Dell 1707FP no power
  • 3d0
    • Jan 2014
    • 159
    • BiH
    #41
    Re: Dell 1707FP no power
    Hi guys, I have the same problem.
    Can someone please confirm that the power supply is ok, before I orded a logic board.
    I have tested it and found that all voltages are the same as terry and bob12345 have.
    • selldoor
      Slow Learner
      • 7870
      #42
      Presumably you expect us to trawl back through the thread ??
      Well I'm not going to.
      • 3d0
        • Jan 2014
        • 159
        • BiH
        #43
        Here's what someone suggested:
        Measure the voltage on the three pins of U404. Also, there are three voltage regulators to investigate. Measure the voltage on all three pins of U601, U602, and U902.
        PlainBill
        Done all of that, and the measurements are:
        U404:
        Pin 1: 0V
        Pin 2: 0V
        Pin 3: 1.24V
        U601:
        Pin 1: 0V
        Pin 2: 5.21V
        Pin 3: 1.24V
        U902:
        Pin 1: 0V
        Pin 2: 0V
        Pin 3: 0V
        Pin 4: 0V
        U602:
        Pin 1: 0V
        Pin 2: 0.4V
        Pin 3: 1.24V
        Pin 4: 0.4V
        Here's a image of the logic board. I think the power supply is somewhat ok, since the LB has voltage on certain points. Just need someone more smarter then me to confirm that.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4466
          • Italy - Milan
          #44
          Hi 3DO (old console lover eh!) unfortunately the OP did not continued to update this thread, after all the effort Plain Bill had put, i think you have to do the tests P.B. suggested to know if it is worth to replace the regulator/s, then post back the results. P.B. don't noticed and added that there is an onboard usb hub then maybe its normal that U902 (if i remember) doesn't take and give power, another test you can do is to put an external 3,3v like the one from an ATX psu to the U601 output and see if mon. works.
            OK, lets get the pinout of the voltage regulator (1117 series) correct first, see the info here:
            https://www.badcaps.net/forum/showth...579#post406579
            Then report the reading according to the pins.
            Looking at it with big tab up (big tab is tied internally to the center pin), left pin is 1 (adj/Gnd), Middle is 2 (output), right is 3 (input).
            Voltage between pin1 and pin2 will always be 1.25V.
            • 3d0
              • Jan 2014
              • 159
              • BiH
              #46
              Thanks guys for your time and interest in this crapy old monitor.
              Davi.p it does have a external usb hub.
              Maybe after these readings we should try to put 3.3V on the output pin like you said, do I have to take the ground form the ATX PS and solder it on to the gnd on the logic board. Stupid question but just want to double check before I fry something.
              So I measured the 1117R-33 voltage reg.
              pin1-Left pin= 0V
              pin2-Middle pin= 1.24V and every second or so it jumps to 1.25V (it should be 3.3V correct?)
              pin3-Right pin= 5.24V
              Thanks again.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4466
                • Italy - Milan
                #47
                "Thanks guys for your time and interest in this crapy old monitor."
                I don't like these words, don't seem a crappy one to me..
                "Maybe after these readings we should try to put 3.3V on the output pin like you said, do I have to take the ground form the ATX PS and solder it ..." Yes you must..
                For the rest i told you that thus regulator must be pulled out like PlainBill suggested.. read the rest..
                • 3d0
                  • Jan 2014
                  • 159
                  • BiH
                  #48
                  It's not going to be crappy if we fix it, right!
                  I read the thread a couple of times, English is not my native language, plus I'm a noob at electronics so it's quite hard. After your & budm post I'm starting to understand more about these logic boards and how they function.
                  So, I'm going to pull out an old atx ps, and try what you said, I'll report back the findings.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4466
                    • Italy - Milan
                    #49
                    wait wait wait... don't do that first, first you have to desolder the U601 and test it outside circuit, i refer to what said P.Bill that is an expert, give it a Vin of 5v and a load resistor of 25ohm, test the central pin, if it is good 3,3v the fault is still on the board, so test the connected alluminium caps for short..
