LG 27GL63T-B completely dead
  • didinos
    • Nov 2017
    • 3
    • france
    #101
    régulateur changer + cpu😏
    • Pandor
      • Oct 2016
      • 24
      • Belgium
      #102
      I finally had some time to have a look at replacing the CPU. And it worked.
      So for me, the fix was replacing IC401 with MP2122AGJ + CPU.
      So i can finally vouch for the aliexpress link i posted. The CPU is good.
      • Pickanick64
        • Nov 2024
        • 3
        • Italy
        #103
        Hi all!
        Im here for the same problem, 27gl650 dead...
        I think my problem is IC401, it gets extremely hot in less than a second.
        Reading here, the MP2122GJ can be better than the original and perfect for a replacement.
        However, I would also like to order some spare ICs for IC402 and IC400 but i can't find what they are.
        I have IAGCN for the 402 and IAQTP for the 400.
        Can someone help me identifying those?
        Thanks!
        PS. I have a lot of cap shorted to gnd around the 401, like C438 C439 C444 C403 C401... i will desolder the ic and test again later in the day
        • Pickanick64
          • Nov 2024
          • 3
          • Italy
          #104
          Removed IC401, all shorts on caps disappeared!
          Ordered new components for IC401 and 402 (not shure if is working or not).
          For the C508 shorted near the audio jack: if you plug a jack, the short will go away. i think is intended to work this way.
          • Pickanick64
            • Nov 2024
            • 3
            • Italy
            #105
            Great news, found some MP9148 (the original IC401) lying around and tried to replace it: MONITOR WORKING!
            I take some measurement for the IC401, 402 and 400 if someone need them, from pin1 to pin8:
            400: 300mV 19V 3,3V 0V 8V 2,4V 5V 790mV
            401: 609mV 3,3V 1,1V 3,3V 0V 1,8V 5V 609mV
            402: 286mV 19V 12,8V 0V 15V 3,3V 4,8V 800mV
            • Christoph Mayer
              • Feb 2025
              • Deutschland
              #106
              My CPU, the big processor on the Board is getting very very hot until seconds.
              I cant find where to buy the PCB.
              I have an LG 27GL63T-B
              but my board is from LG 27GL650.
              My case only has ONE hdmi port.
              where can i buy an PCB compatible with mine?
              I can also buy an PCB with 2 HDMIs instead of 1.
              I think if its working i can modify the case if needed.
              The seller from non business has already opened the TFT i think.
              The TFT is from 2019. On the Board is written 2022 and some screws are missing and so on.
              • Dency
                • Apr 2025
                • Hungary
                #107
                Hey guys. I got a dead LG 27GL650F-B monitor (no power). So i readed this thread and checked the IC401 voltages. On the pin3 missing 1,2V and pin6 missing 1,8V. In my country only availabe the MP2122AGJ component. Succesfully changed the IC401 and the monitor started working. WOW! Thank you guys for the information. Great community.
                • Andrés Beyer
                  • Apr 2025
                  just in case you guys still need this... i have my monitor with no power same as many here but my electronics knowledge is really bad...
                  • besheniy_suslik
                    • May 2025
                    • Russia
                    #109
                    Hello. IC402 what is the name of the chip?
                    • lotas
                      • Jan 2016
                      • 4710
                      • Russia
                      #110
                      IC402 = AGC = MP2315
                      https://www.monolithicpower.com/en/d...cument_id/513/
                      • Sebastian McCarroll
                        • May 2025
                        I am looking to replace IC 201, and IC 202 but I believe the links are dead. If anyone knows where to find these please let me know.
                        • besheniy_suslik
                          • May 2025
                          • Russia
                          #112
                          Is it possible to insert EAX68524501 (1.4) instead of EAX68524502 (1.1)? Will it work?
                          • dbuergi
                            • Jul 2024
                            • 126
                            • Deutschland
                            #113
                            my 27GN750 also died. The board shows 4 hotstops.
                            IC202 (CPU), IC701 (marked TUSB8041I) and both buck converters close to the two bigger chips. The one under the CPU in my pic is the biggest hotspot. Would you change the converters before changing the CPU? Around 40c on the CPU doesn't seem too hot since it also has a big cooling pad.
                            • lotas
                              • Jan 2016
                              • 4710
                              • Russia
                              #114
                              Well, 40 degrees on the processor doesn't mean anything (this is a normal temperature, when it works its temperature is even higher), it's the processor that should be heating up, you need to check the voltage and resistance on these inductors relative to the ground.
                              • dbuergi
                                • Jul 2024
                                • 126
                                • Deutschland
                                #115
                                Thank you for your help. I had too much focus on the thermal cam. I found L407 (in by board L408) short. Removed the inductor and got 24 ohm back. So should be fine for a low voltage rail? Short on converter side stays.
                                • dbuergi
                                  • Jul 2024
                                  • 126
                                  • Deutschland
                                  #116
                                  Working again! I replaced IC402 and IC700 and got a standby LED.
                                  Just in case anybody else has this fault. All components in my thermal pic have around 45c with the CPU beeing the hottest spot.
                                  But the fault is caused by the buck converter.
                                  • max-power
                                    Dell E6540 laptop completely dead after dssasembly
                                    by max-power
                                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                    03-24-2025, 08:49 AM
                                  • wangbreeze
                                    T480s random shutoff and then completely dead
                                    by wangbreeze
                                    Hello Gurus,
                                    I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                    I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                    Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                    charger gave - 20V - ok
                                    U101B
                                    02-03-2024, 04:57 PM
                                  • pavski
                                    Completely dead MSI z490 tomahawk
                                    by pavski
                                    Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                    I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                    t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                    Can you please let me know if this is indeed incorrect and what else should I look at next?
                                    Thanks!
                                    06-02-2024, 02:42 PM
                                  • Andreasbest
                                    Lenovo Thinkpad T14s completely dead.
                                    by Andreasbest
                                    Hello.
                                    I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                                    I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                                    Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                                    Thank you in advance!
                                    Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                                    03-19-2024, 03:18 AM
                                  • armini
                                    18VDC PSU completely dead - ZD-915 desoldering station
                                    by armini
                                    Hi everyone!
                                    Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                    Due to a lack of time, I set it aside and didn't look at it.
                                    Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                    According to replies in 18VDC PSU has dropped to...
                                    04-25-2023, 07:49 AM
