datasheet
                                REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                - No Clean Formulations
                                - Low residue
                                - Range of activity to deal with different component solderability
                                - Halide free
                                - Suitable for dispensing
                                - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                Both products are supplied in syringes or cartridges for application by dispensing....
                                10-07-2024, 06:02 AM
                              • petemanuk
                                BGA solder balls not connecting - help pls
                                by petemanuk
                                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                11-16-2022, 05:21 AM
                              • Azurain
                                Elitebook 840 G5 Bios Chip Soldering Question
                                by Azurain
                                I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                                Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                                04-14-2023, 06:58 PM
