Siemens RVS21.831, Looking for References, Models, and Values of These Components
  • mengpo
    • Dec 2021
    • 9
    • France
    Following a short circuit on the controller board of my heat pump, I'm looking to replace the components shown in the photos. All I know is that they are diodes (but I'm not sure what type), and I haven't been able to find their equivalents.
    The one on the left says: 15A 5BA
    The one on the right says: DTZ S47 or DTZ 547
    Does anyone know how to identify them?
    Thank you very much for your help!
    FYI, the card is a siemens RVS21.831
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    What do this pins do? If I had to guess these are TVS diodes.
    • redwire
      • Dec 2010
      • 3912
      A new diode will also just blow - you have to find out why mains is present at that low voltage connector!
      Logo is Vishay General Semiconductor - Diodes Division.
      Closest I can find is 5KASMC or maybe a 1.5SMC TVS.
      "5AG" is not listed but might be a 5KASMC8.5A
      see SMC markings
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        Vishay marking 15A = 1.5SMC15A or a P6SMB15A; Vishay, Onemi or Littlefuse etc are the same.
        The other one I can't make out the manufacturer. Maybe clean it up and make another picture.
        A diode marking DT on a SMB device would be a SMBJ78CA.
        I guess you have to figure out if the case size is an SMB or a SMC and go from there.
        • proxneo
          Recapping Sony ICF-SW55 - verifying cap values
          by proxneo
          Dear reader
          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
          At the moment, I have selected replacements based on the following list of values:
          3 x 470uF 10VDC
          3 x 4.7uF 35VDC
          4 x 47uF 50VDC
          8 x 22uF 6.3 VDC
          1 x 220uF 6.3VDC
          5 x 100uF 6.3VDC
          Which...
          06-21-2023, 12:38 AM
        • Alexander Gutsch
          Gamecube DOL-001 Cap Values/Original Cap Models
          by Alexander Gutsch
          Hey all!
          I need some help identifying the original model of the caps you could see on the pictures below. These all are from a Gamecube and should be replaced as a precaution/repair of the disc drive not reading discs. I know the voltages and capacities are easy to get from most of them, but since I do want to get some high quality replacement parts, I need the ESR or ripple current too to find some equivalent replacements.
          I also added a picture of an Excel sheet I made with the designators and the diameters of the caps.
          Thanks in advance!...
          03-21-2025, 03:41 PM
        • rashidjafar
          Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
          by rashidjafar
          I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
          Values for :-
          PC43 : Capacitor [3x1.5mm]
          PL7 : Inductor [2x1mm]
          PC39 : Capacitor [1x0.5mm]
          Any ideas would be appreciated.
          I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
          08-07-2025, 05:10 PM
        • Kobok
          Different (lower) resistor values on PCB?
          by Kobok
          Dear Alls,
          For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
          09-19-2022, 07:30 AM
        • skdsp
          Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
          by skdsp
          I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
          Attached is the photo.
          Thank you!
          09-27-2025, 09:05 PM
