Xiaomi router freezes at boot after re-capping
  • hinisa
    • Apr 2021
    • 19
    • turkey
    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during kernel messages, or it boot-loops again during kernel boot.
    I'm very inexperienced not sure whether I f**d up something else on the board while soldering or where to start probing with multimeter etc. Any help is appreciated.
    Code:
            MT7621  stage1 code Oct 28 2018 20:39:32 (ASIC)
            CPU=500000000 HZ BUS=166666666 HZ
    Change MPLL source from XTAL to CR...
    do MEMPLL setting..
    MEMPLL Config : 0x11100000
    3PLL mode + External loopback
    === XTAL-40Mhz === DDR-1200Mhz ===
    PLL2 FB_DL: 0x10, 1/0 = 537/487 41000000
    PLL3 FB_DL: 0x15, 1/0 = 647/377 55000000
    PLL4 FB_DL: 0x16, 1/0 = 669/355 59000000
    do DDR setting..[01F40000]
    Apply DDR3 Setting...(use customer AC)
         0  8  16  24  32  40  48  56  64  72  80  88  96 104 112 120
    0000:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0001:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0002:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0003:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0004:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0005:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0006:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0007:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0008:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0009:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    000A:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    000B:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    000C:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    000D:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  1
    000E:|  0  0  0  0  0  0  0  0  0  1  1  1  1  1  1  1
    000F:|  0  0  0  0  1  1  1  1  1  1  1  1  1  1  0  0
    0010:|  1  1  1  1  1  1  1  1  1  0  0  0  0  0  0  0
    0011:|  1  1  1  1  0  0  0  0  0  0  0  0  0  0  0  0
    0012:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0013:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0014:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0015:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0016:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0017:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0018:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0019:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    001A:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    001B:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    001C:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    001D:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    001E:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    001F:|  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    DRAMC_DQSCTL1[0e0]=13000000
    DRAMC_DQSGCTL[124]=80000033
    rank 0 coarse = 15
    rank 0 fine = 72
    B:|  0  0  0  0  0  0  0  0  1  1  1  0  0  0  0  0
    opt_dle value:9
    DRAMC_DDR2CTL[07c]=C287221D
    DRAMC_PADCTL4[0e4]=000022B3
    DRAMC_DQIDLY1[210]=0C090909
    DRAMC_DQIDLY2[214]=06090907
    DRAMC_DQIDLY3[218]=0E09090A
    DRAMC_DQIDLY4[21c]=0B090C0A
    DRAMC_R0DELDLY[018]=00002221
            RX   DQS perbit delay software calibration
    1.0-15 bit dq delay value
    bit|   0 1 2 3 4 5 6 7 8 9
    0 |  9 9 9 11 7 9 8 6 7 7
    10 |  9 11 8 9 8 8
    2.dqs window
    x=pass dqs delay value (min~max)center
    y=0-7bit DQ of every group
    input delay:DQS0 =33 DQS1 = 34
    bit   DQS0   bit   DQS1
    0 (1~65)33 8 (1~61)31
    1 (1~65)33 9 (1~64)32
    2 (1~65)33 10 (2~66)34
    3 (1~64)32 11 (1~62)31
    4 (1~65)33 12 (1~64)32
    5 (1~65)33 13 (1~62)31
    6 (1~64)32 14 (1~66)33
    7 (1~66)33 15 (1~62)31
    3.dq delay value last
    0 |  9 9 9 12 7 9 9 6 10 9
    10 |  9 14 10 12 9 11
       TX perbyte calibration
    DQS loop = 15, cmp_err_1 = ffff0000
    dqs_perbyte_dly.last_dqsdly_pass[0]=15, finish count=1
    dqs_perbyte_dly.last_dqsdly_pass[1]=15, finish count=2
    DQ loop=15, cmp_err_1 = ffff0000
    dqs_perbyte_dly.last_dqdly_pass[0]=15, finish count=1
    dqs_perbyte_dly.last_dqdly_pass[1]=15, finish count=2
    byte:0, (DQS,DQ)=(8,8)
    byte:1, (DQS,DQ)=(8,8)
    DRAMC_DQODLY1[200]=88888888
    DRAMC_DQODLY2[204]=88888888
    20,data:88
    [EMI] DRAMC calibration passed
            MT7621  stage1 code done
    U-Boot 1.1.3 (Aug 18 2020 - 11:10:29)
    Board: Ralink APSoC DRAM: 128 MB
    Power on memory test. Memory size= 128 MB...OK!