                    • 3d0
                      • Jan 2014
                      • 159
                      • BiH
                      #50
                      Oh crap, I have already done it while the U601 was in the circuit!
                      But you where right, the lcd did turn up, so that's good to know.
                      The next step is to desolder U601 and test it, but before that I need to figure out how to give it a Vin of 5V with a load resistor of 25ohms? Total noob pls forgive me, I guess I'll find a explanation somewhere on the forum.
                      Do you mean the alluminium caps that are on the main psu, these circled in red on the picture?
                      Thanks again.
                      • selldoor
                        Slow Learner
                        • 7870
                        #51
                        No - He means the Aluminium capacitors on the Main Board (the green one)
                        The capacitors that are connected directly to the Voltage Regulators like C604 and C607
                        English is not Davi,p' s first language either so its going to be difficult
                        • 3d0
                          • Jan 2014
                          • 159
                          • BiH
                          #52
                          Thanks for the explanation selldoor.
                          I took the 1117R-33 voltage reg out of the circuit, put 5.25V on the Vin pin, and the Vout has a reading of 4.4V?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4466
                            • Italy - Milan
                            #53
                            For the 5v you can use the psu board of the monitor detached from the rest, for the resistor i can't help you but 25ohm is an uncommon value, i think you can grab a 27ohm, red purple black gold stripes, solder on the regulator some test wires that you connect to psu and resistor..
                              "I took the 1117R-33 voltage reg out of the circuit, put 5.25V on the Vin pin, and the Vout has a reading of 4.4V?" That sounds like the Ground pin (pin1) is not connected to the ground.Bad input and output cap for the regulator can be bad and causes the output to Oscillate, so you do need to check those caps also.
                              • 3d0
                                • Jan 2014
                                • 159
                                • BiH
                                #55
                                Pulled both of the caps out, since I don't have a ESR meter, nor can I measure capacitance with my DMM I will replace them with new ones, also ordered a new voltage reg. Took a little risk, but hey.
                                Just need to wait for 10 days for the parts to arrive, hopefully that would be all that needs to be replaced, we will see I guess.
                                Thanks again guys, you're help is appreciated.
                                • 3d0
                                  • Jan 2014
                                  • 159
                                  • BiH
                                  #56
                                  Re: Dell 1707FP no power *SOLVED*
                                  Ok, so the Voltage regulator arrived (1117R-33) , replaced the old one and the monitor works now!
                                  Bought it on ebay:
                                  Sipex (Alpha) 3.3V/800mA Positive Voltage Low Drop-Out Regulator, Part Number: AS1117R-3.3TR
                                  Big thanks to davi.p, budm & selldoor for the help.
                                  Quick note: this is a Dell 1707Fpf model lcd, the original poster made a mistake in the title.
                                  • Borse2008
                                    Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                    by Borse2008
                                    Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                    I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display β€” it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                    • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                    • There’s
                                    07-15-2025, 04:55 AM
                                  • Mark01
                                    Dell Optiplex 7490 AIO - red power led after flash
                                    by Mark01
                                    Hi guys,
                                    This is my first post! πŸš€
                                    I have no idea what I’m doing, but I’m learning by trial and error.
                                    I’m currently working on a Dell Optiplex AIO 7490β€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                    07-04-2025, 12:54 PM
                                  • zlr8r
                                    Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                    by zlr8r
                                    hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                    Ill try and give as much info as I can.
                                    Dell Inspiron 17 (7786) Laptop
                                    Service Tag: 5J0NHT2
                                    Bios: 1.9.0
                                    When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                    Then it started getting weirder!
                                    Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                    12-12-2023, 09:31 PM
                                  • SuperJames
                                    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                    by SuperJames
                                    This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                    Specs
                                    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                    Backstory
                                    I bought this from eBay, from a wallpapering shop. Β£650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                    10-23-2023, 04:09 PM
