LG Flatron L1933TR again....
--- begin sig file ---
--- end sig file --- -
Re: LG Flatron L1933TR again....
Woke up a couple days ago to find my L1933TR would not turn on (power LED doesn't come on, screen doesn't light up, nothing). Googled looking for a fix and found this thread. I opened it up and sure enough C203, C204 and C207 are all bulging (Samxon GF(M)'s). I also checked the fuse with a multimeter which is intact. I figure I'll go ahead and replace all seven Samxon GF(M)'s while I'm at it (the ones listed in the first post). I've put together an order on digikey as follows:
1x Panasonic FM 470uF 25V
1x Panasonic FM 680uF 25V
2x Panasonic FM 1000uF 16V
2x United Chemi-Con KZH 1000uF 25V
1x United Chemi-Con KZE 33uF 63V
Would these be suitable replacements for the Samxon GF(M)'s or are there better quality/value caps I should look at? Also is there anything I'm missing?
Much appreciate your help.Last edited by Rayne; 07-30-2013, 05:30 PM.Comment
Those caps are fine for this application. I myself use FM series for all my repair that required low ESR caps.Never stop learning
So I got the caps today, went ahead and did the swap, plugged everything back together before reassembly and turned it on. Power LED came on along with the backlights however screen was blank like with klaxon44. Display detected on my computer fine and the backlights powered up when I moved the mouse over to the screen but it was blank. Turns out stupid me had the connector that plugs into the display from the logic board upside down. Flipped it around and everything works just great.
I just wanted to thank everyone who contributed to this thread and cap recommendations. It's great to get my display back up and running for only $7.94.Comment
Great!Never stop learning
I want to post a thank you. I ran across this thread from a Google search on this monitor. I replaced the caps and I'm using the monitor to type this. Money is a little tight right now so this was greatly appreciated.
I used the FM series caps listed above but the EE I work with suggested I go with caps rated for a higher voltage. I used 35V caps for both the 16V and 25V 1000uf caps and doubled the voltage rating for all the others. Here is my Digikey parts list:
1x P12400-ND CAP ALUM 470UF 50V 20% radial
1x P12402-ND CAP ALUM 680UF 50V 20% radial
4x P12405-ND CAP ALUM 1000UF 35V 20% radial
1x P10771-ND CAP ALUM 33UF 100V 20% radial
Everything fit into the original spot although it was a little tight.Comment
by BitviveHi
My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find...1 Photo-
by sam_sam_samHere is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...-
Channel: General Capacitor Questions & Issues
by frannyjunkHi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
Any thoughts if OK to use these higher voltage capacitors? -
1000uf 120v 46mmx18mm or something close, Thanks3 Photos
by awdrifterI just bought some 1000uF 10v capacitors from eBay to fix my Samsung 2220WM, but it seems like they are already bulging? Are they ok to use? Thanks....
- Loading...
