Sceptre x22wg-Gamer 22" LCD
Re: Sceptre x22wg-Gamer 22" LCD
PlainBill says he usually limits himself to Panasonic FC and FM series. Digikey doesn't have the FC or FM for my 470uF 25v 105C 8mm x 16 with 3.5mm spacing, but they have an FR series 470uF 25v 105C that is 8mm x 15 x 3.5 (here http://search.digikey.com/scripts/Dk...name=P14417-ND). Is there any issue with the Panasonic FR series that should cause me not to consider it? It even has an 8000 Hrs @ 105C Lifetime @ Temp rating.Comment
I think FR has too high of an ESR. You need to match the series properly.
If you want a list of the exact type of capacitors and part numbers from digikey for this monitor, let me know, I have already ordered and recapped it. My list also includes the primary capacitor and all the capacitors on the logic board.Comment
QTY P/N
2 P12366-ND Panasonic FM replaces Taicon HF
4 P12389-ND Panasonic FM replaces Capxon KF
1 565-1469-ND OPTIONAL (Big expensive capacitor)
1 493-1575-ND Nichicon HE replaces Capxon GL
1 493-1522-ND Nichicon HE replaces Jackcon LHK
2 493-1578-ND Nichicon HE replaces Jackcon LHK
4 493-1547-ND Nichicon HE replaces Jackcon LHK
2 493-1548-ND Nichicon HE replaces Jackcon LHK
2 565-1599-ND UCC KY replaces Jackcon General Purpose
1 493-1887-ND Nichicon PW replaces Jackcon General Purpose
When I ordered there was stock of everything.Comment
I also have a Sceptre X22WG-Gamer 22" monitor that is experiencing issues. Mine is much different than what I see posted here however. When I power on my monitor I will see pink and green dots all the display which I guess are pixels that arent changing color properly. After the monitor is on for awhile the dots mostly go away and are less aparent. Im a PC Tech so i've already made sure its not a video card or dvi cable issue ruling that out completely. Experienced this with the HDMI port also. I have NOT seen it happen while using the vga port. I've taken apart the monitor and inspected both the video board and the power board and didnt see any leaking or bubbled caps or burnt out resistors. Does anybody have any ideas ?? Im at a total loss here.Comment
2) Post pictures using the manage attachments feature and please do not post pictures inline as they slow down the loading of pages.
3) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
4) Here is an example of the pictures we want.
https://www.badcaps.net/forum/showpo...94&postcount=1--- begin sig file ---
--- end sig file ---Comment
Panel: AUO M220EW01 V.0 TN Film
Power Supply: FSP050-2L02 3BS0144112GP REV:1 E116921 K3502 2SK3502 SG6841SZ BI3101A
Video Board: AL012 REV.1 MTK810NGD MST9251DA-LF-165
Inverter Transformer: SPI 8TC00291
Another revision of the FSP050-2L02 uses a set of 4 transformers similar to the SPI 8TT00006.
Disassembly:
Do not remove 3 black angle head screws in back near connectors
Split front with putty knife working from any corner, no force extract LED from front cover
Panel: 4 gray angle head
Power Board: 2 gray plastic thread, 2 gray machine thread, 1 gray machine thread to ground lug
Video Board: 4 gray plastic thread, 4 VGA standoff, 1 gray machine thread at HDMI connector
Reassembly: Ensure all buttons click. Unfortunately the monitor must be mostly reassembled to test.
Bulged caps on power supply:
C551, C552: CapXon 470uf 25v (runs at 5v, good ESR=0.05, bad esr>=1.1)
Other caps that did not fail yet:
C664: CapXon 470uf 25v (runs at 12v)
C554: CapXon 470uf 25v (runs at 5v)
C1, C661: Taicon 1000uf 16v (runs at 12v)
C210: CapXon 33uf 35v (runs at 12v)
The video board has a dark spot near C37. C37 tests good.
C37: Jackcon 47uf 25v, esr=0.06 in circuit, esr=1.1 out of circuit
This TN Film panel running on DVI is as clear as my PVA monitors with excellent bleed control.
One person here on badcaps was able to fix their x22wg-Gamer entirely from the debug menu.Comment
Well, I got my new caps in today and replaced them and my monitor now works perfectly. Another success story due to all the great help on this site. Thanks much to everyone, especially retiredcaps, and keep up the great work with the site.Comment
I have X22WP-1080p that is working perfectly, however, I had a housefire that started in another room, but the heat got to my monitor and melted the top of the case.
My question is... does anyone know where I can get another case?
ThanksComment
The only thing I can think of is to keep an eye open on Ebay for a similar model with a broken screen. Once you purchase it, strip it down for parts and use the case for your repair and resell the power supply and logic board to help offset your initial cost.Comment
Add another success story to the list!! I replaced the four CapXon 470uf 25v, the two Taicon 1000uf 16v, and the CapXon 33uf 35v and it's working flawlessly on the VGA.
It's still a no go on the DVI and HDMI connection but I'm not going to pursue getting them to work based on mockingbird and PlainBill's experience to date with bird's connections, but I will stay tuned.
Thanks again to all you guys!!! Also, the DigiKey experience was excellent.Comment
I no longer have the screen, but I'm still interested if someone gets the DVI and HDMI working...
Why didn't you end up also recapping the logic board? Not that you should, in fact, since it's working, I suggest you don't. It's very easy to destroy the logic board because it's a lot more difficult to solder than the PSU.Comment
I did go ahead and buy the caps for the logic board (that you included in the parts list) when I ordered the power board caps but just opted to call it a day while I was ahead. If it has problems later, I'll re-think it.
Thanks again!Comment
The dark spot (overheated?) on the board in photo 2 of the orig. post corresponds with component U4 (regulator?) on the other side of the board, photo 1. I have the same board with the same dark spot and my U4 looks like it overheated (not uniform in color). I also have some failed/bulging capacitors on the power board. I am thinking I'll replace the logic board also.
Now if I can find one. Nothing on ebay.Comment
Went to turn on monitor and got a loud pop noise. It cycles in 2 second intervals making a buzz. I figure a cap or two went bad on the power supply. Can anyone see if C551 and C552 are bad? Thanks
http://i.imgur.com/v3wHU.jpg
http://i.imgur.com/qozDx.jpg
http://i.imgur.com/QTJn3.jpgComment
I tested the ESR on all the caps on my Sceptre X22wg-Gamer monitor's power supply and C551 and C552 were the only ones that were questionable. In my case, like the pictures provided by severach in the first posting of this thread, my C551 and C552 caps were the only ones bulging.
I decided that since my C551 and C552 were obviously failing (bulging) and the ESRs on the other caps seemed reasonable, that I was going to only replace the TWO caps.
Total cost of my repair parts was approx. $5 from Digikey.
My monitor is working fine.
From severach's posting:
>"Bulged caps on power supply:
>C551, C552: CapXon 470uf 25v (runs at 5v, good ESR=0.05, bad esr>=1.1)"Comment
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 05:20 AM
This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...09-07-2024, 12:10 AM
by Mad_ScienceI have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
03-01-2024, 05:05 PM -
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... -
by spirittooTrying to fix a backlight problem with a Sceptre 48" TV.
I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
Anyone know how I can remove those leds without damaging them? - Loading...
