LG 27GL63T-B completely dead
  • didinos
    • Nov 2017
    • 3
    • france
    #101
    régulateur changer + cpu😏
    • Pandor
      • Oct 2016
      • 24
      • Belgium
      #102
      I finally had some time to have a look at replacing the CPU. And it worked.
      So for me, the fix was replacing IC401 with MP2122AGJ + CPU.
      So i can finally vouch for the aliexpress link i posted. The CPU is good.
      • Pickanick64
        • Nov 2024
        • 3
        • Italy
        #103
        Hi all!
        Im here for the same problem, 27gl650 dead...
        I think my problem is IC401, it gets extremely hot in less than a second.
        Reading here, the MP2122GJ can be better than the original and perfect for a replacement.
        However, I would also like to order some spare ICs for IC402 and IC400 but i can't find what they are.
        I have IAGCN for the 402 and IAQTP for the 400.
        Can someone help me identifying those?
        Thanks!
        PS. I have a lot of cap shorted to gnd around the 401, like C438 C439 C444 C403 C401... i will desolder the ic and test again later in the day
        • Pickanick64
          • Nov 2024
          • 3
          • Italy
          #104
          Removed IC401, all shorts on caps disappeared!
          Ordered new components for IC401 and 402 (not shure if is working or not).
          For the C508 shorted near the audio jack: if you plug a jack, the short will go away. i think is intended to work this way.
          • Pickanick64
            • Nov 2024
            • 3
            • Italy
            #105
            Great news, found some MP9148 (the original IC401) lying around and tried to replace it: MONITOR WORKING!
            I take some measurement for the IC401, 402 and 400 if someone need them, from pin1 to pin8:
            400: 300mV 19V 3,3V 0V 8V 2,4V 5V 790mV
            401: 609mV 3,3V 1,1V 3,3V 0V 1,8V 5V 609mV
            402: 286mV 19V 12,8V 0V 15V 3,3V 4,8V 800mV
            • Christoph Mayer
              • Feb 2025
              • Deutschland
              #106
              My CPU, the big processor on the Board is getting very very hot until seconds.
              I cant find where to buy the PCB.
              I have an LG 27GL63T-B
              but my board is from LG 27GL650.
              My case only has ONE hdmi port.
              where can i buy an PCB compatible with mine?
              I can also buy an PCB with 2 HDMIs instead of 1.
              I think if its working i can modify the case if needed.
              The seller from non business has already opened the TFT i think.
              The TFT is from 2019. On the Board is written 2022 and some screws are missing and so on.
              • Dency
                • Apr 2025
                • Hungary
                #107
                Hey guys. I got a dead LG 27GL650F-B monitor (no power). So i readed this thread and checked the IC401 voltages. On the pin3 missing 1,2V and pin6 missing 1,8V. In my country only availabe the MP2122AGJ component. Succesfully changed the IC401 and the monitor started working. WOW! Thank you guys for the information. Great community.
                • Andrés Beyer
                  • Apr 2025
                  just in case you guys still need this... i have my monitor with no power same as many here but my electronics knowledge is really bad...
                  • besheniy_suslik
                    • May 2025
                    • Russia
                    #109
                    Hello. IC402 what is the name of the chip?
                    • lotas
                      • Jan 2016
                      • 4863
                      • Russia
                      #110
                      IC402 = AGC = MP2315
                      https://www.monolithicpower.com/en/d...cument_id/513/
                      • Sebastian McCarroll
                        • May 2025
                        I am looking to replace IC 201, and IC 202 but I believe the links are dead. If anyone knows where to find these please let me know.
                        • besheniy_suslik
                          • May 2025
                          • Russia
                          #112
                          Is it possible to insert EAX68524501 (1.4) instead of EAX68524502 (1.1)? Will it work?
                          • dbuergi
                            • Jul 2024
                            • 139
                            • Deutschland
                            #113
                            my 27GN750 also died. The board shows 4 hotstops.
