HP L1955 with Benq 48.L1A02.A00 inverter
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP L1955 with Benq 48.L1A02.A00 inverter
    Originally posted by retiredcaps
    You definitely have at least 3 bad capacitors. Replace them with high quality low ESR Panasonic FM or FR caps from digikey following PlainBill's instructions.
    I should have mentioned that you should replace ALL the electrolytic caps except the largest main filter cap. The main cap rarely, but not never, fails.
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by <danutzz>
      Sorry for that... I was in a hurry and had to do print-screen from jpg imported in Word because the original img. was made with 12 mpx camera and couldn't upload it like that
      Now THAT brings up an important issue. I've been using VuePrint for years for viewing and resizing pictures. It was quick and easy to use. Unfortunately it doesn't work properly under Win7 and is no longer supported.
      PlainBill
      • <danutzz>
        • Jan 2011
        • 8
        I'll also take that into consideration. Thanks'
        • <danutzz>
          • Jan 2011
          • 8
          Thank you for the hint, I didn't knew about this program . I have allready installed VuePrint and it works fine.
          Daniel
          PlainBill
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Another (free) one would be Irfanview. Been using that for almost a decade.
            Just make sure you untick all the toolbar crap that it wants to install on the newer versions..
            screenshot (of a screenshot )
            • PlainBill
              • Feb 2009
              • 7034
              Thanks for the suggestion. I'm looking into it.
              And it certainly looks good. Sounds like it might be able to replace Paint for my purposes.
              PlainBill
              • <danutzz>
                • Jan 2011
                • 8
                #27
                Good news... I have changed the 3 1000uF capacitors and resoldered all of the transformer pins and the result you can see in the attached image
                I will also change the rest of capacitors but there is still one problem left: I can hear some noise from the monitor (with almost constant frequency). Do you think that by replacing all the capacitors the noise will go away or is it another problem?
                Thanks,
                Daniel
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  The smallest cap next to the SMPS plays an important role in the startup process and could be making that noise.
                  Thus, the earlier recommendation from forum members to replace ALL the capacitors.
                  edit: Reminder you MUST resolder all the inverter transformer pins (the 4 yellow boxes). MANDATORY.
                  • donnsj
                    • Jul 2011
                    #29
                    I have the same monitor with the same inverter board (Benq 48.L1A02.A00). Which is toast. Monitor doesn't respond/turn on at all. Q812 was absolutely fried, and had actually lifted some of it's traces. So, I know so far I need to replace that part, 2 C5707s (shorted)(and i may replace all 4, just 'cause), resolder all 4 xformers (all 4 have cracked solder), and replace all the caps. Once that's done, check other parts around the damage, and see if there is any other questionable parts. Sheeesh.
                    The alternative is buying a whole replacement board(used) from one of the Hong Kong vendors on eBay, for about $30. Which is a crapshoot, in that it may need recapping anyway. And, maybe have to pay duty tax, etc. on top of that. not sure how that all works.
                    Does anyone have a soft version of the parts list/schematic for this board? I'd like to know where & what I'm probing. and what I need to buy for parts.
                    Thanks.
                    • jakdedert
                      • Jun 2010
                      • 19
                      "Here is where to solder the jumper wire I traced it out with a continuity tester. I checked those five other traces radiating from under the IC as well and they had no tie to the torn trace.
                      This was a very bad trace to tear it's part of the PWMs startup circuit . Run a jumper wire between the two points and the trace is repaired."
                      I know this is an old thread, but I just wanted to commend you Krankshaft, for going above and beyond. That was incredibly kind of you.
                      • bobbygg
                        • Oct 2012
                        • 5
                        • england
                        #31
                        hi,can you please tell me or show me with a photo where the 2 fu9024n fets are located,as i cant seem to find them on my board.thanks
                          @bobby, please post good clear pictures of your board, both sides.
                          • bobbygg
                            • Oct 2012
                            • 5
                            • england
                            #33
                            hi,budm,thanks for the quick reply.
                            please find enclosed 2 photos as requested.
                            i have a kit which includes 4xc5707,2x fu9024n,plus fuse.i have found where 4 xc5707 is located ,but not fu9024n,cant find them anywhere on board.
                            hope you can help.thanks
                              You have the wrong kit for your board version, the MOSFET in your kit has 3-pin MOSFET, your board uses 8-pin surface mounted MOSFET as you can see around the inverter section.
                              What is it not doing? What comes with the kit?
                              • bobbygg
                                • Oct 2012
                                • 5
                                • england
                                #35
                                hi budm,thanks for getting back to me.thanks for showing me where fets are.
                                monitor was bought secondhand earlier this year,it worked when i tested it,then was put in storage.went to use it last week ,it would flash for split second then dark blank screen.when you cut power and switched back on same thing would happen.
                                but since i posted first message i had a look at the power supply socket and all 3 soldered joints had just broke away from board. i have resoldered joints ,plus on/off switch terminals and i now have test pattern on screen.
                                so problem was just soldered joint.
                                time will tell if any other problems crop up.
                                in the meantime thanks very much for your help.
                                  Great, keep an eye on the board since they are browned in the output section which measn the oscillator may be running the wrong frequency due to bad tuning caps (gray rectangular caps by the transistors),or the DC filters are dying and letting through the AC ripple. See if the C5707/5706 are running hot. Also inspect all the solder joints, especially around the inverter transformers.
                                  • bobbygg
                                    • Oct 2012
                                    • 5
                                    • england
                                    #37
                                    hi budm,thanks for info.i am going to take board back out and solder around transformers etc.i have been in touch with supplier of kit and hopefully they will have right kit with the 8 legged mosfets.best to have a kit in case things go wrong.in the meantime thanks for all your help.regards
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #38
                                      If one/both of your 8 legged Mosfets did fail, then that is normally all you would replace.So I assume this 'kit supplier' is not offering other parts which no doubt will be totally unecessary ??
                                      • bobbygg
                                        • Oct 2012
                                        • 5
                                        • england
                                        #39
                                        hi,rtech.i have just got in touch to see if supplier has the 8 leg mosfets or can get them,but i have just had a good look on his website and i dont think they do.but as board now works i will resolder transformers etc and hope for the best.
                                        thanks for info.
                                        • eccerr0r
                                          inverter H tree driver imbalance in an AC inverter
                                          by eccerr0r
                                          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                          11-16-2025, 12:34 PM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