    relocate_code Pointer at: 87fb0000
    Config XHCI 40M PLL
    RT2880_RSTSTAT_REG 0xc0030000
    Board power on Occurred
    flash manufacture id: ef, device id 40 18
    find flash: W25Q128BV
    Ralink UBoot Version: 5.0.0.0
    ASIC MT7621A DualCore (MAC to MT7530 Mode)
    DRAM_CONF_FROM: Auto-Detection
    DRAM_TYPE: DDR3
    DRAM bus: 16 bit
    Xtal Mode=3 OCP Ratio=1/3
    Flash component: SPI Flash
    Date:Aug 18 2020 Time:11:10:29
    icache: sets:256, ways:4, linesz:32 ,total:32768
    dcache: sets:256, ways:4, linesz:32 ,total:32768
     ##### The CPU freq = 880 MHZ ####
     estimate memory size =128 Mbytes
    #Reset_MT7530
    set LAN/WAN LLLLW
    restore_defaults:0
    Please choose the operation:
      1: Load system code to SDRAM via TFTP.
      2: Load system code then write to Flash via TFTP.
      3: Boot system code via Flash (default).
      4: Entr boot command line interface.
      7: Load Boot Loader code then write to Flash via Serial.
      9: Load Boot Loader code then write to Flash via TFTP.
      n3: System Boot system code via Flash.
    Booting System 1
    Erasing SPI Flash...
    raspi_erase: offs:30000 len:10000
    Writing to SPI Flash...
    done
    ## Booting image at bc180000 ...
      Image Name:  MIPS OpenWrt Linux-3.10.14
      Image Type:  MIPS Linux Kernel Image (lzma compressed)
      Data Size:  1690519 Bytes = 1.6 MB
      Load Address: 81001000
      Entry Point: 81387e90
      Verifying Checksum ... OK
      Uncompressing Kernel Image ... OK
    done
    commandline uart_en=1 factory_mode=0 mem=128m root=/dev/mtdblock9
    No initrd
    ## Transferring control to Linux (at address 81387e90) ...
    ## Giving linux memsize in MB, 128
    Starting kernel ...
    LINUX started...
     THIS IS ASIC
    SDK 5.0.S.0
    [  0.000000] Initializing cgroup subsys cpuset
    [  0.000000] Linux version 3.10.14 (jenkins@327eefce2db8) (gcc version 4.8.5 (crosstool-NG crosstool-ng-1.22.0) ) #1 MiWiFi-R4A-3.0.24 SMP Tue Aug 18 11:17:57 UTC 2020
    [  0.000000]
    [  0.000000] The CPU feqenuce set to 880 MHz
    [  0.000000] GCMP present
    [  0.000000] CPU0 revision is: 0001992f (MIPS 1004Kc)
    [  0.000000] Software DMA cache coherency
    [  0.000000] Determined physical RAM map:
    [  0.000000] memory: 08000000 @ 00000000 (usable)
    [  0.000000] User-defined physical RAM map:
    [  0.000000] Initrd not found or empty - disabling initrd
    [  0.000000] Zone ranges:
    [  0.000000]  DMA   [mem 0x00000000-0x00ffffff]
    [  0.000000]  Normal  [mem 0x01000000-0x07ffffff]
    [  0.000000] Movable zone start for each node
    [  0.000000] Early memory node ranges
    [  0.000000]  node  0: [mem 0x00000000-0x07ffffff]
    [  0.000000] Detected 3 available secondary CPU(s)
    [  0.000000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
    [  0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
    [  0.000000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
    [  0.000000] PERCPU: Embedded 7 pages/cpu @8160e000 s6912 r8192 d13568 u32768
    [  0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
    [  0.000000] Kernel command line: console=ttyS1,115200n8 uart_en=1 factory_mode=0 mem=128m root=/dev/mtdblock9
    [  0.000000] drivers/mtd/mtdpart.c mtd_init_bootos 1085
    [  0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
    [  0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    [  0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    [  0.000000] Writing ErrCtl register=00068000
    [  0.000000] Readback ErrCtl register=00068000
    [  0.000000] allocated 262144 bytes of page_cgroup
    [  0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
    [  0.000000] Memory: 124392k/131072k available (3657k kernel code, 6680k reserved, 993k data, 272k init, 0k highmem)
    [  0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [  0.000000] Hierarchical RCU implementation.
