I have a Dell 1703 fps where the backlight turns on for about a second. Turning the monitor off and on again causes the light to repeat the cycle.
The monitor has a Lien Chang inverter board (LI-2070) and the power board is numbered BN41-00296B. I've replace 3 1000 mf 25v Capxon and 3 1000 mf 16v Capxon electrolytics on the power board. The caps showed no signs of bulging and also tested good with an esr meter. There are two other caps on the power board and one on the inverter board that check good (with esr meter) that I have not replaced.
If I monitor pins 1 and 12 on the connector going to the inverter board (I'm pretty sure this is supposed to be the 12 volt line) I get 17.70 volts when plugged in but not turned on - after turning on and the backlight comes up the voltage is 15.26. The backlight goes off and the voltage increases to 19.47 volts.
Seems like this backlight issue is common for this monitor - anyone have a fix for it?
Mike
Mike