                            IC202 (CPU), IC701 (marked TUSB8041I) and both buck converters close to the two bigger chips. The one under the CPU in my pic is the biggest hotspot. Would you change the converters before changing the CPU? Around 40c on the CPU doesn't seem too hot since it also has a big cooling pad.
                            • lotas
                              • Jan 2016
                              • 4863
                              • Russia
                              #114
                              Well, 40 degrees on the processor doesn't mean anything (this is a normal temperature, when it works its temperature is even higher), it's the processor that should be heating up, you need to check the voltage and resistance on these inductors relative to the ground.
                              • dbuergi
                                • Jul 2024
                                • 139
                                • Deutschland
                                #115
                                Thank you for your help. I had too much focus on the thermal cam. I found L407 (in by board L408) short. Removed the inductor and got 24 ohm back. So should be fine for a low voltage rail? Short on converter side stays.
                                • dbuergi
                                  • Jul 2024
                                  • 139
                                  • Deutschland
                                  #116
                                  Working again! I replaced IC402 and IC700 and got a standby LED.
                                  Just in case anybody else has this fault. All components in my thermal pic have around 45c with the CPU beeing the hottest spot.
                                  But the fault is caused by the buck converter.
                                  • Zulfi2212
                                    • Sep 2025
                                    • South Africa
                                    #117
                                    Had the same issue with my board, no output from IC401.
                                    Managed to get the MP9148GJ-Z replacement for IC401 from Ali Express. did take 6 weeks to arrive.
                                    Ordered this from Ali Express https://www.aliexpress.com/item/1005...5ef91802li8sFa
                                    luckily i ordered a batch of 10 of these IC's, pricing was great from Ali Express, i replaced the chip, but still had no output, only after replacing the chip by the 3rd time i managed to come right and had output from IC401, hence why i say luckily i had ordered 10 IC's. which means 2 of them were DUD's .
                                    After i had output from IC401, the screen worked. lets hope it stays that way.... Fingers crossed.
                                    I do want to thank all those whom took the time to explain and help with diagnosing the problem, without this article, i would have still been looking at the board and scratching my head
                                    • dinutzmtv
                                      • Jan 2014
                                      • 3
                                      • Romania
                                      #118
                                      LG 27GL63T-B - EAX68524502(1.1) - IC401 = IAKXM. L407 - 1v2 and L408 - 1v8. Shorted to GND on L407, but only when you plug it in, not always. I used LM1117 for 1v8 and an ups from Aliexpress for 1v2. It's not the only one that i repaired this way (when was about IC401), so you can trust this method.
                                      • max-power
                                        Dell E6540 laptop completely dead after dssasembly
                                        by max-power
                                        Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                        that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                        After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                        03-24-2025, 08:49 AM
                                      • wangbreeze
                                        T480s random shutoff and then completely dead
                                        by wangbreeze
                                        Hello Gurus,
                                        I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                        I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                        Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                        charger gave - 20V - ok
                                        U101B
                                        02-03-2024, 04:57 PM
                                      • pavski
                                        Completely dead MSI z490 tomahawk
                                        by pavski
                                        Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                        I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                        t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                        Can you please let me know if this is indeed incorrect and what else should I look at next?
                                        Thanks!
                                        06-02-2024, 02:42 PM
                                      • Andreasbest
                                        Lenovo Thinkpad T14s completely dead.
                                        by Andreasbest
                                        Hello.
                                        I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                                        I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                                        Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                                        Thank you in advance!
                                        Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                                        03-19-2024, 03:18 AM
                                        Laptop computer that went completely dead no boot no power light no hard drive light
                                        by sam_sam_sam
                                        See pictures for type of laptop computer
                                        I checked switching power supply brick 19.2 volts multi meter only
                                        No booting without switching power supply connected
                                        Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                        What the heck is going on here...
                                        04-04-2025, 04:58 AM