    [  0.000000] NR_IRQS:128
    [  0.000000] console [ttyS1] enabled
    [  0.150000] Calibrating delay loop... 577.53 BogoMIPS (lpj=2887680)
    [  0.210000] pid_max: default: 32768 minimum: 301
    [  0.210000] Mount-cache hash table entries: 512
    [  0.220000] Initializing cgroup subsys memory
    [  0.220000] launch: starting cpu1
    [  0.230000] launch: cpu1 gone!
    [  0.230000] CPU1 revision is: 0001992f (MIPS 1004Kc)
    [  0.230000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
    [  0.230000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
    [  0.230000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
    [  0.290000] Synchronize counters for CPU 1: done.
    [  0.300000] launch: starting cpu2
    [  0.300000] launch: cpu2 gone!
    [  0.300000] CPU2 revision is: 0001992f (MIPS 1004Kc)
    [  0.300000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
    [  0.300000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
    [  0.300000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
    [  0.360000] Synchronize counters for CPU 2: done.
    [  0.370000] launch: starting cpu3
    [  0.370000] launch: cpu3 gone!
    [  0.370000] CPU3 revision is: 0001992f (MIPS 1004Kc)
    [  0.370000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
    [  0.370000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
    [  0.370000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
    [  0.430000] Synchronize counters for CPU 3: done.
    [  0.440000] Brought up 4 CPUs
    [  0.440000] devtmpfs: initialized
    [  0.450000] NET: Registered protocol family 16
    [  0.750000] release PCIe RST: RALINK_RSTCTRL = 7000000
    [  0.750000] PCIE PHY initialize
    [  0.750000] ***** Xtal 40MHz *****
    [  0.760000] start MT7621 PCIe register access
    [B]freezes around here though not sometimes it goes a little bit further[/B]
    • 31267
    Re: Xiaomi router freezes at boot after re-capping
    "NOBBY" ??
    wtf is that?
    do it again - use panasonic FR or rubycon ZL or some other decent low esr caps
    and you added an extra cap not in the original picture - that may have been unwise unless you know what it connects with.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Agree with stj, I would also clean the board because it looks like shit, electrolyte might have leaked on it and that is conductive...
      • hinisa
        • Apr 2021
        • 19
        • turkey
        Originally posted by stj
        "NOBBY" ??
        wtf is that?
        Unfortunately there's only 1 place in town who sells small caps and only this no-name crap.
        Extra cap is "cost optimization" by Xiaomi. It's populated in older revisisons
        I actually also have the older revision and I've checked before installing they're exactly same caps (kys 470uf 25v), only differ in quantity.
        Already cleaned in the 2nd pic.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          The original small caps looks to be LOW ESR 105°C rated capacitors.
          Your replacement look to be general purpose 85°C capacitors.
          If you are unable to get better capacitors a test could be to stop the boot process and load a firmware image via TFTP server and see if the unit works.
          Because it is possible the firmware became corrupted when the caps got bad...
