HP 1955 Monitor Repair Guide
Re: HP 1955 Monitor Repair Guide
Yes better pictures are needed.
The flashing of the PLED has me wondering if we are dealing with something shorting causing the power supply to restart over and over.
Even though the inverter fuse has not gone open, I am going to suggest removing it.
Would you remove the inverter fuse and see if the power button and PLED respond normally.
As a side note is anyone else watching this Ballgame?WOW!
Last edited by alexanna; 10-27-2011, 10:41 PM.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
Lets try that again shall we?
Here are some new full-surface pictures.
If you want there are fullsize pictures here... http://gkdv.se/bilder/Elektronik%20&...1030/Fullsize/
Update: I removed the fuse and the PLED didnt flash as it did before. I didnt get a a picture on the screen though.Comment
Did you check the driver FETs (C5707s) with a DMM in diode check mode for shorts? They clearly label the collector, emitter, and base on the boards silkscreen.
Look up bipolar transistor testing if you don't know how to test them.
You can't see a shorted transistor you have to check the junctions with a DMM. If I had a nickel for every person who said a semiconductor looked fine and dismissed it as an issue I'd be rich.
The only time there will be external damage to the transistor package is when a serious over current condition existed which caused the package to overheat.
The inverter is going into shutdown because one of the CCFLs isn't coming on.
Don't forget to resolder all of the inverter transformer pins, the pins on the two inductors, and the pins on the two gray poly caps in between the C5707 transistors.Last edited by Krankshaft; 10-30-2011, 05:19 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
Measure the SMD 4 pin 4431 Backlight On / Off FETs. Measure between source and drain do you get a reading in only one direction? Are any of them shorted?
Reference the datasheet for the pinout.
Also measure the resistance on the secondaries of the inverter transformers the resistances should all be similar on all of them.
Measure the resistance of the inverter fuse it should be a low resistance I've had ones that didn't blow but had a higher than normal resistance.
Check the board thoroughly for cracked solder joints especially around the inverter section.
If these check out it's beginning to look like an issue with the main video board that signals the inverter on.Last edited by Krankshaft; 11-01-2011, 03:53 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
Not for a short just check them in circuit.
No need for hot air either on such a small package. Just blob solder between 4 pins on one side. Insert a sewing needle under the pins while melting the blub and gently pull it up until the pins clear the blob.
For the other side blob up the pins grab with tweezers then remove the component.
This method is only for replacement of course.Elements of the past and the future combining to make something not quite as good as either.Comment
I measured the inverter fuse and it gave the resault of 0.05 ohms.
But what is the "secondaries of the inverter transformers" and where do I find it on the board?Last edited by krantz; 11-06-2011, 06:48 PM.Comment
I measured the signaling transistors that also is in the repair guide and I got some strange readings.
The left top gave me:
B-C: 0.724v
B-E: 0.730v
C-E: 0.762v
E-C: 0.780v
The left underneath gave me:
B-C: 0v
B-E: 0v
C-E: 1.660v
E-C: Open
The bottom left gave me:
B-C: Open
B-E: 0.733v
C-E: 0.977v
E-C: Open
The bottom right gave me:
B-C: 0.725v
B-E: 0.731v
C-E: 0.763v
E-C: 0.776v
Maybe some need to be changed?Last edited by krantz; 11-06-2011, 09:20 PM.Comment
I measured the SMD 4-pin 4431 Backlight ON/OFF FET's. From drain to source I got 0.535v-0.540v, and from source to drain i got overload.
But what is the "secondaries of the inverter transformers" and where do I find it on the board?Comment
There are 4 inverter transformers on your board. They're the yellow rectangular devices with multiple pins coming out each side. They appear to be labeled T801-T804. The secondary pins are numbered 8 and 10. With your meter set to resistance, measure across these two pins and post your results. Difference between the 4 transformer secondaries should be no more than 3%.
188.6 ohms
184.3 ohms
187.1 ohms
188.5 ohmsComment
The tranformer values seem a bit low, but are pretty consistent, so we'll assume that they're good.
Concerning your values for the signaling transistors. I'm assuming your testing the 3904 and 3906 transistors?
Let's try a different test for these transistors. Again, with your meter set to resistance, touch the black and red probe tips together. You should see something between 0 to 1 ohms. This is what you should expect to see if something were shorted. Now, check the transistors again with your probes across the following:
E-B
B-C
E-C
If you see a zero reading, then you have a short between those two legs of the transistor.Comment
There seems to be a lot of people who are mis-interpreting their multimeter readings.
1) A multimeter always gives a reading. "1" on the left hand side of the display means the reading is "out of range". 1.0 on the right side on the display is a unit of measure (i.e. 1 unit of measure). As you as you turn on the multimeter, it gives you a reading. There is no such thing as "nothing".
2) When testing for a short, put your multimeter on 200 (two hundred) ohms. Any reading under 30 ohms suggests a short. If your multimeter reads "1" on the left hand side, it is telling you that the resistance is greater than 200 ohms (out of range for the dial setting). At this point, we don't care what the actual resistance reading is. We know it is NOT less than 30 ohms and thus it is NOT shorted.Last edited by retiredcaps; 11-07-2011, 12:10 AM.--- begin sig file ---
--- end sig file ---Comment
I have allready taken pictures of the board on top and underneath and even given links to the full resolution pictures on my webserver.
Thanks for the info about the multimeter btw!Comment
If you get "1" or out of range, then those components are likely NOT shorted.Last edited by retiredcaps; 11-07-2011, 12:10 AM.--- begin sig file ---
1) Let's get a picture of the logic/main board.
2) What are the DC voltages on the connector from the power to main board? List all the pin number, its color, and the DC voltage. If there is a legend detailing the voltages, please also post a picture of that.--- begin sig file ---
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by corrizeHello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping... -
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... - Loading...
