I believe this Westinghouse 19" widescreen is a rebranded Optiquest. Won't power up when plugged in. A lot of the parts inside say ViewSonic or OptiQuest. The Power/Inverter board is a DELTA, which outputs both 5Vdc, 3.0A and (inverter) 1250Vrms, 4.5 to 5.5 mA.
This unit has 5 bulging CapXon capacitors (hmm, beginning to see a pattern here), a likely blown fuse (3.15 A, 250 V radial button-type fuse), and a potentially blown resistor (and possibly the neighbouring inductor). A majority of the bulging CapXon capacitors have date code P608, so 8th week 2006. Here's the list of bad caps:
- CE100 _220uF 25V KF/105C 8 x 13 mm
- CE101 1000uF 25V KF/105C 10 x 21 mm
- CE102 1000uF 25V KF/105C 10 x 21 mm
- CE104 2200uF 10V KF/105C 13 x 20 mm (no bulge)
- CE105 1000uF 10V KF/105C 10 x 15 mm (no bulge, date code P608)
- CE107 __22uF 50V GL/105C 4 x 11 mm
- _C200 _220uF 25V KF/105C 8 x 13 mm
- C203 _220uF 25V KF/105C 8 x 13 mm
- [FONT=Courier New]Resistor Violet-Blue-Violet-Silver, which, if memory servers is 76 x 10^7 Ohms or 7.6 MOhm with 10% tolerance - I think
Pics are worth 1000 words, and will follow soon.