            • 31267
            if that uses a 12v psu then you could possibly scavenge some 16v caps from an old motherboard.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              hmm
              "LE PET"!
              • csh
                • Mar 2015
                • 38
                • Croatia
                Interesting, I got the same router but the first revision from 2019, bought early 2020. Been working 24/7 first as a router, then as dumb access point, flashed with openwrt. Rock stable, newer any problem with it.
                This is the second forum post with blown caps on the newer revision (there is one post also on openwrt forum).
                On newer revisions Xiaomi omitted shielding from the SOC and wifi chips and one of the larger caps on the input.
                Could it be that OP's router blew the caps because of one cap less on the input?
                I opened my router today, all caps are OK, no bulging, measured in place as 925 uF for larger input ones (470 uF, 25V) and the ESR of 0.08. The smaller caps are 470 uF 10V, measured 954uF and 0.12 ohm ESR. Both pairs are in parallel so the measurement is not accurate.
                • harp
                  • Jun 2022
                  • 645
                  • Planet Earth
                  I think that is not anymore problem capacitor and their quality, but previous leaking spillage under cristal, ic and small component... on many point you can see joint plague, and function of these is highly questionable, connections is unreliable or broken or partialy shorted due to stalled residue under its legs. It is realy no point to repair such condition, maybe is firmware corupte and so on...
                  It is good reminder that 24/7 router should hang on wall respect to capacitors
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5084
                    • New Zealand
                    Love the deranged names of these caps. Nobby? LE Pet?
                    Ironic that the one called KYS was the only one that wasn't dead...
                    -David VanHorn
                    • m1ch43lzm
                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                      by m1ch43lzm
                      Hi everyone
                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                      There's also an extra OTP Secu.R...
                      09-06-2025, 05:47 PM
                    • dragometin
                      Hitachi 40HYC42
                      by dragometin
                      TV Model: Hitachi 40HYC42
                      Power Supply: 17IPS71
                      MainBoard: 17MB95M
                      Panel: VES400UNDS-2D-NO3
                      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                      Is there any variants on 17IPS71 power supply's?
                      UART output pins 10 and 12 on scart connector:
                      Code:
                      12:24:04.595
                      08-08-2024, 05:53 AM
                    • Curious.George
                      FYI: Reflashing Cisco AP1142
                      by Curious.George
                      This is an AIR-LAP1142N-A-K9 powered directly from a Cisco brick (48V).
                      Console cable connected to "Console" port.
                      Network cable (10.0.1/24) connected to "Ethernet" port.
                      Terminal (emulator) connected to console cable (9600 8N1 noflow).
                      Hold MODE button depressed while applying power. Watch terminal output for "button is pressed, wait for button to be released..." message. This will appear after about 20 seconds (LED indicator will change just about that same time). Release button at this point.
                      The terminal session,...
                      09-22-2018, 05:53 AM
                    • mrsdsdsdsd
                      usb flash drive "0 Bytes" - data recovery
                      by mrsdsdsdsd
                      hello
                      i've got a usb flash drive which is no longer recognized by the pc, diskpart report "No media" and its capacity is 0 mbytes
                      i was wondering if i can remove the nand chip and put in another device of the same model, will it work ? can i recovere the data from it ?
                      i need the stored data i don't really care about the device
                      thank you !
                      09-25-2022, 06:54 AM
                    • 6BW6
                      Win7 Performance test stops
                      by 6BW6
                      I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
                      Problem signature:
                      Problem Event Name: APPCRASH
                      Application Name: WinSAT.exe
                      Application Version: 6.1.7601.17514
                      Application Timestamp: 4ce798fc
                      Fault Module Name: atiuxp64.dll
                      Fault Module Version: 8.14.1.6463
                      Fault Module Timestamp: 56254af6
                      Exception Code: c0000005
                      Exception Offset: 000000000000dc14
                      OS Version: 6.1.7601.2.1.0.256.48...
                      05-29-2023, 04:21 PM
