speedstream 2624 (Siemens S***)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Beware of Siemens S***
    i bought one of these wireless b routers with built in print server at a goodwill(5 bucks) about 6 months ago. was using it until tonight when it stated to act funny. I opened it up to find a bulging Tocon cap.
    i thought Siemens (the manufacturer of speedstream) was a good brad that kept out of this crap. nope.
    since its old and kinda obsolete, i may not re-cap it.
    has anybody else had this happen with siemens
    sigpic
    (Insert witty quote here)
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: speedstream 2624 (Siemens S***)
    siemens was winning many state contracts here, then it was discovered they were paying huge bribes but anyway i havent seen many good caps in networking equipment except for cisco and also recently 3com. its the easiest thing to recap networking equipment and restore to full functionality again.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      all siemens stuff i've had so far (mostly old stuff) used Siemens/EPCOS caps.
      they have a top marking like a few cheapos (a stretched "X") but they work fine.
      even a really old (by now) Slot1 mobo (Siemens D1115) has those and is still going strong in my little brothers homeserver with a PIII 600.
      edit: example of those EPCOS caps.. i've never seen them anywhere else than older Siemens/Fujitsu-Siemens mainboards..
      • weirdlookinguy
        • Sep 2007
        • 1638
        My modem (SpeedStream 4100 I think) has two caps in it, a Matsushita and a G-Luxon.
        Strange mix but it's been doing 24/7 service for 3 years now and has never given me any trouble.
        • i4004
          • Oct 2006
          • 2029
          nope, siemens adsl modem/routers are here highly regarded, and they work quite fine...
          i have one, bought one (used) for my brother, everything ok.
          • alpersen
            Siemens Washing Machine WM12T581TR/67 Touch Panel not working correctly
            by alpersen
            On the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time ). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
            10-24-2025, 01:55 AM
          • Thermaltake
            Fujitsu Siemens Amilo Xa 3530
            by Thermaltake
            Hi, I got this Fujitsu Siemens Amilo Xa 3530 Model: MS2244. from a friend and it is powering On, but only functional keys lights up, fan spins and nothing else, screen is black no backlight, and it's staying like that forever. I tried other memory that I know is working, I tried to empty capacitors by holding power button without battery but still nothing. I didn't try new cmos battery, need to disassemble it first to try that. But I don't think even if cmos battery is dead it would give some backlight and picture...I kind of think it's chipset or gpu dead.
            I read something on google that...
            02-01-2024, 12:34 PM
          • Wet_Cap
            EPCOS Cap Replacement
            by Wet_Cap
            Hey everyone. Just wondering if anyone can help me with some capacitors that blew on a VFD. Caps are EPCOS B43501-S3277-M1, 270uF, 385V, three pin. Markings on capacitors are as follows.
            EPCOS
            B43501-S3277-M1
            270uF (M)
            385V 40/085/56
            10.10 S3
            Tried looking on Epcos website which takes me to TDK. Tried searching with no luck for specs on cap. I just want to find all the information I need to replace these caps. Any help greatly appreciated.
            08-28-2022, 12:00 AM
          • mengpo
            Siemens RVS21.831, Looking for References, Models, and Values of These Components
            by mengpo
            Following a short circuit on the controller board of my heat pump, I'm looking to replace the components shown in the photos. All I know is that they are diodes (but I'm not sure what type), and I haven't been able to find their equivalents.
            The one on the left says: 15A 5BA
            The one on the right says: DTZ S47 or DTZ 547
            Does anyone know how to identify them?
            Thank you very much for your help!
            FYI, the card is a siemens RVS21.831
            02-15-2025, 10:50 AM
          • johancraftech
            Help needed with Siemens S11868502 D SIM24 ECU component value/s
            by johancraftech
            Foremost, I am not an ecu specialist. This ECU: Siemens S11868502 D SIM24 (Ford KA 1.3 Petrol) ended on my bench. It was previously worked on by an unknown technician. The only information I have at hand, is that the owner replaced the ignition coil as the latter caused one of the IGBT's in the ECU to short. The IGBT I can source and replace, but it seems that the previous technician removed 2 components (most probably resistors in a mini-melf package): see attached photo. It seems that schematics and/or board view files does not exist. If there are any ECU specialists that can assist in identifying...
            02-05-2025, 06:28 AM
