HP 1955 Monitor Repair Guide
  • sermulis
    • Jul 2013
    • 38
    • Latvia
    #161
    Re: HP 1955 Monitor Repair Guide
    I got 29 V DC
      Right at the two legs? It cannot be that high!, The IC will not take that, your meter's battery is good? It is 15V zener diode.
      • sermulis
        • Jul 2013
        • 38
        • Latvia
        #163
        hmm. sometimes multimeter shows low battery indicator. measured one more time. same results. in 20 v range its out of range. will try to find another multimeter meanwhile.
          You need to change the battery.
          • sermulis
            • Jul 2013
            • 38
            • Latvia
            #165
            replaced battery. same results!
              Sorry to say, that cannot be, unless the Zener is open. As you can see in the circuit, that 15V Zener is for regulating the VCC for the SMPS IC to be at 15V max.
              • sermulis
                • Jul 2013
                • 38
                • Latvia
                #167
                I see.. is it wise idea replacing zener diode without going any further? may be mosfets Q602, Q603 are shortd too, as well as zener diode ZD602.
                p.s. sorry for spamming into forum. I am totally new in electric diagrams and repairs greater than simple cap replacing
                • sermulis
                  • Jul 2013
                  • 38
                  • Latvia
                  #168
                  on D602 i've got 10.9V
                  Sorry for measleading info. I measured standard diodes not zener ones.
                  Find proper ones
                  ZD601 - 10.2 V
                  ZD602 - 10.6 V
                    About 10VDC is correct voltage for NCP1200 SMPS IC to run. Check R615 Source resistor 0.22 Ohm for MOSFET Q601 to see if it is open. Check the DC voltage at the Drain pin of Q601 using C605 Negative leg as the ground ref point for this primary circuit section.
                    OK, just to sure, you are not getting any DC voltages on these caps?
                    • Behemot
                      • 4845
                      • CZ
                      #170
                      If there is NCP1200AP40, those are 40kHz version, hard to get. I just managed to buy 10 pcs so if anybody wants some…
                      • sermulis
                        • Jul 2013
                        • 38
                        • Latvia
                        #171
                        hmm. maybe i am doing smth absolutely wrong or problem is behind the power board? pinout differs on actual board versus schema. measurements was taken without logic board and lcd panel connected.
                          OK, the power supply is not dead after all since you are getting the 5V, so next step will be hooking up logic board back but leave the flat cable from the logic board that go to the panel and see if those voltage readings change or disappear, especially the 5VDC. one thing does bug me is that you are getting only 13V for the inverter, but then the sch does not match your board 100%.
                          I will need you to post good closed up pictures of your board, both sides so I can trace out the connections and compare it to the sch.
                          • Behemot
                            • 4845
                            • CZ
                            #173
                            The inverter should be getting 13-13,5 volts, at least that's what inverter in my piece was fed with and worked OK.
                            Than there is transistor step-down for +3,3 V, probably to directly feed ICs on logic board.
                              Can you tell me what voltage are you getting at those 4 locations?
                              Notes: number 4 location are 3 pins, report reading at those 3 pin with the monitor connected to running PC. One of those 3 pin is for BL_ON (Backlights ON), another pin is for Backlights Dimming control, the 3rd pin I do not know what that one is for.
                              • Behemot
                                • 4845
                                • CZ
                                #175
                                Yeah, may be all-in-one regulator, who knows…the thing is, if it works and gives +13something V, it should also give +3,3 to feed the logic board.
                                • sermulis
                                  • Jul 2013
                                  • 38
                                  • Latvia
                                  #176
                                  if i understood you right.. than
                                  V1 - 3.3V
                                  V2 - 4.97V (pin to GND)
                                  V3 - 5.07V (pin to GND)
                                  V4 - from left to right - 3.13V, 0.02V, 0.02V (each pin to GND)
                                  • sermulis
                                    • Jul 2013
                                    • 38
                                    • Latvia
                                    #177
                                    After all came to conclusion that my Power supply board IS OK.
                                    Cut and repaired old sleeve from logic board to control buttons.
                                    Connected all cables back. Now i am not able to see any diode indicator lights on control menu (diodes are OK). Pressing power on button seems doesn't work (silent dead monitor state).
                                    May be someone can provide Logic board chema for this HP 1955 ?
                                      Please post the pictures of the Logic board, both sides, so I can look for the SCH of your board version.
                                      • sermulis
                                        • Jul 2013
                                        • 38
                                        • Latvia
                                        #179
                                        Alright. Finally dealt with this monitor. After re soldering bad joints, and fixing cable to logic board, monitor came to life.
                                        • holoprox
                                          • May 2014
                                          #180
                                          1-st post here
                                          48.L1A02.A31 board
                                          changed all capacitors 1000 mF 16->25V
                                          ,22 160V (gray ones) with ,22 400~
                                          resoldered most of the board
                                          checked ZD601
                                          is it safe to switch on?
                                          hoq to check Q805 and Q812? between S and D? @200ohm?
