EPCOS Cap Replacement
  • Wet_Cap
    • Jan 2021
    Hey everyone. Just wondering if anyone can help me with some capacitors that blew on a VFD. Caps are EPCOS B43501-S3277-M1, 270uF, 385V, three pin. Markings on capacitors are as follows.
    EPCOS
    B43501-S3277-M1
    270uF (M)
    385V 40/085/56
    10.10 S3
    Tried looking on Epcos website which takes me to TDK. Tried searching with no luck for specs on cap. I just want to find all the information I need to replace these caps. Any help greatly appreciated.
    • 31163
    Re: EPCOS Cap Replacement
    use a decent search engine
    https://yandex.com/search/?text=B43501-S3277-M1
    google is only good for looking up propaganda and finding your nearest Trans-center!
    • diif
      • Feb 2014
      • 6978
      • England
      If you stuff all the details you have written into Google, Ecosia or Duckduckgo it would bring up what you want as a first result. However Yandex struggles.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
