HP 1955 Monitor Repair Guide
  • garrysoh
    • Sep 2010
    #41
    Re: HP 1955 Monitor Repair Guide
    I would just like to double check with someone on this forum regarding the signaling transistors (3904 and 3906) exactly which ones are the npn and pnp...I'm getting confused trying to measure in circuit as I have so many things blown. I've uploaded a copy of Krankshaft's picture (I hope that's okay) as a reference to the devices. I think the Q811 is the npn and the Q810 is the pnp (as pictured), but I can't figure out Q802 and Q803 (upper left side of the picture) as they are both damaged on my board....Can anyone help?
    Thanks in advance
    • pedro
      • 199
      • AUSTRALIA
      #42
      2N3904 is NPN and 2N3906 is PNP.
      Friends don't let friends buy Samsung ....
      • garrysoh
        • Sep 2010
        #43
        I'm sorry, but I guess my question wasn't clear. I know that the 3904 is the npn and the 3906 is the pnp, but I was looking for confirmation in circuit. I know that there is a pair (npn and pnp) is used for each FET. I also know the location on the board of each pair thanks to the picture that circles each pair. What I am not 100% sure on is which one, as shown in the picture, is the 3904 npn and which one is the 3906 pnp...
        Thanks in advance.
        • fiero79
          • Nov 2010
          #44
          I have one of these monitors and I am finding there is a buzzing coming from the inverter board. Near the entry of the 110v power supply. It could be coming from the transformer for the mains power, or the caps that are near the entry of the 110v. Does anyone have a part number for a replacement transformer? The one for the mains power, not the ones for each backlight supply.
          • alexanna
            • Mar 2010
            • 1346
            #45
            These inverter boards are noted for poor solder joints, if you haven't already I would suggest
            Re- soldering that area.
            Al.
            • Ron K
              • Sep 2010
              • 17
              #46
              Dear Help
              I have a burnt 40T03GP Power Fet and I found some but the second number is Different the ones that blew are 40T03GP and right under that number is 701085. But the ones I can get heve the numbers 40T03GP but the number under that one is 602425 are those fets ok to use. is the socond number of any value I googled the socond number and it never came up.
              Thank for your time
              Ron
              • jetadm123
                • 2169
                #47
                Originally posted by Ron K
                Dear Help
                Thank for your time
                Ron
                Yes, it's ok to use. The second line is usually manufacturing info like the month/year of manufacture, country of origin, hfe values, etc. Just remember to replace these in pairs, since different dates of manufacture usually indicate different hfe values.
                Also, are you sure the 40T03GP transistors were original to your board? If you look at post #1 of this thread, that board used 2SC5707 transistors. Of course, you might have a different board.....
                • Ron K
                  • Sep 2010
                  • 17
                  #48
                  Dear Helper
                  Yes it is a different Monitor and a different board then the Post #1
                  Is this usually the case with the second set of numbers and sometimes even a third
                  set.
                  Thanks for the help greatly apprecaited.
                  Ron
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    Dear Helper
                    set.
                    Ron
                    If it is another board and another monitor,what is it doing here (the post)?
                    There are 10 kind of people in this world: those that understand binary, and those who don't.
                    • ASUS ROG Maximus IX Code
                    • Intel Core i5-7600K 3.8GHz
                    • 16gb GSKILL TridentZ RGB DDR4-3200
                    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                    • Windows 10 Pro x64
                    • GeForce GT1050
                      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                    • CatalinaWOW
                      Gefingerpoker
                      • Jun 2011
                      #50
                      Thanks Krankshaft.
                      This info saved me a lot of time on a monitor with exactly the problems described.
                      • CatalinaWOW
                        Gefingerpoker
                        • Jun 2011
                        #51
                        Just a follow up. The monitor is fine now. Recapped for insurance, although there were no signs of cap failure. Root cause was cracked solder joint on ferrite core coil near center 2SC5707s. Took out both 2SC5707s.
                        Touched up all four similar joints. All were hard to get right, although only the cracked one was originally bad. Also found poor joints on AC connector.
                        Thanks again for those who posted this information. It shortened my path a lot.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          As others have mentioned, don't forget to resolder all the inverter transformer pins.
                          --- begin sig file ---
                          --- end sig file ---
                          • CatalinaWOW
                            Gefingerpoker
                            • Jun 2011
                            #53
                            "As others have mentioned, don't forget to resolder all the inverter transformer pins."
                            I resoldered them as advised, although all did appear fine under 15X magnification. Examined all joints on the board with the following conclusions:
                            1. Most reflow joints were good. It appears that a couple of parts had tombstoned and the rework on those was terrible, but probably electrically sound. Redid those for insurance.
                            2. All through hole parts were apparently done manually, by two different operaters. One was good, the other so-so. There were a lot of very good quality joints (including all of the transformers), and a smaller number of joints that ranged from marginally bad to margninally good.
                            Unfortunately I didn't take before pics, and don't think the after pics will help enough be worth opening the monitor up again to take. The bad solder joint was on the inductor adjacent (above-right) to the top right 2SC5707 in Krankshaft's picture identifying the drivers. The solder in the joint was fractured, fracture resulted from inadequate solder fill and poor wetting of the inductor lead. When I resoldered I found it difficult to get proper fill and wetting, it took lots of heat and added flux. True on both leads of both inductors. The pair of drivers ajacent to the bad solder joint were the two dead ones. There is a similar inductor between (slightly to the left) the other two drivers.
                            Last edited by CatalinaWOW; 06-21-2011, 10:31 AM. Reason: Name mispelling and clarification
                            • calcu
                              • Aug 2011
                              #54
                              I have burned Q815 & Q815, pleasetell me what are these transitor?
                              Do someone have the schematic for HP 1955?
                              Thanks in advanced
                              • bomcla
                                • Nov 2010
                                • 16
                                #55
                                the monitor has many monitors that use the inverter BQ. usually burn a 4-2SC5707 transistors, the 3 amp fuse or a MOSFET IRFU9024.
                                It is all in net. If the transistors are smd say I do not know what to say.
                                • krantz
                                  • Nov 2010
                                  • 23
                                  #56
                                  Re: HP 1955 Monitor Step By Step
                                  I have a 1955 that I am trying to get working. I have changed all the caps except for the 150uF 450v. I cant see any blown FET's or anything else that might be shorted. What could it be?
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    #57
                                    First describe the type of problem you are having.
                                    A monitor can fail in various ways.
                                    Does it have what we call 2 sec to black?
                                    Dose the power LED come on and recognize a signal?
                                    Can you turn the monitor on and off with the front power switch?
                                    • krantz
                                      • Nov 2010
                                      • 23
                                      #58
                                      The LED comes on and recognizes a signal when i push the power button. It then gives a picture for 0.5 seconds, restarts (also the LED blinks at the restarts) and repeats.
                                      I can turn it off if i hammer the power-button during the restarts.
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        #59
                                        Do you have a multimeter?It's time to look at some voltages.
                                        Even though this a long thread with photos,It would help to see photos of your power supply front and back.Try to get them focused so we can read the writing on the board
                                        Please use managed attachments to post the photos.
                                        • krantz
                                          • Nov 2010
                                          • 23
                                          #60
                                          Yes, I do have a multimeter but not sure what component to measure.
                                          Here are some pictures. Ive focused on the components as Krankshaft did.
